LS Swap without a Kit?? - Page 2 - JKowners.com : Jeep Wrangler JK Forum
 6Likes
post #26 of 48 Old 05-21-2018, 12:56 PM
nocoastfocus's Avatar
Anything can be done with time and money. The question more succinctly is if I were to drop an LS in without a kit. What creature comforts stop working other than the dash and what would it take to get those creature comforts back? That was the original intent of this thread.
It is a valid question. I went with the Motech kit but I do not require emissions. The stock look and feel is pretty great, but with all the modifications to the Jeep a custom dash with some nice gauges might be pretty cool. Not sure how the cost comes out after figuring the dash/gauges and AC into it, but I would be interested in hearing from those who've done it.
nocoastfocus is offline
post #27 of 48 Old 05-22-2018, 11:30 AM
gt1guy's Avatar
Factory AC can be run stand alone as Kowboy is doing. Or you can run a Vintage Air system, that's the route I'm taking due to space constraints. The Vintage Air is obviously stand alone too.
Cruise control, if you're running an LS drivetrain, can be done with a Dakota Digital module. It ties into the gas peddle, either the OBDII port or a VSS signal (two different models) and the GM ECU. You'll need a controller (new stalk or pad) also. Maybe you could get fancy with wiring and use the factory stalk, I have no idea.
The gauge cluster, I got nothing. It seems to be a little computer that's tied into everything else.
What other creature comforts are you looking for?
Kevin
gt1guy is offline
post #28 of 48 Old 05-22-2018, 12:52 PM Thread Starter
ALASHA's Avatar
Radio, doors, car alarm, windows, remote start. I think those are the biggies other than AC
ALASHA is offline
post #29 of 48 Old 05-22-2018, 01:52 PM
Cod
Cod's Avatar
Send a message via MSN to Cod
remote start
Cod is offline
post #30 of 48 Old 05-22-2018, 03:54 PM Thread Starter
ALASHA's Avatar
Originally Posted by Cod View Post
I park indoors now but when I was in the Springs, being able to remote start from the apartment and let it warm up was quite useful.
ALASHA is offline
post #31 of 48 Old 05-22-2018, 08:30 PM
gt1guy's Avatar
Just thinking out loud here.
* Without a swap kit, the Jeep and GM sides don't talk to each other. We know that much.
* Stand alone engine harness gets the Jeep rolling down the road, more or less.
Will the Jeep side flip the fuck out, if it thinks you're driving down the road with the engine off? The brakes will work, the nanny shit wont. I assume something would need to be done with the way the key switch is wired?
Someone smarter, please fill in the blanks.
* AC and cruise can be delt with.
All those things, except remote start, will work just fine if the Jeep thinks the key is in acc or run.
So here's my big question. If the Jeep thinks it's just sitting there with the key on and engine off, what's to stop a stand alone LS from driving it around?
There has to be some big glaring reasons why this wouldn't work.
Kevin
gt1guy is offline
post #32 of 48 Old 05-23-2018, 01:06 PM
Cod
Cod's Avatar
Ah hell, just noticed you changed location to Denver.....why would you do that to yourself?? Isn't Springs > Denver?
Cod is offline
post #33 of 48 Old 05-23-2018, 01:10 PM Thread Starter
ALASHA's Avatar
Depends on what you are looking for. I was looking for more money...
ALASHA is offline
post #34 of 48 Old 05-23-2018, 02:12 PM
Cod
Cod's Avatar
I guess I should of bought you that beer while you were in the Springs!!
Cod is offline
post #35 of 48 Old 06-22-2018, 10:17 AM
DeucesALLin's Avatar
Swap w/o kit = buggy
Makes perfect sense if your starting with a flood vehicle.
*cough*
Sent from my SM-J700P using Tapatalk
Soon to be a vendor!!!
Looking for a good Rat Rod JK donor vehicle.
DeucesALLin is offline
post #36 of 48 Old 06-22-2018, 10:18 AM
The same reason people think throttle body spacers and gutted cats make stock engines faster... $$$
post #37 of 48 Old 06-22-2018, 11:07 AM
I can furnish a flex fuel bbc that will both run on the LS ecm or a carb...3 4 or 6 speed auto... if someone with a legit JK wants to see this done...Im in Houston.
Probably a 30 day project
post #38 of 48 Old 06-22-2018, 07:55 PM
Tyler at Rocksolid fab in Chattanooga did this years ago with big booty judy. Its got a supercharged 6 liter in it.
Redrockjeepin is offline
post #39 of 48 Old 06-24-2018, 05:36 PM
ebay sells stand alone harnesses for the LS motor for $400??? i'm wondering why all the need for everything else too....I have no worries about emissions so it maybe an emissions thing?
a10weaponsguy is offline
post #40 of 48 Old 06-25-2018, 08:35 AM Thread Starter
ALASHA's Avatar
From the build thread:
https://www.jkowners.com/forum/scrapb...-build-20.html
Originally Posted by Team Willys View Post
The thread explains it pretty good but I understand its a lot of stuff to sift through. Basically we kept the JK TIPM and body controller, which is the gauge cluster. The stock JK cluster no longer functions as gauges, but is used solely for the body controller. The LS system is 100% stand alone. It is simply powered from the ignition switch. If everything JK goes haywire, the jeep will still run and drive as long as the ignition switch gets power.
I dont remember how/if HVAC, alarm system and audio was handled/functioning
ALASHA is offline
post #41 of 48 Old 06-25-2018, 11:44 AM
Dkjeep's Avatar
You wont get a big block Chevy in a JK, it wont even take you 30 days to figure it out either.
Dkjeep is offline
post #42 of 48 Old 06-25-2018, 08:54 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
The LS is setup to run on it's own and the Jeep gauge cluster is back behind the dash still plugged in so everything is happy. He has a custom Autometer setup in the factory location that tells him what the LS is doing, speed, etc. Its been years since I talked to him about it, but I do recall those details.
https://www.jkowners.com/forum/2112209-post433.html
RiverCityOffroad is offline
post #43 of 48 Old 06-26-2018, 07:46 AM Thread Starter
ALASHA's Avatar
Getting the LS side of things to operate is the easy part. I like my creature comforts so I want AC, remote start, power everything and audio to remain working.
I guess Im just wearing a tin foil hat with this thread and trying to expose if all those things will still work without a kit...
ALASHA is offline
post #44 of 48 Old 07-02-2018, 04:11 PM
Well i know with my swap i just get in and turn the key and everything works, no hassles and if for any reason will be easy to sell due to everything operating like a Jeep should, hard to sell a modern jeep that doesn't have any heating controls,A/C controls, cruise control, Tap shift from either the Auto shifter or Steering wheel, no auto start and then theres the wiring under the hood that doesn't look factory due to running a aftermarket fan and shroud that isnt computer controlled like it should also for the A/C pressure. Theres also another reason these engine swaps cost so much is all the man hours working out coding for everything to make sure it all works together and not fighting itself....
But if your wanting to be cheap on a LS conversion for your Jeep, go buy a CJ that has no creature comforts as this will be a cheap conversion, while your there might as well stick a cable throttle on too....hahaha
2014 Rubicon JK 5.3 Gen 5 V8
2007 Wrangler Sport 3.8 SC
Dual country owner
Chris Meehan is offline
post #45 of 48 Old 07-02-2018, 04:24 PM Thread Starter
ALASHA's Avatar
Did you read this thread before posting or did you just decide to verbally vomit here?
ChuckTheRipper and xtremdude like this.
ALASHA is offline
post #46 of 48 Old 07-03-2018, 06:13 AM
coilrod's Avatar
Who the fuck are you?
coilrod is offline
post #47 of 48 Old 06-28-2019, 04:33 PM
I recently talked to a turbo guy who has a 2008 jku from pa he is running a 5.3 and 4l80e trans only things he bought for his swap was the transfer case adapter and some tach signal box to make the dash come alive after start up. He is running a holley terminator x for the engine and said he stripped down the jk harness kept all the sensors and adapted them to the ls engine. He usedhe hp tuners and removed a bunch of stuff from the stock Jeep ecm and it still runs a bunch of stuff and keeps things happy. Claims he only has 3k in the whole swap turbo and all it’s all used but this thing is nasty as can be. It does help he is a hot rod guy and does great work. Something to look into I guess I have gone for a ride in the Jeep it doesn’t have dash lights on and everything seems to work the way it should. But I’m no expert just was tickled pink to ride in a turbo v8 jk thing was a rocket ship.
Lsswapped4life is offline
post #48 of 48 Old 12-31-2019, 11:36 AM
How much hp/torque, if you know?
I'm building a twin turbo 6.0 lq4 w/ 4l80e JK and I'm going to be putting the stock NP241 tcase to the test.
An Atlas wasn't in the budget so the Novak adapter it was.
2008 JKU Sahara on jack stands with suspension completely removed, engine completely exposed, crossmembers cut out, and wiring harness dangling by the firewall. Soon, IFS front suspension with trailing arm 4 link in the rear.
GetLost is offline
