Hump 'N Bump 2010. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 08-11-2010, 11:07 AM Thread Starter
Liquor's Avatar
Hump 'N Bump 2010.
http://www.vv4w.org/humpnbump.asp
When is Hump N Bump?
The 30th Annual Hump N Bump will take place November 5th and 6th 2010.
Where does the Hump N Bump take place?
Most of the trail rides are around Logandale, NV. The "Base Camp" is located at the Logandale Fairgrounds just up Whipple Road. It is about 1 mile from where the trail heads of most of the trails are located. Logandale, NV is about 60 miles east of Las Vegas on I-15.
The Trails!
The following trails will be ran this year:
Arockalpse - Extreme trail with a gigantic boulder at the beginning. This trail is rated 4 and should not be attempted unless you have 35"+ tires, 2 lockers and do not care what you vehicle looks like!
Bowl Trail - Perfect trail for those with stock to lightly modified vehicles. The trail winds through the desert through some very scenic parts of the Logandale area. There are a few obsitcles for those of you adventurous types but all are optional. At the very end of the run you can really test your driving skills and attempt the S-TURN. Though it is optional we suggest lockers front and rear and there is a possibility for some body damage. Full size not recommended in the S-Turn and are guaranteed body damage.
Bronco Falls - A short trail named after the one biggest obsticles in the trail, a huge vertical climb up a rock wall. Though it looks more intimidating then it is difficult a good set of tires and some low gears will get you to the top. After this short section the group will continue on around and catch the Shedder Trail.
Hawkins Trail - Scenic trail that takes you through the mountains to the valley adjacent to the Logandale Valley. This is the connector trail for many other trails such as Matterhorn, Arockalypse and The Bowl trail. So if your looking for a scenic easier trail take the Hawkins Trail.
Matterhorn - Rated probubly a 2 this trail is good for those slightly modified vehicles. Scenic ride through the Logandale hills to some mild obsticles. Great optional off camber climb just before a large climb that puts you back in the launch postition.
Rock Bottom - This is a great trail for those looking for a challenge. Rated a 3+ this trail will test your rig. The entrance to the trail is a V notch that you tip toe through. From there you crawl some sand stone obsticles along the way until you end up in a canyon with 4 ways out. The easiest is rated a 2 or 3 the hardest put mosts on there roof! As the trail comes to an end you have two ways to exit the trail: the S turn near the end of the trail where your powersteering, gearing and brake control abilities get a major workout or the waterfall which is pretty steep flat rock wall decent. After the trail have some fun at the sand dunes and back to base camp. Trail will take about half the day with a large group so bring snacks and plenty of water.
Shedder Trail - This trail will challenge the stock the vehicle but still have excitement for those modified rigs with some optional obsticles. This trail is also close to base camp and is famous for unofficial night runs. Rated about a 2-3 depending on the optional obsticles.
anyone interested in going? If "CAIN" is finished, i will be attenting. I have a lot of buddies in Vegas that are looking forward to it.
• Your Jeep and Gaming Social Network
2012 Sponsors:
Magazine Feature:
Liquor is offline
post #2 of 2 Old 11-04-2010, 02:33 PM
PUDDLZ's Avatar
We are in
PUDDLZ is offline
