Lets get the tape out!!! (Tires) - JKowners.com : Jeep Wrangler JK Forum
post #1 of 21 Old 07-28-2009, 12:05 AM Thread Starter
lbh
lbh's Avatar
I am in the market for a new set of tires. I am running 37" Krawlers now, but as much street drving I do, I need a new tire. soooo.... I am looking for a TALL 37" tire. Currently my 37" Krawlers measure in at 35 3/4" on the Jeep. If you have some free time, measure you tires and post the make please.
2007 JK
lbh is offline
post #2 of 21 Old 07-28-2009, 12:29 AM
blownJK's Avatar
if what your lookin for is a "true" 37" tire...check out those new MT/R's with Kevlar...I've been reading up and hearing good things, haven't run them but all the field test seem pretty cool
Like us on
blownJK is offline
post #3 of 21 Old 07-28-2009, 07:57 AM
RiggerMike's Avatar
Go see Hundy.
http://www.100dollarman.com/tires.html
Current Mods:
  1. Cleghorn tailpipe mod
  2. Cleghorn side step ventilation with Gold Mtn. enhancement
  3. Heartbreak Ridge bumper scuffs
  4. Goler gas tank skid mod
  5. Miscellaneous pin striping
  6. Woods evap cannister relocate (Wow, an intentional mod!)
  7. 2"BB and swapped in stock Rubi coils and shocks (thanks Seth!)
  8. Calico fender realignment and texturing
  9. Calico "explodey the side step" ez removal kit
  10. Stock Rubicon rails courtesy of JackTuttle (Thanks Jack!)
  11. Solid Axle dif covers
RiggerMike is offline
post #4 of 21 Old 07-28-2009, 08:20 AM
Alec W
Guest
Posts: n/a
37 Kevlar MT/Rs measured 36.5 inches (vertically) on my JK aired up to 30 PSI and loaded when they were new.
post #5 of 21 Old 07-28-2009, 02:13 PM
TrailDuty.com
PhilD's Avatar
Going from memory this is what the tires on the JK measured when new:
40" MTR/K = 39.25"
37" KM2 = 35.5"
36" IROK = 34.5"
PhilD is offline
post #6 of 21 Old 07-28-2009, 08:10 PM Thread Starter
lbh
lbh's Avatar
Anybody have input on the Toyo's?
2007 JK
lbh is offline
post #7 of 21 Old 07-28-2009, 10:43 PM
blownJK's Avatar
overpriced...like so many
and as far as "true size"....i know 37's measure to around 34-35"'s
Like us on
blownJK is offline
post #8 of 21 Old 07-28-2009, 11:07 PM
Hot Duck's Avatar
I have 37" Toyos on both my JK and my dually and they measure a full 37" on both trucks. However, we are running 35" Toyos on my wife's Suburban, but they only measure 34 inches tall. Go figure.
Hot Duck is offline
post #9 of 21 Old 07-29-2009, 07:08 AM
TrailDuty.com
PhilD's Avatar
I ran 38" Toyo's in the past and they measured 36.25", and i know they were bigger than the Toyo 37's.
You have to remember that rim width makes quite a difference to the measured height. Look at most of the manufacturers measured heights and you'll notice that they are generally on rims at the wide end of the width range.
PhilD is offline
post #10 of 21 Old 07-29-2009, 08:17 AM
93country's Avatar
40" MTR/K = 39.25"
37" KM2 = 35.5"
36" IROK = 34.5"
My 36" iroks are 35.5" (from the ground to the top of the tire)with 24psi in them and an empty jeep, and probably 50% tread left.
93country is offline
post #11 of 21 Old 07-29-2009, 08:37 AM
Prope's Avatar
I'll 2nd that measurement! They even looked much bigger than my 37" BFG M/T KMs did side by side.
'08 Unlimited Sahara - Hemi -
Fenders & Rockers -
Prope is offline
post #12 of 21 Old 07-29-2009, 01:57 PM
TrailDuty.com
PhilD's Avatar
Mine were never close to that on 9" wide rims.
PhilD is offline
post #13 of 21 Old 07-29-2009, 01:58 PM
TrailDuty.com
PhilD's Avatar
The MTR/K's are the closest to advertised size tires I've seen.
PhilD is offline
post #14 of 21 Old 07-29-2009, 03:15 PM
jeepdaddy's Avatar
X2 !
12 Rubi - Dozher - wifes jeep
04 LJ - nameless to protect the guilty - my jeep
14 Raptor - daily/tow rig
jeepdaddy is offline
post #15 of 21 Old 07-29-2009, 10:31 PM
levellinebrad's Avatar
when new my 315/75 r16 km2's measured 34.8" which was the advertised height. mine were mounted on 16x8's. I had heard that the wider the wheel, the shorter the actual tire height. Is this true or not?
levellinebrad is offline
post #16 of 21 Old 07-29-2009, 10:37 PM
Big A's Avatar
40" MTR/K = 39.25"
37" KM2 = 35.5"
36" IROK = 34.5"
36" IROKS are 36.5
Phase 1 Complete. Sold JK
Big A is offline
post #17 of 21 Old 07-29-2009, 10:53 PM
StubEXrube's Avatar
True in theory. The wider the wheel, the more that the tire is being "stretched" out. The narrower the wheel, the more "compressed" the sidewalls become, allowing them to gain a little more height. However.....between a 1" difference in wheel width, I doubt there is much noticeable difference in tire height.
StubEXrube is offline
post #18 of 21 Old 07-29-2009, 11:05 PM
cool info, thanks
post #19 of 21 Old 07-30-2009, 08:11 AM
TrailDuty.com
PhilD's Avatar
There will be an optimal rim width where the tire is at it's tallest, going wider or lower will reduce the tire height. Some tires will bow in the tread section when on narrow rim, causing a little increase in height, but this is unwanted height as it is only in the center of the tread.
If you look at the measured heights published by the manufacturers you will see that they are usually on the a rim at the wide end of the recommend rim width range, especially on larger sizes.
PhilD is offline
post #20 of 21 Old 07-30-2009, 08:52 AM
Since my wife is driving the Jeep, I will see if I can get home early enough to measure the 37" BFG's we have. Or you can measure them saturday if we go to hungry valley, That might be the next time I even get to see the jeep myself....haha
Ironworks is offline
post #21 of 21 Old 07-30-2009, 09:50 AM
Wrangling Steel's Avatar
GoodYear Wrangler Mtr/Kevlar 35x12.50x15" on my 15x8" wheels measured 34.25" with 35lbs. and 34" even with 27lbs of pressure when new.
It is probably a safe bet that they do measure the advertised 34.8" when off from the vehicle. And according to the GY website that is 34.8" on a 10" wheel at 35psi.
"Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it." -Ronald Reagan-
Wrangling Steel is offline
