WELDERS BE CAUTIOUS!!! PLEASE READ - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 07-26-2009, 11:13 PM Thread Starter
07unlimitedx's Avatar
I picked this up on another site.
http://i32.tinypic.com/x2thl3.jpg
07unlimitedx is offline
post #2 of 7 Old 07-26-2009, 11:24 PM
Mr.RonGilbert's Avatar
Damn.....
Give me a few and I will find the MSDS for the brake cleaner.
Mr.RonGilbert is offline
post #3 of 7 Old 07-26-2009, 11:28 PM
MSDS
http://www.gunk.com/msds/M720.pdf
Cliffs Notes:
X. Stability and Reactivity:
Open flames, hot glowing surfaces. Liquid oxygen or other strong oxidants can form explosive mixtures of perchloroethylene
Incompatibility (Materials to Avoid):
In the presence of water: hydrochloric acid. Ignition sources and hot metals surfaces: phosgene and chlorine. Flames, welding,
and high temperatures induce decomposition.
post #4 of 7 Old 07-27-2009, 12:38 AM
venom's Avatar
Damn!
Duly noted - thanks for passing along the warning!
I'm horrible about not making sure metal is perfectly clean/dry before I weld it, guess i'll be a little more careful from now on!
I was working in a 3500 gallon display tank at the zoo, we had just drained it and were changing out the 12" deep gravel bed. The guy I was working with and myself kept getting dizzy and headachy after being down in the tank for more than about 10 minutes, last time down I could barely climb the rock work to get back out.
Then it occurred to me, the reason we were changing out the substrate was I had diagnosed that the original tank design was flawed and it had built up deposits of hydrogen sulfide gas in the gravel, a big rock shifted and released enough into the water to kill all of the fish. Then I remembered hydrogen sulfide gas is heavier than air and realized we were down in a big tank of it breathing it.
DUH, felt pretty dumb, added a few fans, waited a couple of hours and every thing was fine, but if we had passed out down there like we almost did, it coulda been a different situation.
poisonous gasses are just a tiny mistake away everywhere we go!
Originally Posted by My Wife
venom is offline
post #5 of 7 Old 07-27-2009, 07:43 AM
jacktuttle's Avatar
Here is a substance that is more danagerous.....
http://chemsoc.velp.info/msds-woman.html
Be very careful handling this.....
jacktuttle is offline
post #6 of 7 Old 07-27-2009, 01:53 PM
TrailDuty.com
PhilD's Avatar
Tetrachloroethylene is very toxic, the short term exposure limit is 100 PPM. I try to keep clear of brake cleaner altogether. If inhaled, phosgene produces hydrogen chloride in the lungs, very nasty. You should never weld near any chlorinated solvent.
I generally don't use anything on areas to be welded, apart from a grinder/sander/etc, but it is a very good reminder how dangerous some of these chemicals can be.
PhilD is offline
post #7 of 7 Old 07-27-2009, 03:41 PM
jrph's Avatar
Any type of CHLORIDE in the lungs can turn to fluid.
jrph is offline
