Heat Dissipation Hoods, Which to choose - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 11-18-2013, 04:10 PM Thread Starter
4wdave's Avatar
I need opinions and real world results on the effectiveness of the following hoods for heat dissipation over a Hemi. Including quality of the hood. I have three in the running.
1) TOTL Innovations Positive, good air flow characteristics due to domed hood vent. Good finished look. 25lbs. / Negative, not sure I can get past the look of the domed hood. Little bit radical.
2) River Raider Hi-Flow Hood Positive, Like the look of the center raised area. Not sure of the amount of opening at the rear of the hood for heat dissipation. 14 lbs. / Negative, side air vent does not have a finished look although it is quite large and may need water trough to direct water from TIPM. Need to see the underside support, will it flex too much.
3) TMD Hood Positive, I just like the look of this hood. Not sure of the heat dissipation effectiveness compared to the first. / Negative, It is made of PLASTIC. Most expensive of the three.
2011 JK Rubicon - 5.7 VVT, 545 RFE transmission, Areoforce Gauges, Coast 1310 Drive Shafts, ORW Transmission Cooler, Metalcloak control arms & 2.5" Springs, Bilstien 5100, 4.56 Gears, Teraflex Front Big Brakes, C Gussets, GenRight Front & rear bumpers, LOD Rock Rails, 9.5 SR Superwinch, SPOD, Viair compressor, Boom Mat, Backup Camera, Truck-Lite Headlights, Rigid D2
4wdave is offline
post #2 of 7 Old 11-19-2013, 07:48 AM
MR LIKA's Avatar
My hemi would overheat in traffic when it was around 85 degrees and I ran the air. I had the AEV hood. I now have the TOTL hood, and have not had a problem with overheating yet.
JKUS Sort of
MR LIKA is offline
post #3 of 7 Old 11-19-2013, 07:52 AM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
TOTL, a quality product, effective, and a vendor here so if you have any issues you'd get great support.
JKCTAZ is offline
post #4 of 7 Old 11-19-2013, 12:17 PM Thread Starter
4wdave's Avatar
Had a feeling that was the case. I did not over heat this summer with a stock hood and vents but I did not push it either and saw temps to middle 220's. Definitely would like to get it down a little bit. The extra air space and vents on the TOTL hood may be the key. Thanks
4wdave is offline
post #5 of 7 Old 11-19-2013, 03:09 PM
Daniel_M's Avatar
I am not crazy about the looks of the TOTL either but it may be designed that way for a reason. Seems like it has the best heat dissipation of the other 2 you posted and the AEV.
If function over form is what you are after, then get that one.
-Dan
2008 JK X: Sold
Daniel_M is offline
post #6 of 7 Old 11-19-2013, 03:54 PM
Thisguyhasadd42's Avatar
Based on looks, RR gets my vote.
2010 Mango 2dr 6spd Rubicon
Thisguyhasadd42 is offline
post #7 of 7 Old 11-22-2013, 06:00 PM
TOTL Innovations's Avatar
Thank you very much for the vote guys. Really means alot to gain the respect of the community.
Let me know if there are any questions I can answer that might help in your decision making process.
As a side note, we will be running a sale Thanksgiving weekend if that will have any influence on your selection.
- The most functional Jeep JK Hood on the market!
TOTL Innovations is offline
