JK Wiring basics!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 25 Old 06-13-2009, 08:20 PM Thread Starter
usmcdoc14's Avatar
JK Wiring basics!!
The first modification done to most any Jeep typically involves the electrical system. Be it as complicated as a winch, or as simple as a set of off-road lights, and they are done by everyone, to almost every vehicle. But as deceptively simple as most electrical modifications may seem, they are also the most dangerous, due to the common mistakes and lack of attention to detail when doing the installation. What you will be getting here today is not only a primer in electrical upgrades and installation, but a valuable lesson in what the most common and dangerous mistakes are.
So lets start at the beginning:
Each of these points will be simplified not to "dumb it down" but to give you the basic understanding of your electrical system. Each aspect will be discussed as to its function and importance in more detail as we go along.
Your JK is a 12 volt, direct current, negative ground system that is powered by an alternator and battery system. Yes, I know an alternator and battery both have above 12 volts when charging or fully charged (around 14 volts), but we are keeping some things basic and this is how accessories are sold. Its is direct current (DC), that means the negative is the negative, positive is positive and they do not switch back and forth like alternating current (like your house). A negative ground system means that the chassis and body are wired to the negative post of the battery and the alternatorís negative is though its case to the engine/frame. All the positive power is ran in wires and most all modern cars are negative ground.
What are Volts, Watts, Amps and Ohms, and why do I care?
Now you may be thinking "I donít need to know this, my stuff comes from the factory or in the box already wired". Well you would be wrong, or better yet, a lot of companies are completely wrong and send substandard wiring. But you would be oblivious to this because you may not be educated on automotive electrical systems.
Its best to be well educated instead of stuck on the side of the road or trail on fire.
Think of electrons like water, and your battery/alternator as a water tank or pump with pipes. It makes it a little easier to visualize.
Volts
Volts (voltage) is like water pressure in the tank or from a pump. (battery/alternator) It can be constant (vehicle running) or can gradually go down (battery only) just like the pressure in a tank unless there is something to replenish it (alternator).
Amps
Amps (amperage) is the amount of water that can or is going through the pipes at a given time. So if you have a bigger pipe more water can flow through with out doing causing damage. If you are running more amps you are going to need a wire big enough to handle it.
Watts
Watts (wattage) is the amount of work the water can or is doing. For example the watts of a light bulb.
Ohms
And lastly, ohms. Although you will not have much use for them in most simple wiring it is best to understand what it is anyway. Ohms is the amount of resistance caused by the pipes, what is attached to them or what is in them. If you make a pipe longer, smaller, put your thumb over the end or put rocks inside it (impurities), then there is more resistance to overcome to get the same flow. The same thing goes for how big wires are or what they are made from of.
How these terms apply to you is it will allow allows you to safely select wires, switches, relays and other items based on the needs of what you plan on adding to your Jeep. For example, or better yet, the best example, would be off road lights. These being THE most common and first upgrade that most people do an off-road vehicle. On that same note it is also the one that is often done half-assed and dangerously. The danger begins with people misunderstanding the requirements of the lights. They see that they are installing a 55w light and thatís about where it ends. They have no idea what the correct wire size, fuse size or switch is unless itís included with the product. If you get some cheap chicom knock-off light you can pretty much bet the wire/fuse/switch will be substandard. But now that you understand the basic terms of automotive electricity you can figure out exactly what you need!
So you know that you have a 55watt light, 55watts is how much work the light is going to do. You know its 12volt because the box or bulb says so, but how do you figure out what amperage fuse, switch or wire to run? This is what we will cover next.
Basic math
Everything revolves around you knowing numbers, you canít figure the wire, fuse, switch or anything until you know what your electrical item requires in order to work. Luckily most products will list the maximum amp draw in the owners manual or online. Too bad they do not do that with your common off-road lights, Luckily that is quite easy to figure out.
Wattage will always be listed, even if you have to just look at the bulb. Your amp requirements are figured really simple.
Amps = watts, divided by volts.
So you have two 55 watt lights on a 12 volt system. 110 (55x2) divided by 12 = 9.17. Now knowing this, you can start choosing the rest of your electrical system to safely match. To do this you should just follow these steps.
1)Find the amp draw of what you want to wire.
2)Choose a wire that is made to function at or above the amp draw of the accessory.
3)Fuse the wire to less than its maximum amperage.
Choosing wire
For automotive use we will be working with stranded wire instead of the solid wire like you would find in your house. Solid wire (made of a single solid wire) flows electricity the same but it just does not handle vibration well and will eventually fail. You want to use automotive or marine grade wire. Its muti-strand and itís protective coating will be resistant to UV light, oils, abrasion and the other hazards of being in a jeep. Do not go and use lamp cord, com wire, speaker wire or any of the junk that people use that is NOT DESIGNED to be safe in a vehicle.
Do you have any idea how many cars I have fixed that were wired up with lamp cord?
Anyway, You can pick up wire from your local auto parts store or boat/marine shop. Myself? I prefer to use tinned wire and order it online from boating places. Tinned wire takes longer to corrode and getting it online in bulk saves a lot of money over the little 25í spools you get at a retail store. But any automotive or marine grade wire will usually suit your needs just fine.
Wire is measure in gauge or how thick the wire bundle is. This is measured in numbers like lead shot or needles where the smaller the number the bigger the wire cross section is. 10ga being smaller than 2ga and 00ga being much larger than 24ga. Your wire gauge will be dictated by the amps you plan on running through it and how long it needs to be. People will go and figure the amps but fail to take into account how long the wire run is. The longer the run, the more resistance, the more voltage drop, the more heat and the bigger gauge wire you need. The complete run is figured from the battery to the accessory and then back.
Each company has rating for its own wire and no one elseís. For EXACT max rating of the wire you need to see the data sheet ON that brand/company wire. Boat/marine have stricter guidelines on wire than SAE/automotive so using their wire will add a measure of safety as well. You will want to base your choice on the continuous amp draw of the accessory.
Here is a rough chart for a rough go-by to help you out.
usmcdoc14 is offline
post #2 of 25 Old 06-13-2009, 08:21 PM Thread Starter
usmcdoc14's Avatar
But you can ALWAYS go overkill on the wire, you can ALWAYS use larger than what you need or rated. This allows you to correctly fuse and make sure that your under the max amps of the wire. Always choose a wire rated at or ABOVE what your accessory requires. That chart and most companies list the max amps at the continuous draw with the wire by itself cooling in the open air. Wires get heated under normal use by the electricity running through it, but with too much amperage the heat melts insulation, this causes a short and hopefully not a fire. So when you have a bunch of wires tight together or in a loom you may wish to up the gauge just for that reason alone. Then you add the heat from under your hood and you are cutting it kinda close with the point of failure of the wire. Take these into consideration when choosing wire size.
Remember
Always fuse the wire, not the accessory !! This means to make sure your fuse is less amps than what the max amps of your wire. Yes, your accessory may require a 20a fuse, but if your wire will catch fire at 18a you need to fuse it before that point. The fuse needs to be your weak point of failure at all times.
Choosing your fuse
Now that you know your amp draw and the correct gauge wire you will need to fuse it correctly. Luckily, that is the easy part. You just make sure the fuse will pop before the wires failure point. You also want the fuse as close to the battery as possible so there is as little unprotected wire as possible. You do not want the fuse far away from the battery because you do not want the chance of a short before the fuse, defeating the whole reason a fuse is there. Again, your fuse should ALWAYS be your weak point.
Thatís it, almost.
You will need to figure the performance needs for your accessory. A common automotive fuse is set to fail at a set amp, this works fine, unless your item requires something different. If your accessory is a high amp item, say above 30a, a common automotive fuse may not be high enough. Or if your accessory has a high amp draw only at start up you may require a slow acting fuse that still protect the wire at its continuous rating but allow the high start up amp. An example would be an HID light or a compressor that has a peak draw when it first starts up.
Or what if you donít want to keep buying fuses or have an item above a common rating? In that case you would run a circuit breaker. These can be automatically resetting types (resets when the power is turned off) or manual reset (throw a lever or push a button) and can vary in size from a 2.5a to 300a and above.
I myself like to run manual reset circuit breakers because I want to know WHY my circuit breaker tripped and solve that problem before I reset it.
Now as mentioned before, what the type and brand of fuse will dictate when it blows. The amperage at which fuses actually blow, and circuit breakers actually trip, are sometimes considerably higher than their nominal ratings. SEA, Maxi, ATO and AGC fuses, and most circuit breakers, blow or trip at about 130% of their rating. ANL fuses blow from 140% to as high as 266% of their rating.
You NEED to take this into account when fusing a high amp system, but luckily, the information is easy to find from the company website for the manufacturer of the fusing system.
You will also need to choose a holder or fuse block. Fuse holders work great for a single item or when the total amperage of all your individual items will exceed the capacity of the fuse block. They are also very easy to waterproof or come waterproof out of the box.
Here are a pair, now they are rated the same amperage but you notice the different size. one is an ATO-ATC fuse and the little one is an ATM. Your JK uses ATM. Its your choice as to what one you want to run, but the smaller one will make your jeep fused alike.
Choosing your switching
You got your accessory, you got the correct wire, you got the correct fuse, so how are you going to turn it all on and off?
Just a simple switch is easy enough. Make sure the switch can handle the max amp of the accessory and you are good to go.
Even a not so simple switch is easy, once again you just make sure the switch can handle the amps, follow the wire diagram on the back and you are ready to rock.
You can switch either the positive or the ground. Most of the time if not all you switch the positive because it requires less wiring. The positive wire goes to the switch, then from the switch to the accessory. The ground from the accessory go goes right to the frame or body right next to it. Switching the ground requires a wire from the battery to the accessory, and then from the accessory all the way back to the switch and THEN to a ground. But either way works depending on what your requirements are because there are at times, benefits to a switched ground are like when you need an item to turn on if the switch fails, for example a cooling fan.
What limits us in running "just" a switch is the same problem that automotive manufacturers figured out years ago.
When you have 5 or 6 high amp items that need to be turned on/off where do you run all that thick wire? What if you have a accessory with a amp draw higher than your switch is rated? how do you use it?
You run a relay.
A relay is, in its basic terms, a electromagnetic switch that is turned on and off by low power. You apply power to the relay, the electromagnet in the relay causes the contacts to complete a circuit and the current flows to your accessory. This allows you to turn on a high amp item using a very small or low amp switch using small gauge wire ran inside your jeep.
Could you imagine running your starter wire all the way to a huge switch on your steering column and then all the way back? Along with controls for wipers, blinkers and lights? You would have a steering column that would be huge. Thatís why car makers use relays.
The great thing about running relays are:
Smaller wiring.
Smaller switches.
Safer wire routing as only low amp wire is ran though the firewall into the cab.
Safer wiring as there is less wire required for the entire run of the circuit.
Smaller gauge wire required for the accessory as the run of the circuit is shorter.
Can handle higher amps than just a simple switch.
Can be switched in multiple ways (more on this in a bit).
The bad things are:
More wire.
Can be confusing
Not as simple
Although there is nothing wrong with just running a fused wire through a switch to your accessory, I prefer to have mine run with a relay to keep the wire diameter in the passenger compartment to a minimum. I also like to run switches that are smaller but still over rated for the requirements of the relay.
Another great thing about a relay is it does not care what end of a circuit it completes, positive or negative. Power is applied and it electromagnetically closes, what goes through its contacts does not matter. This can be very useful for turning one accessory on with multiple ways. Examples of this include:
Additional reverse lights that you want turned on by the factory reverse lights and/or a switch.
Cooling fans you want controlled by a thermostatic switch and/or a dash switch.
You can not easily run multiple positive power sources to the same item with multiple switches. What will happen is either it will double the volts and fry something or it will flow back through a switch and fry something. You can do it with some more complex electrical that never works out for me or you can do it quite simply and switch the ground with relays. You run your normal fused positive wire directly to the accessory and you use multiple relays or switches (depending on your choice of switch) to control when the accessory is grounded. When its grounded it completes the circuit and turns on! Use as many relays as you need switches.
We will cover wiring a relay a little bit later, its not hard, trust me.
post #3 of 25 Old 06-14-2009, 01:01 PM Thread Starter
usmcdoc14's Avatar
But how do I connect everything?
I am going to cover the good or best connectors here. Sorry, but I have no time for substandard connections. Electrical tape may work great in your house but it has no place at all in a jeep. The same goes for some other utterly retarded connections I see all the time. While we are here on this rant, lets cover some of the most horrible ideas to be used in automotive electrical upgrades.
Wire nuts, WIRE NUTS !!!??? Who ever thinks that a wire nut belongs in a vehicle needs to be force fed a box of them.
T-splices, scotch connectors, inline splices or whatever you would like to call them.
Those things are the most horrible invention ever created. I donít care if it came with the accessory from the factory with one. Just throw it away, it is the lazy mans electrical salvation but at the same time will make you work harder in the end. No cutting, no twisting, no solder, you just slide it on and squeeze with pliers. It also offers no protection from the elements, in fact it leaves the wire nice and open to corrosion. It is also inherently dangerous, it allows you to tap into an already existing circuit to "tap" into its power. That circuit already has a job, a amp draw and a power requirement and there you are trying to suck more power from it and exceed its operating parameters. Walk away from the T-splices and do things right.
Doing connections right
The most common and easy way to do a connection is using crimp style connections. They work well, are simple, anyone can do them and the will not fail if done correctly.
The problem is people do not do them correctly nor seal them when done. Get a quality crimper instead of a pair of vice grips, also use either crimp connectors that have a heat shrink media built in or cover the connection with heat shrink tubing.
If you can find them, use waterproof removable connectors such as weatherpac. These will allow you to have a connection that is completely waterproof but also easy to take apart should you ever need to.
I own huge amounts of adhesive lined heat shrink tubing, the adhesive melts when you heat the tube to shrink it and seals the entire area. Every electrical connection gets heat shrunk and sealed. It is not worth the money to buy "normal" heat shrink in my opinion. I can order the adhesive lined tube online for less than a tiny package of cheap stuff costs me at the auto parts store. Yes, regular heat shrink tubing works well and is tons better than electrical tape. I just want my connections to be waterproof and sealed from the elements so I never have to fix it later. The extra pennies per foot make it worth it in the long run. But either way, use heat shrink tubing.
Another great friend to the off-roader is dielectric grease. It is used in connections to keep water out. Use it on all connections that you do not solder or that have any chance of getting exposed to water. That for me means pretty much everything.
I always solder, its solid, simple and I never have to worry about it. I am not saying you have to, but its a skill to learn. I can also take it apart should I ever need to, you just re-heat it. Soldering is not that difficult, you just strip the wire and twist the ends together or insert it into your connector. Next you heat up the wire using either a soldering iron or torch and touch the solder to the wire. When the wire is hot enough the solder will wick into it, and when everything is nice and silver you are done. You do not need a huge glob of solder on there for it to be a good connection, just what wicks into the connection. Of course only use electrical solder and not plumbing solder. Never solder a dirty joint and make sure the wire is clean.
From A to B
So now you know how to choose your wire, your fuse, the switch and how to connect it all up. But in order to put it all together we have to start back at the beginning: How is this all powered?
A: The alternator
Now with a "normal" jeep you have many options to upgrade your alternator, but you own a JK. The JK alternator is controlled by the wonderful management system in your vehicle so just "slapping on a 200a alternator and hit the trails" is not going to work. When the aftermarket gets on the ball to allow a safe bolt on upgrades then I will update this section. But luckily the 2007 came with a 160a alternator and then they down graded it to a 140a one. This is still a LOT of amps for what came factory! Remember, you have to have more amp draw than what your alternator can handle before it dips into your battery reserve. Another option is use a diesel JK alternator or another Daimler Chrysler alternator of the same design that is higher amp. The main thing here is add up your amps and see if you are cutting it close.
B: The Battery
The battery is the soul of your electrical system. It is what starts your jeep and runs everything when the engine is off or the amp draw is above the alternators output. Don't skimp on your battery.
Where do I wire from for it to do what I want the danm thing to do?
Do you want it to come on when the JK is on? that is "switched" power. Do you want it to always be available no matter what? That is "constant" power.
I try to avoid using the stock JK electrical system for pretty much all of it. I have found it causes less issues to isolate my new electronics from what the JK wants to control.
Constant power is easy, hook a fused wire direct from the battery. Switched or ignition on power is a little more complicated, but still easy. The one for certain switched power source is the cigarette lighter. It also will have no issues because its also made for a variable amp draw and is not pulsed because that would cause issues with accessories that use a lighter plug. But ONLY use this wire to be a switching power to a relay! Donít use it to power a bunch of things or it will pop the fuse. It can barely handle being just a lighter.
But I digress, lets get back to why you are reading this, wiring up a relay.
Some relays are marked on the top as to the wiring but here is a go-by if you flip the relay over and just look at the numbers underneath. (BTW, use a relay plug instead of blade connectors, donít be a hack)
And those numbers tell me what does what.
30 = fused power from the battery
87 (and sometimes there is a 2nd pole labeled 87a) = lights or whatever you want to power.
This is the circuit that is completed when power is applied to:
85 = positive used to close the relay
86 = ground
So I solder the wire from 87 to the positive wire for my lights/whatever, then I run 30 to the battery with a fuse right near the battery (no fuse in it yet, always put the fuse in last). The 86 wire gets a nice solid ground with a ring terminal to something steel or the ground on the battery. I install the fuse and then touch the 85 wire to the battery to test everything, you should hear a little *click* as the relay closes and the lights should come on. This is just a test to make sure everything is working right before I wire everything in place. Remove the fuse and then run your switch wire (85) to whatever you plan on using as a switch. Whether it be a ďnormalĒ single throw switch or a self illuminated one is your call. Test your lights and then mount them up.
And yes, it is that simple.
Note: This is not the original posting for the start of this thread but a replacement due to a member deleting the technical information in spite.
This is a condensed version of my article here https://www.jkowners.com/tech/electrical/index.php and is in no way related to, affiliated, parodied, copied or tied into the original posting.
post #4 of 25 Old 06-19-2013, 04:04 PM Thread Starter
usmcdoc14's Avatar
Feel free to point out errors, information you would like added or any comments !
post #5 of 25 Old 09-30-2013, 06:12 AM
GreenGIAnt08's Avatar
That's one hell of a write up. Good job.
2008 JK 2DR X -3" Lift, 8,000 Waterproof winch, Rugged Ridge Snorkel, XHD front Bumper, Dual Batteries, CB and other random electronic bits.
GreenGIAnt08 is offline
post #6 of 25 Old 10-20-2013, 07:22 PM
sPOD-guy's Avatar
Feedback: 12 reviews
Man I love you! I wish I had you answering our phones for us! Great job! Thank you.
-John the sPOD guy
switches jeeps panels jk-forum carling contura led switch windshield
sPOD-guy is offline
post #7 of 25 Old 12-22-2013, 04:49 PM
txaggie09's Avatar
Man, thanks for taking the time to write this up, I really appreciate it. I feel comfortable with a welder, plasma cutter, grinder, whatever mechanical but when it comes to wiring I am usually lost. I am, or used to be, one of those that half-assed the wiring for my lights and always had problems with it. This really helps!
txaggie09 is offline
post #8 of 25 Old 06-04-2014, 06:13 AM
Nice write up. I'm OK with old school wiring, but canbus and PWM systems are all new to me.
Can I pull power off the high beam side of the headlights to run a relay supplying batt 12V for driving lights, without upsetting the vehicle's electrical system?
ie, 12V tapped off the high beam power to contact 85 on the relay, then from relay 86 to ground via dash mounted switch, so I can disable the driving lights if needed.
Thanks.
LeighP is offline
post #9 of 25 Old 06-05-2014, 07:36 PM Thread Starter
usmcdoc14's Avatar
Thanks.
no..sorta, and why?
there are some times you WILL need aux lighting when high beams are not needed or are DEAD Power to relay should always be fused directly off battery so it is stand alone. The headlights are pulsed and CAN cause issues with a non-capacitored relay
Use any ign switched power to your switch and THEN to your relay, you can use highbeams but i would seriously debate that. And you can use a switch inline to switch via ground.
post #10 of 25 Old 06-05-2014, 08:59 PM
coilrod's Avatar
The law where I live specifies that driving lights only come on with high beams. The switch turning them off was a courtesy for my suburban co-drivers.
The high beam wire was the trigger, so the aux driving lights could only come on with high beams and switch triggered.
coilrod is offline
post #11 of 25 Old 06-06-2014, 07:15 PM
And....thats exactly my issue....the driving lights HAVE to operate with the high beam only....nice fine ($) from the constabulary if they get checked and don't work that way.
I'm going to retro fit some LED Dually style floods into the fog lights for additional lighting ... independant of the headlights at all, that way.
I think I'll have to talk to my tame auto electrician about how to do this....I thought tapping off the stock wiring for the relay might upset the canbus system.....darn it.
LeighP is offline
post #12 of 25 Old 06-06-2014, 09:15 PM
coilrod's Avatar
I used past tense because a month or so after I used them for the first time I started getting weird ghost lights. Interior lights would dimly light randomly and the switch would buzz.
While in Las Vegas, Motech pulled all my splices and ran new harnesses. Fixed the weirdness. I think there was some back feed or something with the aux interior lights, but not sure.
coilrod is offline
post #13 of 25 Old 08-13-2014, 05:01 PM
Catfish's Avatar
Sir, thank you, sir!
Catfish is offline
post #14 of 25 Old 04-26-2015, 11:11 AM
Joe Gamer's Avatar
This is an excellent write up. It's a good reminder to uphold some standards when working on these vehicle's we love so much (like Lennie loves mice)
Joe Gamer is offline
post #15 of 25 Old 05-09-2015, 11:55 AM
n3tfury's Avatar
GREAT write up!
I'm going to be purchasing some wires this weekend to run from my rear cross member to my SPOD, but am wondering if I should NOT run them under the Jeep (along the frame) and just run them inside. Also, I see some folks using wire loom front to rear (outside) and some don't use any. How effective is wire loom as far as help keeping the wire away from the elements? Seems to me it's just a best practice for a sano look as opposed to not using it.
Thoughts?
n3tfury is offline
post #16 of 25 Old 08-24-2018, 04:53 PM
So I found this thread, I have a dumb question. haha. Replaced my speed sensor on my 2012 wrangler, everything went fine. Passenger front was bad. Went to disconnect from the harness, behind the shock tower. He-manned the sensor off and the locking tab portion from the wires in the engine bay came off, leaving two exposed ends. Bought a pigtail replacement with locking tab. Which wire is positive and which in Negative, color wise?
Eggo17 is offline
post #17 of 25 Old 08-24-2018, 05:06 PM
i've not had my insulation wrap off of one of the WSS wires before but I have noticed the tines above the connctng pins are ID'ed within your socket. might help you identify them if you can tell which ripped from which end....
just get a replacement sensor; what r they, $10-$15 bucks?
post #18 of 25 Old 08-24-2018, 05:16 PM
Thank ma man. I have the replacement sensor, was 20 bucks. not the main issue. The two wires that plug into the + and - tines, im wondering what color the + wire is. I mean I ripped the other part of the connector that comes from the jeep engine side haha
Eggo17 is offline
post #19 of 25 Old 08-24-2018, 06:27 PM
Ah
I wondered aftr replying i you meant from the main harness. I would image there is some manner of insulation identifier on one of themunder the primary.. or maybe they are blck and white.
maybe someone else has done that.
post #20 of 25 Old 08-25-2018, 07:09 AM
Yeah, still have been searching on that one. Thanks for the help though brother.
Eggo17 is offline
post #21 of 25 Old 11-30-2018, 02:38 PM
Excellent write up!
Glocker21 is offline
post #22 of 25 Old 06-12-2019, 12:08 AM
Laggy's Avatar
U consider myself pretty savvy electrically.
Learned something though. To still do the computations for a supplied accessory harness, making sure that the wire sizes are all of consistent size, and wire is fused correctly.
Laggy is offline
post #23 of 25 Old 01-06-2020, 08:57 PM
Sort of related ... my 30++ year old Weller industrial just went kaputt... that was way to hot and im not that great with it.... can you please recommend / a good solder gun or IRON for elec work on my JK?
gafergus is offline
post #24 of 25 Old 01-07-2020, 06:04 AM
umm, if you got 30+ years from the brand , I'd do like the majority of us & replace w/ another Weller. I use one &:have had it for a dozen or so years. Tin your tips & solder the planet, dude.
post #25 of 25 Old 01-07-2020, 06:38 PM
that is what i was looking at BUT comments i keep reading is it now comes from china and not real reliable
gafergus is offline
