How Are You Routing Your Front Brake Lines? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 02-13-2014, 09:36 PM Thread Starter
Mr. King's Avatar
Title says it!
When I got my JK back from the lift installer my front brake lines were left hanging like this! SERIOUSLY!
I'm curious how ya'll route and secure your front brake lines.
Please post 'em up and show us how you address this problem.
Thanks, Mr. King
"You come in to this world naked and screaming. If you go out the same way, you broke even; Everything else is a plus!" My friend, George
____________________________________________
"Opinions are also like bellybuttons. They're not good for a damn thing, but you sure would feel left out if you didn't have one." Dad
Mr. King is offline
post #2 of 8 Old 02-14-2014, 10:48 AM
orestespd5's Avatar
When I installed my RK lift that's how they suggested you run them...I have never had any issues.
2011 Wrangler Sport,RK 2.5 X Factor with RRD 2.0 shocks, Synergy steering, Poison Spyder bumpers narrow alum fenders diff covers, LOD sliders, Rockridge 4wd tail lights, trucklites, TF higned tire carrier, Cooper discover STT 37x13.50, 4.56 gears
Ordered a 2015 2 door Rubicon 3-23-15
orestespd5 is offline
post #3 of 8 Old 02-14-2014, 10:56 AM
Originally Posted by Mr. King View Post
Title says it!
Thanks, Mr. King
I have the AEV 2.5" lift and they supply you with Zipties to tie it to the shocks. This is only to keep it out of the way.
espi is offline
post #4 of 8 Old 02-15-2014, 07:23 AM
Poormanz28's Avatar
I installed stainless lines that came with a bracket that keeps them away from things. Got them from Rock Krawler
2008 Jeep JK Unlimited. Auto. Mods: 3.5 RK Max Travel Kit, RK tie rod. 35" Nitto Trail Grappers. Eaton 4 Pinion E-Lockers front and rear. Nitro 30 spline chrome moly front axles. Yukon 5.13 gears/Cyrotreated. Sleeved and gusseted front axle. Dynatrac ball joints. Mopar big brake kit, Advance Adaptors 4wd shift linkage, Tom Woods front and rear driveshaft. Ace Rock Sliders. Terra Flex hinged tire carrier, Carolina Metal Masters grab bars. Exp One Frt Bumper. Warn Zeon 12 Winch.
Poormanz28 is offline
post #5 of 8 Old 02-15-2014, 09:16 AM
JKO Dickhead
Asmmns's Avatar
This is an old picture but I pretty much left mine hanging. No issues after three years of wheeling like that. If the terrain appears to have a lot of possibility to yank e6n like downed trees and stuff I sill zip tie them. For the most part tabulate fine though
__________________
CURE SMA !
Asmmns is offline
post #6 of 8 Old 02-17-2014, 04:41 PM Thread Starter
Mr. King's Avatar
Anybody Else...
Or is this a non-issue? Everyone just lets 'em hang?
The way mine were left I felt that a minimal amount of droop could allow the brake fluid to be liberated from the line and possibly wreck the ABS sensor wire.
I did reroute the lines between the spring and shock and added the tie-wraps. After breaking the tie-wrap on one side I still think it is less than an optimal solution.
Letting mine just hang was absolutely out of the question.
I get the double entendre...
C'mon y'all, show/tell us how you handled it (the brake and ABS lines).
Mr. King
Mr. King is offline
post #7 of 8 Old 02-18-2014, 10:28 PM
Nomadr's Avatar
I have routed mine along the ABS/wheel sensor lines, and tied to the shock. I have torn out 1 wheel sensor already, and like to keep the lines tucked up. Branches can be harsh.
2011 Unlimited Rubicon
Currently: Henderson, CO
Nomadr is offline
post #8 of 8 Old 02-19-2014, 10:16 AM
membrain's Avatar
Pics of my work-around: zip-tied ABS to brake line, and then clips with springs to keep the slack out of the tires when I turn. (added pics!)
2010 Red Unlimited Rubicon 6 speed - Traded!
2014 Red Unlimited Rubicon X 6 speed - starting over!
membrain is offline
