preparing for frigid temps - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 01-26-2014, 05:02 PM Thread Starter
mcrawford's Avatar
Heading up to the u.p for the soo 500 this coming weekend. I don't have much experience with cold that Damn cold. What if anything should be done to prepare the jeep? Has been in storage for winter, so I'm a little nervous. Probably no reason to be, but I don't want to be stranded or stuck because I wasn't ready for it. The only things I can think of off hand are my rear diff fluid (75w-140) and no block heater. Any tricks to reduce/ prevent lifter noise in crazy cold temps? What sorts of accessories should I pack incase of anything?
mcrawford is offline
post #2 of 10 Old 01-26-2014, 05:42 PM
spieg's Avatar
The jeep will be fine. You can run a thinner oil if youre really worried about cold start wear. Just let the jeep warm up to temp before you stomp on it.
Id pack the following:
Blanket
Change of warm clothes
Heavy gloves or mittens
Shovel
Hatchet
High calorie snacks
Jumper cables
Standard recovery gear (straps, hitch pin, d-rings, snatch block and tree saver if you have a winch, etc.)
All the other normal good idea stuff (first aid kit, lighter, tarp, etc.)
spieg is offline
post #3 of 10 Old 01-26-2014, 07:14 PM
Sgo70's Avatar
Shovel for sure and I have a high lift jack mounted to my jeep. Gets really cold here, -30 C or lower and I don't have a block heater just a high cranking amp battery, 800 cca or so works and 5w20 or 5w30.
The hard pack snow drifts will get you every time.
Sean
Sgo70 is offline
post #4 of 10 Old 01-26-2014, 08:07 PM Thread Starter
mcrawford's Avatar
Ok cool thanks guy's. Like I said, I'm sure I'm way over thinking this but want to be sure I won't have to blame myself for lack of preparation. I do have a winch, straps, shovel and switched to a group 34 battery over the weak factory group 91, however no hi lift. Thinking about ordering one, might be the perfect excuse to.
post #5 of 10 Old 01-26-2014, 08:10 PM
Dutch's Avatar
Really good boots and gloves.
Americans can sleep peaceably at night because US Soldiers stand ready to fight on their behalf
2008 Unlimited Rubicon: 37's, 3" Synergy Springs, Artec trusses, 5.38's, Winch, PSC/Poly Cage, Bumpers, TNT Alum belly skids, and other doodads
Dutch is offline
post #6 of 10 Old 01-26-2014, 08:35 PM
gnarlyswine's Avatar
Spare socks, woolen. More than one pair.
Thermals.
Pocket heaters maybe. Maybe scarf, balaclava, mask or something for face if windburn likely. Hat that covers ears.
For gloves I have shooters ones that have fingers, and flip back mitten covers.
These are a few things I found really useful paintballing in the woods in canada in the winter around -40.
Unspoilt by progress.
gnarlyswine is offline
post #7 of 10 Old 01-26-2014, 08:56 PM
2008jkx's Avatar
you could insulate your hardtop! check that out. i live in tahoe, 7000ft, and we get cold winters, i also lived in my jeep for a month or so on a road trip through southern BC, and alberta and it would be -14f. no problem sleeping with tons of blankets, but in the AM when the sun hit the hardtop, it would melt my condensation which would drip back on me.
2013 rubi axles. 2.5in RK max travel. coast front DS.. rockhard oil pan and tranny skid plate. xrc 8 comp winch mounted on RR XHD
south lake tahoe california.
2008jkx is offline
post #8 of 10 Old 01-27-2014, 04:11 AM
Condoms! Gotta watch some of them up'ers
77bronco is offline
post #9 of 10 Old 01-27-2014, 09:54 AM Thread Starter
mcrawford's Avatar
thanks again for the tips guys. I should be set personally, my main concern was the jeep considering low's in the -20's last I checked. I guess we are staying in a casino.....so i'm solid. i think.
post #10 of 10 Old 01-27-2014, 11:26 AM
Boyer343's Avatar
-14 with the windchill this morning
Boyer343 is offline
