measurements - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 05-29-2009, 06:46 PM Thread Starter
measurements
if a wheel measures 17x9 5x5 -6mm whats the backspacing? how do you figure it out?
jchmelo is offline
post #2 of 16 Old 05-29-2009, 06:51 PM
bodyguy's Avatar
Set the wheel down on its face lay a straight edge across the opening and measure to the mounting surface.
bodyguy is offline
post #3 of 16 Old 05-29-2009, 06:52 PM
doc307's Avatar
If I remember correctly this would be about 4.7" backspacing
2014 Rubi Unlimited
2008 2dr X SOLD
with some chit on it
doc307 is offline
post #4 of 16 Old 05-29-2009, 06:57 PM
here is a post I made in another thread. Just replace with your measurments
Originally Posted by WTF_LOL View Post
Just thought of something. Wheel width is measured from the bead seats not the lip. They are generally .5" so you would have to add that to the equation.
Seems so stupid to me to have the two different formats
I also did the math wrong earlier as I did it with positive offset
First convert metric offset to inches:
-19mm / 25.4= -.748"
Add the width of the lips to the advertised width of wheel (wheel width is measured from bead seat to bead seat, we need the width from lip to lip. Usually about .5" so add an inch) then, divide by two as we need to nknwo what half the real wheel width is:
(8" + 1") / 2 = 4.5"
half wheel width + the offset that has been converted to metric
4.5" + -.748" = 3.75"
WTF_LOL is offline
post #5 of 16 Old 05-29-2009, 06:57 PM
doc307's Avatar
To get backspacing you take the mid point of the wheel, in your case is 4.5".
You then have "-6mm" which tells you the wheel extends out (the -). So you add 6mm to the 4.5". to convert mm to inches divide 6 by 25 which is almost .25".
4.5" + .25" = 4.75" backspacing.
2014 Rubi Unlimited
2008 2dr X SOLD
doc307 is offline
post #6 of 16 Old 05-29-2009, 07:00 PM
yep, thats what I get also 4.763779527559055118110236220473
WTF_LOL is offline
post #7 of 16 Old 05-29-2009, 07:36 PM
Comfortably Numb
RubiCajun's Avatar
Wow, for measurements like that you may want to use the new
Tape that Stanley just came out with.
RubiCajun is offline
post #8 of 16 Old 05-29-2009, 07:49 PM Thread Starter
so then what is the stock bs of an 07 rubi? and will these wheels fit ?
jchmelo is offline
post #9 of 16 Old 05-29-2009, 07:54 PM
what size of tire do you want to run?
WTF_LOL is offline
post #10 of 16 Old 05-29-2009, 07:56 PM Thread Starter
stock tires so 32's isn't the stock wheel size of the 07 rubi 17x9? and so a bs of 4.53 would be good correct?
jchmelo is offline
post #11 of 16 Old 05-29-2009, 08:07 PM
you would have plenty of clearance for 32's at 4.75" as I belive stock is right about 6". In otherwords, these will stick out 1.25" further then stock
WTF_LOL is offline
post #12 of 16 Old 05-30-2009, 04:53 AM Thread Starter
ok thank you very much now i jus have to decide what ones i want thank you again!!
jchmelo is offline
post #13 of 16 Old 05-30-2009, 05:17 AM
jeeperjkj's Avatar
You gonna put a 255 width tire on a 9" wide wheel?
That's gonna look kinda funny, I'd think.
jeeperjkj is offline
post #14 of 16 Old 05-30-2009, 06:29 AM
doc307's Avatar
Not sure what wheel the OP is looking at but I ran the 255's on a 17x9 wheel until I upgraded to 35's. Did not look too funny.
2014 Rubi Unlimited
2008 2dr X SOLD
doc307 is offline
post #15 of 16 Old 05-30-2009, 10:21 AM Thread Starter
then should i think about running something like a 17x8 or what?
jchmelo is offline
post #16 of 16 Old 05-30-2009, 12:03 PM
doc307's Avatar
Look at my post above and judge for yourself. Those wheels are 17x9.
I think the 255's looked good on them.
2014 Rubi Unlimited
2008 2dr X SOLD
doc307 is offline
