Driving without outter stub shaft installed - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 01-24-2014, 11:05 AM Thread Starter
10jk's Avatar
Will the unit bearing come apart? Is it safe? I've heard both, you can on a JK and you can not. What's the real deal?
2010 JKUR, 4" Pro C., 3/4" f Daystar spacer, 5.38's, EVO sleeve/gusset/custom trussed, Rear Ten Factory axle shafts, 1.5" wheel spacers, Pro C. 17 x 9 wheels, 38 x 14.50 x 17 MTR's, SuperChip FP, no fenders, B&M Tranny cooler, Magnaflow, Fr./ Rr. frame hacked off, HD Balls
29,000 miles as of 12/13/14
10jk is offline
post #2 of 11 Old 01-24-2014, 11:20 AM
Fklein6768's Avatar
You can run w/o the shafts up front no problem.
www.4x4s-pod.com
Fklein6768 is offline
post #3 of 11 Old 01-24-2014, 11:23 AM
No it will not come apart. Just stuff a rag in the axle tube.
post #4 of 11 Old 01-24-2014, 11:28 AM Thread Starter
10jk's Avatar
Thanks guys because that ugly rumor is raising it's head again. Maybe it was true on an earlier Jeep or something.
Just to let you guys know. This is my first experience on a Jeep. I was a early 80's Toyota (2 of them) and 80's K-5 blazer (3 of them) before. Thanks again.
10jk is offline
post #5 of 11 Old 01-24-2014, 11:50 AM
steve578's Avatar
You can run without the stub shaft on a JK, but you CANNOT run without the stub shaft on a TJ.
2013 JKUR
steve578 is offline
post #6 of 11 Old 01-24-2014, 12:08 PM Thread Starter
10jk's Avatar
That is where people are getting all jacked up about it. Applying TJ stuff to JK applications.
10jk is offline
post #7 of 11 Old 01-24-2014, 12:23 PM
Jeepineer
JKred07's Avatar
To my understanding, it's because the older unit bearings were tapered roller bearings; they would need the preload of the hub nut to stay together and work properly.
JK unit bearings are either standard roller or ball (ball I think, but I'm not 100%), which do not need an axial preload.
....I suspect this is also a big reason the JK unit bearings aren't as "long lasting" as well.... roller and ball bearings don't handle axial loads well.
-Mike
JKred07 is offline
post #8 of 11 Old 01-24-2014, 01:27 PM
Panamon Creel's Avatar
Don't know if they are using tapered or angular ball bearings in the JK unit bearings but the difference is that they are strongly fixed together with a fixed pre-load within the unit thus will not fall apart without a stub shaft.
Regarding "not long-lasting", well they are engineered for OEM tire weights and sizes
2010 JKU Sahara
Panamon Creel is offline
post #9 of 11 Old 01-26-2014, 06:59 PM
Jeepineer
JKred07's Avatar
Spyntec has broken down pictures on their website. They're angular ball bearings, but ball bearings none the less.
And you are correct, they are preloaded during manufacturing.
-Mike
JKred07 is offline
post #10 of 11 Old 01-26-2014, 08:10 PM
ronjenx's Avatar
Here is a thread that shows what's inside the JK unit bearings:
https://www.jkowners.com/forum/showthread.php?t=35276
ronjenx is offline
post #11 of 11 Old 01-26-2014, 11:04 PM
orestespd5's Avatar
Shattered my ring and pinion today I disconnected my u joint from the inter axle shaft and I'm just running the nub shaft with a rag in the axle tube.
2011 Wrangler Sport,RK 2.5 X Factor with RRD 2.0 shocks, Synergy steering, Poison Spyder bumpers narrow alum fenders diff covers, LOD sliders, Rockridge 4wd tail lights, trucklites, TF higned tire carrier, Cooper discover STT 37x13.50, 4.56 gears
Ordered a 2015 2 door Rubicon 3-23-15
orestespd5 is offline
