Magnet to reach inside of axle tube? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 12-29-2013, 07:55 PM Thread Starter
Whats a good pole magnet to reach inside of the longside axle tube?
When on the trail and something snaps, wanna get it out without removing diff cover and center. Sounds silly, but Ive seen these and cant think of what their called.
GlennH is offline
post #2 of 8 Old 12-29-2013, 08:06 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Here ya go.
http://m.lowes.com/product?langId=-1...lue=4294925673
JKCTAZ is offline
post #3 of 8 Old 12-29-2013, 08:12 PM
Telescoping magnet will be better than nothing, but if you're dealing with pieces, there is a decent chance it won't be strong enough to pull the splines out of the differential.
post #4 of 8 Old 12-29-2013, 08:51 PM
redneck ron's Avatar
^^^^^This. Last axleshaft I broke would not budge with the magnet.
It isn't so much that liberals are ignorant. It's just that they know so many things that aren't so.― Ronald Reagan
redneck ron is offline
post #5 of 8 Old 12-29-2013, 09:22 PM Thread Starter
Found this one... little more then the simple 2-3lbs one.
http://www.expeditionexchange.com/ullmandevices/
Ullman Devices Telescoping MegaMAG Magnetic Pick-Up Tool (GM-2) $17
The Telescoping MegaMAG Magnetic Pick-Up Tool telescopes from 7 1/8" to 30 1/4" for reaching into crevices and axle housings, and lifts up to 16 lbs. The stainless steel handle and telescoping elements are long, strong, and lightweight. The textured cushion handle covering keeps the tool secure even in wet or greasy conditions. The goblet-shaped head pushes flux to the top of the very powerful Neodymium magnet, and focuses and concentrates the magnet's power, so that the head will not be attracted to ferrous surfaces and objects to the side and make the tool difficult to use in tight confines. This tool is ideal for fishing out broken halfshafts and other vehicle carnage. And of course it will pick up dropped fasteners.
GlennH is offline
post #6 of 8 Old 12-30-2013, 09:00 AM
I tried several magnets when I snapped my rear axle shaft and no luck at all getting it to pull out of the splines.
post #7 of 8 Old 12-31-2013, 03:08 PM
Research, bro!
RRauzer's Avatar
We found out through trial and error that the stock antenna with the ball snipped off works great. Pull the other side's shaft, duct tape the antenna to something long that reach up to the differential and push the broken piece out. The antenna is strong enough to hold shape and thin and flexible enough to get past the carrier pin.
"Are you gonna bark all day, little doggy, or are you gonna bite?" - Mr. Blonde
A proud part of the Cutts!
RRauzer is offline
post #8 of 8 Old 01-01-2014, 05:24 AM
Chipewa's Avatar
Place PVC pipe in axle tube. Take long piece of weld rod and touch to end of broken shaft with stick welder. Pull out broken piece.
LS3 2007 JKU X - Red Rock, 2012 JKU Rubicon - Deep Cherry Red, 2001 TJ - Black
Chipewa is offline
