Clutch squeek - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 05-28-2009, 07:38 AM Thread Starter
Duffy's Avatar
Clutch squeek
I'm taking the Jeep in to have a tire rotation and to have them stop the clutch squeek. I do believe mine falls under the TSB to replace the disc.
Anyone have theirs done under the TSB? Should I expect to be covered under warantee, or will I be expected to fork out some cash?
Thanks,
Duffy
Duffy is offline
post #2 of 11 Old 05-28-2009, 07:43 AM
H8T2W8T's Avatar
I had my clutch worked on twice under the TSB. The way I understood it was that because it is a TSB and not a recall, the dealership had the choice to not cover it under warranty. Mine was, but that was the way I understood it. I was sweating the cost, but if it was too much (turned out to be free/covered) I was planning on doing it myself. Print out a TSB and take it in with you. I've done that for all my work and I get zero questions.
Good Luck
BIG RED JEEP
H8T2W8T is offline
post #3 of 11 Old 05-28-2009, 09:28 AM
MaRShiN's Avatar
x2. I went to a good reputable dealer that is lift/mod friendly and brought the printed out TSB. They did the clutch TSB for free along with a few other things. I just made sure when I showed up that I got one of the techs out there with me so there would be no "cannot duplicate prblem" thing.
nah nah nah nah nah nah, I made you eat your parents - E.Cartman
MaRShiN is offline
post #4 of 11 Old 05-28-2009, 09:33 AM
Wrangling Steel's Avatar
I had the throwout bearing, and disc tsb done at 24k. No questions asked...
Wrangling Steel is offline
post #5 of 11 Old 05-28-2009, 11:42 AM
MaRShiN's Avatar
My dealer told me (might have been BS) that one superseeded the other.
MaRShiN is offline
post #6 of 11 Old 05-29-2009, 06:35 AM Thread Starter
Duffy's Avatar
Thanks guys.
I printed the TSB and gave it to them. They said they have to order the assembly and will do it next week at no charge. Even gave me a print out that said so. YAY.
I asked if they wanted me to demonstrate the squeek and they said "No, we've had to replace a lot of those. That's why we have to order more parts".
So, I just had the tires rotated and will bring it back next week.
It's my first time using these guys. So far, so good.
Cheers,
Duffy
Duffy is offline
post #7 of 11 Old 05-29-2009, 01:29 PM
Otnoc311's Avatar
Where can I find the TSB to print out and does it only cover certain years? I have an 08' with the clutch squeek.
aka- Brian
08' JKU on 38's... parted out and SOLD
13' JKU Rubi... On HOLD, 04' LJ to suppliment
Rise and Rise Again Until Lambs Become Lions
Otnoc311 is offline
post #8 of 11 Old 05-29-2009, 01:36 PM
SASQUATCH's Avatar
Thanks,
Duffy
It should, mine has been replaced 3 times, second time was their brand new improved clutch/disk assembly, 3rd time, just another throwout bearing. This last time Allen Samuels told me Chrysler has red-flagged my Jeep (hoping that would startle me), but it had a reverse affect and I was told "please just know that at anytime you have anymore problems with your clutch we'll take care of you, even if we have to sit down together and call Chrysler and explain the issue". If I'm under warranty they are going to fix it....unless I'm over the legal limit of mods
SASQUATCH is offline
post #9 of 11 Old 05-29-2009, 01:37 PM
MaRShiN's Avatar
depends on your build date if it applies to your 08. Mine was in just under the wire with a build date in Feb08. The dealer can tell by your VIN. I didnt bring in the whole TSB, just the TSB numbers. Here are the 2 I brought in;
06-004-07
06-001-08
MaRShiN is offline
post #10 of 11 Old 05-29-2009, 04:02 PM
Otnoc311's Avatar
Thanks for the input... Just got home from the dealership and I found out my JK was built Nov 07'. They had not heard of the TSB but after looking it up they were good about it. I asked them up front that if I had any mud underneath, would it be a problem... luckily the service guy has a JK and told me to get under it with a powerwasher good and I shouldn't have any issues. It goes in on Thursday to get the new clutch disc so hopefully it works.
aka- Brian
Otnoc311 is offline
post #11 of 11 Old 06-01-2009, 11:53 AM
Question Clutch Squeel
What if you have a skid plate underneath, would the dealer require you to remove it? I wouldn't want to get charged for labor to remove add-on equipment !
2008 Jeep Wrangler Unlimited X in RESCUE GREEN!!
pacphnmn is offline
