Strange Sound when Accelerating - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 01-31-2014, 06:33 PM Thread Starter
Vaydarade's Avatar
So I went wheeling last weekend and had a blast. However, I came down decently hard a few times, but from what I could tell only on my side rails and that's about it. But now when I accelerate from a dead stop, whenever I pass about 750-1000 rpm I hear a grinding noise (or like noise like a baseball card in some bicycle spokes but deeper and less fast).
Does anyone have any idea as to what this could be? As a side note, after wheeling, my steering wheel was also cockeyed from what it normally is as well. As in, when my car is going straight my steering wheel is in a slight left hand turn position.
I am still new to wheeling and krawling and am still also learning about the ins and outs of my jeep so I have no idea. Any help would be much appreciated so when I do take it in to have it checked I can sound intelligent and also so I learn a little bit more about my jeep.
Black 2012 MW3 4-door Rubi, Teraflex 2.5" lift, Rugged Ridge Wheels, Goodyear Duratrac 35s, Smittybilt XRC GEN2 front and rear bumper, fender armor and rock rails, Custom Grille wrap-Kryptek Typhon Camo, Warn 10-S Zeon Platinum, EVO Full-Protek Skid plates, Cobra 29 LX CB Radio, MetalCloak Fender liners, HIDProjectors Lights, S-pod, Genesis Offroad Dual battery kit, Rigid Industries 50" Light bar
Vaydarade is offline
post #2 of 10 Old 01-31-2014, 06:47 PM
ockgator's Avatar
Noises and vibes that seem slower than engine speed are usually in the wheel area. Get the weight off the tires and check your bearings and such. If you DIY use QUALITY jackstands. Grab each at 12 and 6 and see if there's movement, should be negligible, Do same at 9 and 3, but be aware that hard shaking this way will move steering.
Also while supported, put a pry bar under each front tire and pull upwards to check the balljoints, again not much movement.
While under there see if there's anything obvious... IE bent control arms and such... Worst case bent axle housing.
By stating the strg wheel is off that means there's something bent (duh), All you have to do is find it
Look at ujoints also as they're known for popping caps off, But this shouldn't affect steering wheel
BTW sometimes a front bearing noise can be found by steering side to side and listening for the noise to change.
Proud to be deplorable
ockgator is offline
post #3 of 10 Old 01-31-2014, 08:22 PM Thread Starter
Vaydarade's Avatar
The noise isn't from moving the steering wheel, its from accelerating. It is always the same, whether turning left, right, driving straight, or even in reverse. And it only happens when the RPMs are passing 750 (as in the tic right before the 1 dash....)
But I'll just what I can. I don't have jack stands so well see.
post #4 of 10 Old 01-31-2014, 08:52 PM
jeeperjkjeeper's Avatar
check for torn driveshaft boots yet?
jeeperjkjeeper is offline
post #5 of 10 Old 01-31-2014, 11:50 PM
camo36's Avatar
Wait, is there ANY chance anyone had baseball cards on this trip? let's rule that out first... sorry, i've been drinking, i'll leave now.
guess i can add something productive, any chance your fender liners are deformed or dislodged some how rubbing on a tire and flapping? happens at straight wheel and while turning both directions? or does it go away if you turn the wheel?
'64 CJ-5, '74 Bronco, '79 CJ-7, '84 CJ-7, '92 XJ, '96 XJ, '99 XJ, '01 TJ, '01 XJ, 2013 JKU.
2013 Commando Green JKU
35x12.50/17 Falken Rocky Moutain ATS
2.5 RK X-Factor
17" Black Rock Vipers
Cut Stock Flares
Diablo Sport Trinity (garbage)
Sleeve, Truss, ARB, Chromo D30
camo36 is offline
post #6 of 10 Old 02-01-2014, 01:06 AM Thread Starter
Vaydarade's Avatar
Have not. Too dark out.
Haha, postive nobody had baseball cards. Also my fender liners are not currently attached to my jeep, nor were they when I was enjoying the outdoors so thats out.
And its not a constant sound, it happens when the engine passes 750 RPM and then stops. And yeah, I can be turning left, right, going straight and backing up and it makes the sound. Its like I said, a kind of grinding sound that is similar to the sound made when you attach a baseball card to bicycle wheels but deeper and I guess it could be said that it sounds like metal groaning a little too....but thats just what I think it sounds like. I've looked underneath my car and haven't noticed any real damage other than some scraps on my skid plates, but thats not a big deal because they are pretty hefty and not warped at all...
post #7 of 10 Old 02-01-2014, 01:55 AM
Random Dude
I had a bolt connecting the left front corner of my engine skid to its mounting bracket loosen up slightly one time (I have RockHard skids, but the principle applies). It made an unnerving, RPM-dependent noise similar to what you're describing. You most likely don't have the exact same problem, but something may have loosened up that hits its resonant frequency right as you go through 750-ish RPM.
That's all I got. Hope it's something simple and inexpensive.
Oh, and X2 on steering wheel off-center = somethin's benter.
ExWrench is offline
post #8 of 10 Old 02-01-2014, 02:29 AM
Jay EE P's Avatar
Are you sure it's a grinding sound and not metal on metal vibration? Check the aluminum heat shield where your pipes cross from the passenger side above the skid. Mine did the same thing, at a specific RPM range… a little JB weld and a hose clamp and it was solved.
Jay EE P is offline
post #9 of 10 Old 02-01-2014, 01:54 PM
i had this same thing happen the first time I went out, tore the boot on my front driveshaft and every rotation it would tap the firewall or exhaust whatever was next to it.
the steering wheel being mis aligned is probably a different issue im guessing but i am new as well so i dont really know
also is this a manaul or auto?
I know in low rpm on my mustang the throw out bearing/clutch kinda groans or rattles around that rpm.
GreenThing13 is offline
post #10 of 10 Old 02-02-2014, 06:34 PM Thread Starter
Vaydarade's Avatar
Ok, I'm still holding off going to the shop for a diagnostic because work....but I can check. And its an auto transmission. Ill see if I can see anything in the morning that might look loose as well.
