AR Build recommendations - JKowners.com : Jeep Wrangler JK Forum
post #1 of 22 Old 03-09-2015, 10:08 PM Thread Starter
jrider's Avatar
So I've had a Bushmaster ORC for a while now and after putting a new Volquartsen trigger in my 10/22 I decided I don't like my AR trigger so I started looking at upgrading the trigger in it. And then started thinking of replacing the handguard to a quadrail, and going with a different stock etc.
Now I'm starting to wonder if I might be better off doing something I've wanted to do for a long time and just build one the way I want. Unfortunately, I really don't know much about it and I have to do it on a budget.
Here are the things that I know I want. Magpul ACS stock, free float quadrail, 5-6lb trigger (I swear mine is around 12lb) carbine or mid length barrel, flat top.
Can I get end up better off for around $1000 or should I just upgrade what I have?
Any feed back is appreciated.
2007 Rubi Unlimited. Teraflex 2.5 lift + Fox shocks, Nitto Trail Grappler 35s on XD Addicts, 5.38s, Ten Factory rear shafts, Riddler diff covers, Purejeep front axle truss and Teraflex gussets, Tatton front driveline, Rugged Ridge Modular front bumper with XRC8 Comp winch, Superchips programmer, Volant intake, MBRP exhaust, Hella H4 headlight conversion, Body Armor "not so Extreme" Rock Rails, in-cab winch control,Best Top Trek Top.-Sold
jrider is offline
post #2 of 22 Old 03-10-2015, 07:05 AM
2k2wranglerx's Avatar
https://www.hardenedarms.com/ecProduct_233
best bang for buck upper out there imho
PSA had their magpul MOE complete lower for sale for 159. I just looked and they're out of stock now. But regardless, you can still build the lower fairly inexpensively and leave plenty of $ for a gisele or similar trigger.
they have this complete lower still in stock. since it's cheap enough you could just swap the stock and grip and trigger to what you want...
or buy a stripped lower.
http://palmettostatearmory.com/index...category/4282/
but that basically gets you an entire AR with quality parts (other than the junk grip/stock which you're going to change anyway) for around 500 bucks
2k2wranglerx is offline
post #3 of 22 Old 03-10-2015, 07:25 AM
Hartj17's Avatar
I would agree with the above statement. You can build an AR with very little knowledge at all. Remember that there are a ton of forums just like this one that are dedicated to just that type of thing.
I went the other route though. I went with a CMC 4lb trigger on a 20 inch barrel. However I went a different route than the traditional .223/5.56 and ended up going with a 6.5mm grendel. To each their own right?
Other quesitons to consider would be what are you wanting to do with this AR? Just like Jeeps suspensions, the question is really loaded with all kinds of sub-questions.
1. Is it just for paper?
2. Are you looking to put on a scope?
3. Do you want this for hunting?
4. What type of MOA are you trying to achieve?
Hartj17 is offline
post #4 of 22 Old 03-10-2015, 08:29 AM
ya, i'm fine with the standard PSA trigger that came in my build kit lol.
like stated above, use is what dictates how you build it. If you're looking for accuracy then look at the barrel length to velocity tables.
I have a pretty standard built AR with a 16" barrel and the gun is more accurate than i am. I was shooting at 150 yards over the weekend with the red dot and the dot was as big as the target. i think its a 3 moa dot? i can't remember which one i have.
anyway, what do you want to do with it?
post #5 of 22 Old 03-10-2015, 08:30 AM
I'm all for going fancy billet too... but you're usually looking at around 1600 bucks for a nice build (once you do the stripped billet upper/lowers, nice barrel, nice quad rail, nice trigger etc.
post #6 of 22 Old 03-10-2015, 10:17 AM Thread Starter
jrider's Avatar
Great info guys! I will mostly be punching paper out a little ways, random stuff in the desert and some whistle pigs. I have a Holosight but ended up taking it off and putting a 3-9 on it for small stuff further out.
I just had a second, I'll look closer at those recommendations when I get more time this evening.
Thanks!
jrider is offline
post #7 of 22 Old 03-10-2015, 10:52 AM
https://www.hardenedarms.com/ecProduct_278
18" might be the way to go then.
This doesn't come with the BCG or CH but i love the fluted stainless barrel
https://www.hardenedarms.com/ecProduct_259_27
post #8 of 22 Old 03-11-2015, 07:56 AM Thread Starter
jrider's Avatar
This "out of stock" shit is irritating.
jrider is offline
post #9 of 22 Old 03-11-2015, 09:29 AM
what's OOS that you're looking for?
when stuff is a good deal it pretty much flies off the shelf.
you've gotta be watching.
post #10 of 22 Old 03-11-2015, 10:27 AM Thread Starter
jrider's Avatar
First thing this morning the upper you linked me to came up OOS and then showed up again as available. Not sure if I brought up wrong one or what. The other OOS stuff is trying to find the lower build kits with the stock and trigger combo I want.
I found a Rock River 2 stage trigger and build kit for $150 so I think I will go that route and order lower, buffer kit and stock separately. Is that all I will need for the lower? Buffer kits seem to vary in price a bunch, anything I need to know about them?
https://www.primaryarms.com/RRA_Lowe...p/ar0120nm.htm
jrider is offline
post #11 of 22 Old 03-11-2015, 11:53 AM
that looks like all you need to assemble the lower... kinda pricey though... then again, i don't know anything about that trigger.
http://www.righttobear.com/Geissele-...-p/ssa-lpk.htm
i was kinda eyeing those
or if you already have a lower and standard LPK
http://www.copesdistributing.com/gei...er-p-8247.html
you could do that built lower for 129 with that drop in geissele...
just tossing out ideas
post #12 of 22 Old 03-11-2015, 11:54 AM
you know about this place right?
http://www.slickguns.com/ar-deals
post #13 of 22 Old 03-11-2015, 06:22 PM
WarMachine's Avatar
That's a good price on a Geissele drop in! I'm glad I looked into this thread.
Thanks 2k2wranglerx !
I gotta be me cause everyone else was already taken.
WarMachine is offline
post #14 of 22 Old 03-11-2015, 09:55 PM Thread Starter
jrider's Avatar
No, I didn't. Now I have another way of killing time!
Just scored a Spikes T2 buffer assembly on local CL for a smokin deal!
jrider is offline
post #15 of 22 Old 03-12-2015, 10:43 AM
SEVN62's Avatar
I have a few Geissele triggers and they are worth every penny. Primary Arms occasionally runs a 15 percent off sale which can help with the cost.
My favorite places for AR parts and accessories are :
AIM Surplus
Bravo Company USA
LaRue Tactical
Rainier Arms
The great things about ARs is you can go mild or extremely wild.
SEVN62 is offline
post #16 of 22 Old 03-12-2015, 04:25 PM
Here's the one I built.
psa 1:7 chrome lined upper. Psa lower with standard build.
Magpul stuff. LaRue rat stock.
It has a vortex sparc ii but I should have just spent a little more on another aimpoint.
post #17 of 22 Old 03-12-2015, 06:45 PM
build
Your best bet money wise is going to be a BCM upper on the lower or your choice. I tend to use Noveske. You can drive it like you stole it without problems. A ALG trigger is good for a first build, but I recommend geissele sd-c series.
I do understand wanting to build your own, but once you do it, you just go wow that's easy. If you decide to buy parts, at least get a bolt that is headspaced to your barrel. This is where you will find accuracy. I am also on the keymod wagon, I think they are great.
Lastly, if you build it all yourself, buy the reaction rod, this is much better than anything else on the market. I threw all the other blocks away after I got it.
I used to have quite a few AR's, but most of that was building during the binge last year. Currently I run KAC, which is the best imho, but its store bought and not a build your own.
Feel free to pm me if you need some parts, I have some laying around. also I have a Noveske keymod rails I can give you a deal on.
[IMG][/IMG]
[IMG][/IMG]
Wilson1911 is offline
post #18 of 22 Old 03-13-2015, 09:20 AM Thread Starter
jrider's Avatar
This is ridiculous! I haven't even received my parts I ordered online but I'm already looking at getting stuff for my next build.
Thanks for the info and help everyone. I'll be sure to post pics when I get #1 complete.
jrider is offline
post #19 of 22 Old 03-13-2015, 10:04 AM
the tops one is the pistol i built with the hardened arms upper.
post #20 of 22 Old 03-13-2015, 07:30 PM
Hartj17's Avatar
For Sparty
Hartj17 is offline
post #21 of 22 Old 03-13-2015, 08:55 PM
http://palmettostatearmory.com/index...view/id/15072/
Magpul moe built lower for 159
post #22 of 22 Old 04-06-2015, 08:47 AM Thread Starter
jrider's Avatar
One Piece at a Time!
Finally got everything and now I just got to get some time to work on building it.
jrider is offline
