Gen V engine identification - JKowners.com : Jeep Wrangler JK Forum
 7Likes
  • 1 Post By Mason
  • 1 Post By Conquistador
  • 1 Post By rockystock
  • 1 Post By 0lllllll0 RPMEXTREME
post #1 of 17 Old 05-12-2019, 01:34 PM Thread Starter
cody48's Avatar
Can anyone help identify or point me into the right direction to identify the year model of the powertrain I just picked up? All the scrounging I've been doing all references the vehicle VIN number and/or RPO codes, both of which I do not have...
I obviously know it's an L86 and 8l90, but looking for year of manufacture.
cody48 is offline
post #2 of 17 Old 05-12-2019, 03:38 PM
Trans controller says t87, that tells me that it’s pre 2017. I see the number 15 a lot in your pictures. I suspect it’s a 2015.
Conquistador is offline
post #3 of 17 Old 05-12-2019, 06:39 PM Thread Starter
cody48's Avatar
Originally Posted by Conquistador View Post
Trans controller says t87, that tells me that itís pre 2017. I see the number 15 a lot in your pictures. I suspect itís a 2015.
If this is indeed a 2015, are there any problems associated that I would need to be concerned with or is it just software related problems that could be easily fixed?
cody48 is offline
post #4 of 17 Old 05-12-2019, 09:14 PM
08JKUR33's Avatar
Is that not the vin here on the block? Name:  103448B8-6F1D-4123-ADA4-EE84BC3F6E40_1557717274723.jpeg
08 Jk Unlimited Rubicon
Link to build page-
08JKUR33 is offline
post #5 of 17 Old 05-12-2019, 09:26 PM
Mason's Avatar
Originally Posted by 08JKUR33 View Post
Is that not the vin here on the block? Attachment 336996
Looks like it starts with the letter G, and not a number, so it isnít a vehicle VIN.
Iím assuming that the OP knows that the L86 was made from 2014-2018. Other than that I have no clue, but I do have a job interview at a GM dealer tomorrow so if I get the job and no one else has solved the mystery by then I may be able to look it up.
cody48 likes this.
Mason is offline
post #6 of 17 Old 05-13-2019, 11:06 AM
2015 would be my year of choice. Only trouble may he transmission which should be corrected with updated trans fluid and programming.
post #7 of 17 Old 05-13-2019, 11:32 AM
Here’s mine which is a 2016. Yours looks to be numerically lower.
cody48 likes this.
post #8 of 17 Old 05-13-2019, 11:47 AM
Also look at the transmission. There will be a sticker with 4 large numbers/letters. The first one will give you a build year. Mine is a 5, but it is a 2016 model.
cody48 likes this.
post #9 of 17 Old 05-15-2019, 04:57 AM Thread Starter
cody48's Avatar
Mine starts with a 5, but the rest of the sticker is rubbed off.
cody48 is offline
post #10 of 17 Old 05-15-2019, 07:06 AM
I would bet you have a 2015 or early 2016 like mine.
post #11 of 17 Old 05-16-2019, 07:57 AM
rockystock's Avatar
GM probably has a helpline you could call or e-mail. I contacted FCA and got the full VIN and window sticker. Just told them I bought a used engine and wanted some info, gave them the engine serial # and partial VIN stamping from the block.
cody48 likes this.
rockystock is offline
post #12 of 17 Old 08-22-2019, 05:51 AM
Came across some VIN/engine block info. The circled part is from the VIN. The G means it’s a 2016.
cody48 likes this.
post #13 of 17 Old 09-04-2019, 03:23 PM Thread Starter
cody48's Avatar
Heck yeah, thank you buddy!
Got a link to this info you found?
cody48 is offline
post #14 of 17 Old 09-04-2019, 04:09 PM
I think I saw it in the “GM LT Gen V Swap and Mods” Facebook page.
The last 8 digits of the vin are etched into the block.
I can’t find that Facebook post now, but some quick googling turned up this: https://www.corvetteforum.com/forums...s-and-vin.html
The vehicle identification number (VIN) is located on the left side rear of the engine block (1) and is typically an 11 digit number stamped or laser-etched onto the engine at the vehicle assembly plant.
The first digit identifies the division.
The second digit identifies the model year.
The third digit identifies the assembly plant.
The fourth through eleventh digits are the last 8 digits of the VIN.
cody48 likes this.
post #15 of 17 Old 09-05-2019, 07:26 AM
0lllllll0 RPMEXTREME's Avatar
Look at the fuel rail pressure sensor at the rear of the fuel rail. If its a 4 wire sensor its a 2014-2016 engine.... if its a 3 wire sensor then its 2017 and up.
14-16 engines are basically the same and can be ran on 14-16 calibrations. 17+ have to be ran with 17+ calibrations. I have better luck with the 17+ engine calibrations, some of the early calibrations have issues especially the 2016 calibration.
You can swap out the fuel rail sensor on the early engines and make them run on a 2017 calibration as long as your harness is pined out correctly.
Stick with the 14-16 TCM calibrations as those TCMs do not need to be unlocked. You can run a early TCM behind a 2017 engine computer.
The TCM has to be programed to match the special number on the side of the transmission. best bet is use the TCM that came with the trans so you know it matches.
cody48 likes this.
post #16 of 17 Old 09-05-2019, 11:16 AM Thread Starter
cody48's Avatar
Wow, thanks guys!
cody48 is offline
post #17 of 17 Old 10-24-2019, 10:36 AM Thread Starter
cody48's Avatar
cody48 is offline
Similar Threads
Quadratec Stealth vs. Standard, Gen I vs. Gen II Quadratec, Inc. JK General Discussion 1 02-24-2017 09:40 AM
R.I.P.P. Gen 1 to Gen 2 conversion Q's jeeperpilot Modified JK Tech Dept. 0 01-01-2014 02:45 PM
RIPP gen 1 to gen 2 upgrade block Modified JK Tech Dept. 3 02-03-2011 09:58 AM
RR Gen 2 Snorkel NOW Gen 2.1 joePILE Modified JK Tech Dept. 14 11-02-2010 05:41 PM
upgrade that gen 1 river raider snorkel to a gen 2 tpafire5 Wanted 0 12-11-2009 02:33 AM
