3.6L Pentastar Standalone Harness - JKowners.com : Jeep Wrangler JK Forum
 2Likes
  • 1 Post By duster360
  • 1 Post By 0lllllll0 RPMEXTREME
post #1 of 7 Old 09-22-2018, 03:06 PM Thread Starter
0lllllll0 RPMEXTREME's Avatar
This is something we have been working on for a while and wanted to show it to you guys on JKO first.
We will be releasing a complete harness kit that will allow you to install a 3.6L Pentastar WA580 (NAG1) 4WD into an older vehicle or Jeep.
We had so many 3.6 pullouts sitting around from LS swaps that we needed to figure out a way to give them new life.
The first generation of the harness will be for any basic vehicle. It will have a basic hookup, power-ground-ignition-start etc....
The second generation will be designed to directly replace a 3.8L in a 2007-2011 Jeep JK and will be plug and play with the existing Jeep components. You will need a complete 3.6L - WA580 4WD pullout powertrain with the complete factory engine harness still attached as well as the ECU, TCM and shifter. If you dont have a ECU, TCM or Shifter we can provide them as needed.
RpmExtreme 3.6 Pentastar Standalone Harness :: RPM Extreme
Our harness will plug directly into the C1 connector of the factory computer and your 3.6 engine harness will plug into the C2.
Our harness will include:
Fuses and relays
OBD2 Port
Input and Output wires
CANBUS Module
Vehicle Speed Module
Fan Controls
Reverse Lamp Output
Stop Lamp Output
Fuel Pump Output
MIL Light Output
Bump Shift Control
Optional Options:
AC Control
Cruise Control
IPC Cluster Display Output
Vacuum Pump Control
Intercooler Pump Control
Transmission Fan Control
4WD Indicator Output
Oil Pressure Light Output
High Temp Warning Light Output
AUX Inputs and Outputs as requested
RACE PREP - KOH - BAJA - ROCK CRAWLING - ETC
Custom Vehicle Integration
post #2 of 7 Old 09-22-2018, 03:07 PM Thread Starter
SAVED FOR FUTURE UPDATES
post #3 of 7 Old 06-14-2019, 03:56 PM
Is this yet available?
cody48 likes this.
duster360 is offline
post #4 of 7 Old 12-12-2019, 02:09 PM
No it’s not, they say soon and it may be quite pricey
Nickwelds is offline
post #5 of 7 Old 12-12-2019, 04:40 PM Thread Starter
Originally Posted by Nickwelds View Post
No it's not, they say soon and it may be quite pricey
I wouldn't say it will be "pricey" if it works out the way I think it will the price will be reasonable.
post #6 of 7 Old 12-13-2019, 11:57 AM
Will Scarlet's Avatar
Do you plan on doing a 3.6L conversion for manuals?
2011 Sahara Tan Rubicon 6 Speed
TR HD17 Beadlocks, BFGoodrich A/T KO2 34x10.50R17, Teraflex HD Tire Carrier, Clayton 2.5" Overland Plus Lift, and more to come...
Will Scarlet is offline
post #7 of 7 Old 12-13-2019, 05:11 PM Thread Starter
Yes. the manuals are a lot easier than the automatics. The kit will be cheaper as well.
Will Scarlet likes this.
