dropping gas tank? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 07-23-2009, 08:07 PM Thread Starter
BeerMonkeY's Avatar
dropping gas tank?
anybody drop the tank to get the skid off? i need to beat mine straight again and after messing with it a bit today i realize i need to remove it completly but dont want to get in over my head with the tank.
'92 YJ
'13 WK2
BeerMonkeY is offline
post #2 of 13 Old 07-23-2009, 08:12 PM
bodyguy's Avatar
https://www.jkowners.com/forum/showthread.php?t=11628
This should help
Scroll down in the thread I listed what needs to be removed and posted pictures in the last post
bodyguy is offline
post #3 of 13 Old 07-23-2009, 08:30 PM
kerryp's Avatar
This should help
LOL, listen to him, he should know....dju ever get another skid or just go back with the original?
ジープ
@CigarsNJeeps
kerryp is offline
post #4 of 13 Old 07-23-2009, 08:34 PM Thread Starter
BeerMonkeY's Avatar
thanks. was there enough slack on all those to drop it a little to get them un hooked/re hooked?
'92 YJ
'13 WK2
post #5 of 13 Old 07-23-2009, 08:35 PM
bodyguy's Avatar
You can disconnect everything before you even remove a single bolt.
bodyguy is offline
post #6 of 13 Old 07-23-2009, 08:38 PM
bodyguy's Avatar
I put the old one back on after I straightened it, I'm not sure what I am going to.
bodyguy is offline
post #7 of 13 Old 07-23-2009, 09:00 PM
jeepersheart's Avatar
not to hi-jack the thread here but would it possible to unbolt, leave everything connected and just slide the skid out without disconnecting the tank. I know you would have to have something to support the tank but Im thinkin a pair of jack stands with a little peice of plywood over hem could hold that tank up and save a lot of time.
jeepersheart is offline
post #8 of 13 Old 07-24-2009, 04:56 AM Thread Starter
BeerMonkeY's Avatar
i dont think you could. the way the skid is you wouldnt be able to get it out of thw way to get jackstands in there
'92 YJ
'13 WK2
post #9 of 13 Old 07-24-2009, 04:56 AM
bodyguy's Avatar
You would waste more time trying to separate the two while in the jeep. The gas tank does not fit loosely in the skid you have to force it out and back in. I wouldn't consider that a hijack that's a good question.
bodyguy is offline
post #10 of 13 Old 07-24-2009, 11:07 AM
cool thanx for the info, I guess I will be waiting till I am ready to replace it then I have a tendency to make even small jobs a big ordeal.
post #11 of 13 Old 07-24-2009, 03:37 PM
thecarters91303's Avatar
Having taken a gas tank out in my Mustang once I will suggest that you drain it as much as possible. The tank and skid will be heavy enough without the extra weight of the gas.
thecarters91303 is offline
post #12 of 13 Old 07-27-2009, 01:55 PM
Wrangling Steel's Avatar
Let's just say I could tell a funny story about dropping the fuel tank skid to clean out the rocks and other debris that had accumulated. There is a reason why the first three letters in the word assume are there, and why you should never “assume” the fuel tank is mounted separately from the skid plate… I highly recommend that you do not have a full tank of fuel when decide to quickly drop the skid plate to clean out the said debris; don’t ask how I know this!
I must say, I am thankful I had my 17yr old son outside at the time, or I might still be lying underneath the Jeep, with a stunned stupid look on my face… I never imagined the only thing holding the tank in place was the skid, wrong!
"Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it." -Ronald Reagan-
Wrangling Steel is offline
post #13 of 13 Old 07-28-2009, 12:42 AM
blownJK's Avatar
HEY!....make sure it's mostly empty ....don't ask
Like us on
blownJK is offline
