MoTech Gen V LS Conversion - Page 17 - JKowners.com : Jeep Wrangler JK Forum
 63Likes
post #401 of 428 Old 07-11-2017, 08:58 PM
Originally Posted by Dkjeep View Post
I'm measuring 39-1/8" from a flat spot on the face of the transfer case flange to a flat spot on the face of the axle flange. The 12'+ driveshaft will be plenty for you if you are trying to save a buck for now.
The end game for me is Adams shafts but I'm just trying to get this back on the road for now.
Sent from my SM-G955U using Tapatalk
I wouldn't think 3/8" would raise any red flags unless someone else thinks differently. I'll see what's available on the used markets and just order the rear Adams for now, thanks.
WNbirdman is offline
post #402 of 428 Old 07-13-2017, 07:54 AM
One solution that may save you some $$$ for now depends on what year model you have. I know FOR SURE that the front shafts for the 12+ models are a bit longer. I am actually running a new takeout front shaft from a 15' model on my jeep with the swap and it fits with ease. The travel on the slip is about dead center on whats available to go both ways. I stretched my front axle forward about 1.25" as well.
This could save you some $$$ if you only had to buy the rear shaft and there are always plenty of super low mile or new takeouts available around for free or super cheap.
Inquired about measurement on a 2012-2017 front shaft and response was 34.5" compressed to 37.25" extended. Not even close to my 39.5, which is the bottom measurement. Top is 40.25". Just to let everyone know who will be doing this swap who may not already know, you'll need to add about $900-$1000 minimum for new shafts. No complaints here as I knew this swap would not be cheap. From what i'm hearing this ride will be a gas to drive.
post #403 of 428 Old 07-13-2017, 08:05 AM
Dkjeep's Avatar
I dunno what to tell you, I have the shaft installed and if I unhook the axle end I can pull it bare minimum another 3" forward past the flange.
Dkjeep is offline
post #404 of 428 Old 07-13-2017, 10:25 AM
I believe you. Just got my shafts back from local driveshaft co. and measured front shaft. 33.75" compressed and 40.25" extended as far as boot would allow. I'll try asking another seller for measurements. Thanks!
post #405 of 428 Old 07-13-2017, 11:26 AM
Dkjeep's Avatar
I had just installed this shaft before I did the LS swap and with a 4" lift it was actually too long fully compressed to even go in. I had to stretch the axle forward to get it to fit even before the swap.
Dkjeep is offline
post #406 of 428 Old 07-16-2017, 07:34 PM
nocoastfocus's Avatar
Anybody have a part number for an ECM pin for the E38? I am finding different things on the web and I don't really want to pull the connector apart to look at the pin. I recently upgraded to the 52 dual core radiator and SS fan and the last step is to tie the fan wiring harness into the E38 Connector 1 Pin 58. Well, I am ready to do that, but I don't have the pin.
I think some of the newer Motech modules have this wire already ran but I have an older revision.
nocoastfocus is offline
post #407 of 428 Old 07-17-2017, 09:34 AM Thread Starter
MoTech's Avatar
Give the office a call we'll send you some.
MoTech
725-502-8507
MoTech is offline
post #408 of 428 Old 07-17-2017, 11:30 AM
Called and looks like I will have the part on Wednesday (I paid for expedited shipping). Motech, please know I provided some feedback to include this part in radiator upgrade sales. It is my understanding that some of the newer modules have this pinned already so its much easier to splice. You probably have a good idea on the customer's previous purchase if they will need to pin the ECM or not so you could choose to provide the part based on the customers needs. At any rate, it shouldn't take much to tape a pin to the harness when it gets sent out.
post #409 of 428 Old 08-03-2017, 12:19 PM Thread Starter
MoTech's Avatar
We have a couple different accessory drives running on the Gen V engines now, both the truck and the Camaro style. Most of our Gen V swaps are running the GM accessories which woks well. The AC compressor on the Gen V engines is tucked in tight to the block and up high so we don't have the UCA interference we had with the Gen IV AC compressor.
We are running JK accessories on a couple Gen V engines for testing now.
In the meantime the Gen V AC lines can be difficult to fit cleanly so we decided to turn out some adapters. This is the first Gen V adapter, it allows you bolt onto a Gen V compressor then run any standard AC fitting you want: 90* short drop, straight, 45* even 180*. There is a lot of room around the gen V compressor so it's not squeezed in there like the Gen IV compressors, or having to run a reduced size compressor.
We will be offering other AC adapters depending on your need.
MoTech
725-502-8507
MoTech is offline
post #410 of 428 Old 08-22-2017, 03:35 PM
Rubi-8's Avatar
Robbie,
What have you been able to do in the past to combat extremely high Intake Air Temperatures?
07 JK-8
08 2dr Sahara
17 Gobi Recon
Rubi-8 is offline
post #411 of 428 Old 08-30-2017, 04:00 PM Thread Starter
MoTech's Avatar
The Gen V 5.3 is a powerful engine. Mitch is still waiting to get his Jeep so he installed a L83/6l80 into his Tahoe. The L83 has no problem spinning the tires through 3rd in this Tahoe with tall gearing.
tapcola likes this.
MoTech
725-502-8507
MoTech is offline
post #412 of 428 Old 09-01-2017, 08:56 PM
Rubi-8,
I ended up adding a cheap EBay snorkel on my JK, which feeds cold air right to the air filter. I also made a quick metal box, shielding the hot radiator air from the intake. This dropped the air temp from 145 to 95 in 92 degree weather. However, only when moving......once we crawl, its back in the 130's.
I also added a DV8 heat reduction hood, but don't think it made as big of a difference as the snorkel.
Rubi-8 likes this.
Mjp83 is offline
post #413 of 428 Old 09-02-2017, 03:56 AM
https://www.youtube.com/watch?v=tfQg...ature=youtu.be
Pretty damn SWEET!!! I used to have a 1999 5.7 Vortec Tahoe 2-door (1994 GMC Yukon 5.7 2-door before that), would have loved that L83, and can only imagine the L86 in that platform!
What kind of MPG is he seeing?
2013 JKUR
Magnuson Supercharger (66mm Pulley) with Catch Can
Innovate Wide Band O2 Sensor
Diablotoona Custom Tune
Volant Cold Air Intake
6-Speed MT with B&M Precision Sport Shifter
4.10 Rear Diff
Line-X of Interior and Rock Hard 4x4 Sport Cage
JW Speaker Headlights, Fog Lights, and Tail Lights
BFG All-Terrain T/A KO LT265 70 17 (actual height: 30.75")
doc5339 is offline
post #414 of 428 Old 09-19-2017, 03:13 PM
This is a Gen IV LS3-430, I think you can hear the difference in the power bands vs the Gen V engines; the LS3 likes to rev, the Gen V's have gobs low end of torque.
https://www.youtube.com/watch?v=KoMr...ature=youtu.be
One mean machine!! Thinking this is the direction I want to go.. curious what control arms he's running.
Josh Dalton is offline
post #415 of 428 Old 04-16-2018, 08:18 AM
Thought I would inject a comment in regard to my L83/8L90 swap. The 8L90 trans fluid, Dexron HP, is impossible to find locally at a reasonable cost and the local retail parts houses do not stock. Dealerships want about $17 a quart and considering I don't know how much I will need due to trans being drained before shipment I opted to purchase at the most reasonable online vendor I could find after hours of research. One Amsoil online dealer claims their ATF is an acceptable substitute but could not verify through Amsoil so I passed. The 8L90 seems to be very particular about its fluid so I'm using Mobil 1 LV ATF HP to play it safe as the dealerships, through part #19353429, use it exclusively. TheLubricantStore simply had the best price so I went with them. Swap going good and will be working out a few instrument light issues with Motech after trans is filled and road tested.
mstrofpuppets likes this.
post #416 of 428 Old 11-14-2018, 12:38 PM
Status of DIY Gen V kits
Hi Robbi,
Do you have any updates to report on the DIY Gen V kits? When does this kit transition from BETA to fully awesome status?
Looking forward to using this product!
Thanks,
kingtroller is offline
post #417 of 428 Old 11-18-2018, 04:40 AM
Bumpstick's Avatar
It's been 2yrs since I last commented on this thread, but it's now finally possible for me to start gathering the parts for a V8 swap... My rig is a 2012 JK 2door with 4.88 gears turning 37x14.00 Iroks (have cryo treated gears and chromoly shafts with 35spline in the rear) . I live in Florida but have family that live in PA about an hour from Rouse Creek. So I will be s staying on the east coast mostly. But my jeep rarely sees interstate driving. I'm not wanting to regear or change tire size any time soon (if I do it will be with bigger axles).
I have a buddy that's been a GM tech for 20yrs that has a 2 post lift at his house that we will be using. I'm still not sure what engine or trans would be the best for me and the best bang for my buck.... Is the L83 and 8spd the way to go? Or 6.0 with 6L80 still better for me?
- 37 Irok's - 4.88 - Detroit/OX -
Bumpstick is offline
post #418 of 428 Old 11-18-2018, 10:04 AM
I completed an L83 swap this summer on a 2013 4dr also on 4.88 and 37s. On the highway at 70mph the motor is running 2100 rmps. When I got my L83 it had an 8L90 on it. When I called
Motech about a kit I talked to Mitch and he strongly recommended that I either get a 6L80 or
change my gearing to 4.11. I went with the 6L80 as it was the less costly way to go.
John_fender is offline
post #419 of 428 Old 03-04-2019, 03:52 PM
Hi guys, I have a swap jk ls and here's a block. it is impossible to establish normal operation of the unit with the bus. Tell me in which direction to move
Wrangar is offline
post #420 of 428 Old 03-04-2019, 07:49 PM
coilrod's Avatar
I know as much as anyone who put a (mostly) ready for market bolt in Motech swap in a jk.
Who supplied your parts? Who programmed your comps, what year, blah blah blah.
Your question is like saying," I bought a new rifle. Why am I not eating steak?"
Rubi-8 likes this.
coilrod is offline
post #421 of 428 Old 12-12-2019, 04:32 PM
I'e read this a couple times now but not seeing anything on headers/manifolds. Im about to swap in a Gen5 l83 into the JKU. The manifolds I have are truck manifolds. Would these work or do I need something else?
As for the pedal, which 3 options best fit the JK?
Mildly built 2011 JKU Rubicon
FatCow is offline
post #422 of 428 Old 12-13-2019, 10:32 AM
My L83 came out of a 2016 Silverado and I used the manifolds that came with motor and used the Motech exhaust kit.
Not sure what you mean by 3 options for the pedal. If you are talking about the throttle pedal the Motech kit includes the mounting adapter plate and pedal assembly.
post #423 of 428 Old 12-13-2019, 12:00 PM
Thanks. I thought I had read the truck manifolds were the ones to go with but that was a good while back and couldn't find it again.
The pedals come in several different styles, 3 being fairly common in swaps across the board. I am not going with motech's kit outside of a few things I needed. Is your pedel straight down or does it have a right hand offset?
FatCow is offline
post #424 of 428 Old 12-13-2019, 04:48 PM
Mine has the offset towards the right. I puts the pedal pretty much where the Jeep pedal was.
post #425 of 428 Old 12-13-2019, 05:13 PM
0lllllll0 RPMEXTREME's Avatar
You should run the stock GEN5 truck pedal. it will bolt up the same way the GEN4 truck pedal did.
