Ice proofing the rims??? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 25 Old 01-05-2014, 06:57 PM Thread Starter
jeeper2008's Avatar
Is there anything that could be done to rims to keep ice from forming on them? I went wheeling yesterday and spent about hour chiseling ice off my rims after short trip down the freeway I couldn't get over 40mph without shaking the Jeep apart. Name:  ImageUploadedByAG Free1388973448.172246.jpg
Size:  77.2 KBName:  ImageUploadedByAG Free1388973460.954980.jpg
jeeper2008 is offline
post #2 of 25 Old 01-05-2014, 07:23 PM
JKO Dickhead
Asmmns's Avatar
There is a number of things that could be done...
1) move to a warmer climate
2) don't use jeep while there is snow on the ground
3) when there is a chance of snow in the forecast, remove all the wheels, keep the jeep on jackstands and brink the wheels inside until they are needed
4) garage jeep til spring or summer
5) maybe try some Pam or other not stick cooking spray and give them a liberal dose prior to inclement weather
6) hire an illegal immigrant to climb under the rig and remove snow and or ice at every stop
7) take off the esp and spin the tires till all snow has been removed my means of centrifugal force
8) reroute exhaust so you have a one into four, with each outlet pointed at the back of the wheel for heat and ice melting
Or...
9) don't worry about it and get some real world problems
__________________
CURE SMA !
Asmmns is offline
post #3 of 25 Old 01-05-2014, 08:30 PM
jaker's Avatar
I was going to say get a flame torch but that is taking the easy way out
jaker is offline
post #4 of 25 Old 01-05-2014, 08:37 PM
Maybe try WD40. Try one first. I would imagine it would keep snow from from sticking.
da20captain is offline
post #5 of 25 Old 01-05-2014, 08:42 PM
Guruman's Avatar
Originally Posted by jeeper2008 View Post
Is there anything that could be done to rims to keep ice from forming on them? I went wheeling yesterday and spent about hour chiseling ice off my rims after short trip down the freeway I couldn't get over 40mph without shaking the Jeep apart. Attachment 111729Attachment 111737
I don't have an actual answer, but I feel your pain. Others may joke, but it's genuinely a PITA. I had a Cayenne with this issue and it was awful. The only observation I have is that the rims I had with this issue were very flat on the inside which contributed to the buildup of snow/ice and small stones. I wonder if different wheels would help. In my case it was not much of an option as the choices were limited as to what would fit.
_
Guruman is offline
post #6 of 25 Old 01-05-2014, 08:56 PM
Keep it off the brake rotors!
post #7 of 25 Old 01-05-2014, 08:56 PM
jaker's Avatar
To be real how about you cover the wheels that way the wind does not get to them
I am thinking get 4 tarps and cover the wheels for the night and just pull them off before you leave
jaker is offline
post #8 of 25 Old 01-05-2014, 09:07 PM
RubiZealot's Avatar
neverwet?
Mike 2010 Rubicon 2DR | RK 3.5 X FACTOR MID ARM | ΜΟΛΩΝ ΛΑΒΕ
RubiZealot is offline
post #9 of 25 Old 01-05-2014, 09:46 PM
Guruman's Avatar
Originally Posted by RubiZealot View Post
Great idea. Might be worth spraying the insides of the wheel wells/inner fenders just to help keep them clean. I wonder how long this stuff lasts....
_
Guruman is offline
post #10 of 25 Old 01-05-2014, 10:05 PM
Dutch's Avatar
I've never had in issue with this at all and I grew up in Montana and live in Colorado. Even after winter drifting my S4 through parking lots and completely filling the wheels with snow I never had an issue with it throwing my tires that out of balance.
You guys remind me of the "Mud in your tires" scene in My Cousin Vinny.
Americans can sleep peaceably at night because US Soldiers stand ready to fight on their behalf
2008 Unlimited Rubicon: 37's, 3" Synergy Springs, Artec trusses, 5.38's, Winch, PSC/Poly Cage, Bumpers, TNT Alum belly skids, and other doodads
Dutch is offline
post #11 of 25 Old 01-06-2014, 07:58 AM Thread Starter
jeeper2008's Avatar
The ice build up isn't from sitting while it snowed or from regular driving. It accumulated through the while out wheeling all day on rocks and some mud/water holes. I've been winter wheeling before but never had this happen. I wasn't the only one either that it happened too. We topped out at 6*f Saturday at Rausch creek. I'm sure this didn't help but ya gotta do what ya gotta do...Name:  ImageUploadedByAG Free1389020141.668811.jpg
Size:  124.2 KB. Ice at this hole was 5" thick.
post #12 of 25 Old 01-06-2014, 08:02 AM
I hear ya. Don't have the solution though. I'm in MN. Our high today is something like -14. Its 24 below right now. I was out playing around on Saturday, and I had the same issue.
96zjlimited is offline
post #13 of 25 Old 01-06-2014, 08:17 AM
Guruman's Avatar
I once pulled over 2 pounds of "traction aid" stones and grit out of one of my wheels. When I was having this problem it was fine until I'd stop and half of the material would fall to the bottom, making each wheel a pound or so out of balance. 40MPH with all your tires a pound of of balance will shake your eye teeth out. I'd have no choice but to stop and try to clean it out, and then stop again because I didn't get it all. I had a 520HP Porsche Cayenne Turbo S, which was pretty awesome in every other way but this was the main reason I got rid of it.
_
Guruman is offline
post #14 of 25 Old 01-06-2014, 01:19 PM
funfred's Avatar
NeverWet sounds like it's worth a try but I found nothing about its "green" properties, if that's a concern. Much more, what does it do to tires?
Car wax and Rain-X are other options but require significantly more elbow grease to apply.
Then there's Teflon coated wheels.
According to NeverWet, their product outperforms the aforementioned products by a long shot but I'd be concerned about any chemicals that were superhydrophobic. For one thing, it doesn't like water. I mean, it appears to absolutely hate water!!! That's just not right.
PAM? I wouldn't use it on anything, much less a frying pan.
There is Ballistol...it's like CLP except it's "green". Not a hydrophobic product, it mixes with water, but I imagine it can't be any worse than using WD40. Aerosol or liquid(put the liquid in a spray bottle). It's also safe for other than metal products like leather, rubber, plastic, tires, wood, etc.
Check it out...it's not exactly inexpensive, tho'. If you like it, it's also available in buckets and drums but not from this website.
http://www.ballistol.com/about-us/
Great first-aid anti-septic, too, but our government won't approve its medical use. The medical grade version is overseas only...I think it has pain-killer in it.
Some people can't stand the smell(kinda like licorice) but the odor dissipates shortly after application.
Oh, you wanted a sales pitch?
Spray your fender wells with Ballistol before you get your Jeep muddy. Hell, spray the whole undercarriage!!! It's green and keeps it clean!
I wouldn't be surprised if it returns sun-faded fenders and trim back to black, either.
Seriously, ice-packed wheels suck. Almost anything is better than doing nothing, except dragging your brakes to put heat in the wheels. Don't do that.
funfred is offline
post #15 of 25 Old 01-06-2014, 02:41 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
You guys are a bunch of tool bags! Pretty sad that the guy who has only ever lived in SoCal or the desert knows this shit...
2:1 Ratio of isopropyl rubbing alcohol to water in a spray bottle or for larger applications like yours, a pump sprayer. You can usually get those big bottles of rubbing alcohol at Wally World or the CVS/Walgreens on sale. Probably cost you ten to fifteen bucks to fill up a pump sprayer and would last a while.
http://kk.org/cooltools/archives/5944
JKCTAZ is offline
post #16 of 25 Old 01-06-2014, 03:00 PM
funfred's Avatar
What he doesn't know, cuz he lives in a dry, temperate climate, is that alcohol is bad for his windshield seal. Up north, the only alcohol that gets mentioned in the same sentence as rubber comes in bottles with classy labels.
funfred is offline
post #17 of 25 Old 01-06-2014, 03:04 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Yeah, but he's going to use it on his wheels, or drink it until the vibration feels good. Either way...
JKCTAZ is offline
post #18 of 25 Old 01-06-2014, 03:16 PM
A JKO DICK
ASSFROW's Avatar
I heard someone say " vibration, alcohol and feel good", so here I am!!!!
ASSFROW is offline
post #19 of 25 Old 01-06-2014, 06:26 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
LOL, Frow of Ass! Got a chuckle out of me.
JKCTAZ is offline
post #20 of 25 Old 01-06-2014, 08:23 PM
HAFICON's Avatar
Yea I feel your pain as well.. Winter time sucks but is still kinda fun. I may try a few idea suggested above not really worried about the finish on my wheels and they and rock bashed anyway. Might try something different on each wheel and see what works.
Quick google search on Liquid ice melt turned up lots of results.
Here is one. I am not concerned with he finish on my 6 month old wheels.. *L* I am going to sand then and coat them this summer anyhow.
http://www.menards.com/main/outdoors...34-c-12409.htm
Or:
http://www.megagro.com/iceclear.htm
For me it is not a matter of removing what is there, it is keeping it from building up. Tire cover might be the next best answer. My single carport houses the wife's car and is not tall enough for my JK regardless. Nothing worse than getting recalled into work at 2am and shake to death the whole way there. Just to jump on a boat and get tossed around all night.
HAFICON is offline
post #21 of 25 Old 01-07-2014, 07:39 AM
I used to use these when I raced ATVs http://www.bykas.com/Rim-Spins-Custo...esigns-s/2.htm. Maybe some one can fabricate something out of a plastic for full size rims.
MUD707 is offline
post #22 of 25 Old 01-07-2014, 05:00 PM Thread Starter
jeeper2008's Avatar
I expect nothing less than tool bag remarks from this crowd, Lol. Even though I don't post much, I'm surprised I haven't had any tool bag remarks before.
Some ideas thrown out that I'll have to try if I get out on another winter run.
post #23 of 25 Old 01-07-2014, 05:06 PM
funfred's Avatar
I just remembered. One of the times my wheels were snowpacked and I said fuggit, yeah, the ride got bad. It also tossed some balance weights so there's that to look after, too.
funfred is offline
post #24 of 25 Old 01-07-2014, 05:08 PM
Cavallini03's Avatar
Just pee on each tire after you go through the snow. It will melt it all off
Cavallini03 is offline
post #25 of 25 Old 01-07-2014, 05:22 PM Thread Starter
jeeper2008's Avatar
We joked about that. Lol
