TJ Help? Removing fan and clutch assembly - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 09-21-2010, 08:50 PM Thread Starter
upalms's Avatar
I posted this on a TJ forum, but no reply yet, and I'm usually here so I thought someone could help.
I did this a while ago on our TJ, but I'm helping a buddy replace a water pump and forget the trick to getting the fan and clutch assembly off, I've seen different designs, this one has the shaft betreen the pump & pully and the fan/clutch that takes like an 1 1/4 wrench, but spins. How do you break it loose?
THanks!
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
Synergy Front Suspension
Artec Front JK Armor
5:13's
Tom Woods Drive Shafts
Hi-Lift & Much More
2000 TJ
6" lift
37 TOYO MT's on Worx Rims
$hitty Built bumpers
Air Raid
Corbeau Baja RS seats
upalms is offline
post #2 of 3 Old 09-21-2010, 08:53 PM Thread Starter
upalms's Avatar
Man it's midnight, I posted this in the wrong place.
Sorry
Just let it Die...
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
5:13's
Hi-Lift & Much More
2000 TJ
6" lift
Air Raid
upalms is offline
post #3 of 3 Old 09-21-2010, 08:56 PM
Trail Concepts Hmfic
jdemonto's Avatar
Sorry
Just let it Die...
Well I own a TJ so your in luck! You need to hold down the 13mm bolts while spinning counter clock wise to keep the clutch from moving.
Jason
602-314-5356 or
jdemonto is offline
