RED LIGHT OIL - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 02-01-2014, 02:06 PM Thread Starter
RED LIGHT OIL
Just wanted to throw this out there. my 2011 JK with 31000 was 2 quarts low on the oil when I went to do my own oil change. found the same last year with the wife's 3.5 chy.......dealer says quart at a 1000 is normal for the new ones....my reply was simple the book say change at 8000 in the new ones and they ony hold 6.....you do the math. After checking the chy forums I found this is a very common problem in the 3. v6s that chy is very aware of......I guess we go back to standard check at every fill up. BEAWARE! By the way no leaks or smoke with either.
muddauber is offline
post #2 of 6 Old 02-01-2014, 10:12 PM
offroader613's Avatar
2011=3.8L=notorious for using oil. Happens earlier to some than others...fairly common on here...
offroader613 is offline
post #3 of 6 Old 02-02-2014, 04:32 AM
10jk's Avatar
Wonder if it has anything to do with the thinner oil that is called out on these newer engines. Or is it to do with the PVC system they are now using????????
I don't know. What changed? Seals, gaskets, Rings, Valve stem seals?????
2010 JKUR, 4" Pro C., 3/4" f Daystar spacer, 5.38's, EVO sleeve/gusset/custom trussed, Rear Ten Factory axle shafts, 1.5" wheel spacers, Pro C. 17 x 9 wheels, 38 x 14.50 x 17 MTR's, SuperChip FP, no fenders, B&M Tranny cooler, Magnaflow, Fr./ Rr. frame hacked off, HD Balls
29,000 miles as of 12/13/14
10jk is offline
post #4 of 6 Old 02-02-2014, 05:56 AM
OH9JK's Avatar
Yep, I am old school and check my oil at every fill up.
I switched to 10w-30 a long time ago and have not had consumption issues. The thicker oil also helped with engine pinging.
If your engine isnt leaking oil, its burning it. It doesnt just disappear
OH9JK is offline
post #5 of 6 Old 02-02-2014, 06:06 AM
It is pretty common. My 2009 was changed at 1,000 miles old to 5w-30. I haven't burned a noticeable amount of oil between changes in ~74k miles.
post #6 of 6 Old 02-02-2014, 03:32 PM
doesnt matter what oil I use, I burn through a quart every 1000 miles like clockwork. Pretty sure its the valve seals but I could be wrong.
Mike
'07 2 door soft top
Espo78 is offline
