09 with what sounded like throwout bearing squeal??? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 07-13-2009, 02:50 PM Thread Starter
09JK's Avatar
Just got back from a trip to Colo springs. After the 8 hour drive out I parked the Heep and went sight seeing for a bit. When i came back and fired it up I noticed a chirp every now and then. popped the hood and looked around figuring it was the belt but it seemed more to come from bellhousing area. Also after taking off I noticed a rough pedal feel while pushing the clutch in and out. And possibly but may be in my head a rough clutch ingagement. Well I spent three days with some easy wheeling (didn wanna burn it up 8hrs from home) , sight seeing and the 8 hr drive back home I have no more chirping or rough pedal in and out ????? What da ya think the beginnings of bearing failure or possibly it has finally broken in,,,just hitting 6k miles ?????
09 JKX 2in Old Man Emu lift and shocks, Teraflex 1in front spacers,35x16 Toyo Open Country M/T,16x8 eagle alloys,Raingler handles,XRC front and rear bumpers with carrier,Warn M8000 winch,6 in KC Slimlites,modified Rubi sliders. BROKE for now
09JK is offline
post #2 of 4 Old 07-13-2009, 03:08 PM
MaRShiN's Avatar
There is a TSB and I had the same symptoms that you're having, but IIRC the TSB was for JK's built before like March2008 or something. Either way it MAY be covered under the factory 2year/20,000mile warranty.
If you ahve a mod/warranty friendly dealership within reach Id take it there. Also mine made a creaking sound when the clutch was pressed in, and the rattle if the pedal was all the way out that went away with slight pressure on the pedal. I had the service guy come out and listen to it while I was there so there was no chance of the "could not duplicate the problem" BS.
nah nah nah nah nah nah, I made you eat your parents - E.Cartman
MaRShiN is offline
post #3 of 4 Old 07-14-2009, 06:46 PM
johnmcd's Avatar
I have the same creeky door sound both in and out, it happens with or without engagement ( engine off in drive way or at red light out of gear).
I have a service appointment at a friendly dealership for that and teh hood latches, i will post up the outcome.
Originally Posted by H.I.I.K View Post
Ok We need to organize a "Strippers and Blow Trail Run" It can raise money for college scholarships
Raleigh Meet and Greet,
Check the thread ------------->
johnmcd is offline
post #4 of 4 Old 07-14-2009, 06:59 PM Thread Starter
09JK's Avatar
AHHA i was under the impression it was a problem only on 07 and early 08 's....And mine has cleared up but i know will come back, and also happened in and out..
09JK is offline
