Install Suggestions?! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 08-20-2009, 04:55 PM Thread Starter
FHMan1905's Avatar
Send a message via AIM to FHMan1905
Got my new bestop bikini in today and have been working on the install...what a PITA...any tips or tricks....and it is so tight it is pulling my door surrounds up (behind the rear door) And i don't even have the other side completely in yet!!!
Any suggestions would be much appreciated!!!!
Lance
2007 Sahara Unlimited
4" Lift, 35" KM2's, Soft 8's, 4" HIDx windshield mounted, Finishlinewest rocksliders and 4.0 bumper, Bestop Trektop!
FHMan1905 is offline
post #2 of 7 Old 08-20-2009, 05:28 PM
Lance
With any soft top install, especially when new.....let it sit in the sun for a while before install and during install.
Off-road.com
JK Project
Recession Cheap Cherokee
JK Project 2
PBach is offline
post #3 of 7 Old 08-20-2009, 06:16 PM
lmg5819's Avatar
hey lance,
i had the same issue with mine, and got to a point where I tucked the driver side passenger flaps into the door surrounds and left the passenger sides flying free. After about a month, I was able to stretch the top so that both sets of rails are in, but without any pressure, one side will immediately pop. to solve that issue, I used a bungie cord wrapped from one side to the other to keep constant pressure on the rails. it hasn't popped since, and if you're not looking for the bungie, you can't really see it. also, the bungie doesn't affect using to doors, if you absolutely need those.
and like pbach said, let it sit in the sun for a few hours before you do the install, it will help loosen the material, and make it easier to stretch a bit.
good luck.
lmg5819 is offline
post #4 of 7 Old 08-20-2009, 06:19 PM
Mule'Con's Avatar
My bikini mesh is the same way. Works great without the door frame kit, but, with the door frame kit on, its over stretched to work without f-n things up.
2008 Red Rock Rubicon Unltd 6spd dual top
Mule'Con is offline
post #5 of 7 Old 08-20-2009, 09:19 PM Thread Starter
FHMan1905's Avatar
Originally Posted by lmg5819 View Post
hey lance,
good luck.
got any pics of that bungie idea!!!
post #6 of 7 Old 08-20-2009, 09:43 PM
paramaniac's Avatar
X3 on the sun idea. I used to use pliers to pull the esdges into the surround channels. I left it open in the sun one day while I was at work, put it on while still hot (holy sh it was it hot) and now it goes on no problems!
paramaniac is offline
post #7 of 7 Old 08-20-2009, 10:00 PM
lmg5819's Avatar
tomorrow...
lmg5819 is offline
