Strange. Never seen or herad of anything like this. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 10-04-2012, 09:30 AM Thread Starter
Gotlime?'s Avatar
These things may not be related, but weho knows.
I have an Optima Red Top battery in my Jeep that is less than a year old. About a week ago, I went out after the Jeep sat for about a week and the battery was dead. I jumped it and all was well. Last time I drove the Jeep was this past satruday. Went out this am and the Jeep started, but it sounded weak. I'll have the battery checked.
here's the weird thing. This has been going on for maybe a week or so. I take the keys out of the ignition. The headlights are off. I open the door and the chime (like the lights are on or I left my keys in the ignition) stays on. The gauges are also lit up like the lights are on.
Anyone experienced this?
What should I be looking for?
08 Jeep Wrangler Unlimited Rubicon: lift, wheels/tires, bumpers, skids, sliders, winch, lights, cb. All the normal stuff, plus some.......
Build thread:
Gotlime? is offline
post #2 of 13 Old 10-04-2012, 09:43 AM
You have a draw on your electrical system, something is keeping the cluster powered up. I think there is a topic on here about how to check for a draw and find out what it is. Its fairly simple
Sent from my SCH-I500 using Tapatalk 2
Wanta44 is offline
post #3 of 13 Old 10-04-2012, 09:46 AM Thread Starter
Gotlime?'s Avatar
I didn't think to verify it, but I don't think the cluster lights stay on. I need to roll down the windows and see if the chiming and the cluster lights stay on indefinitely. If so, that could drain the battery. Then the question becomes, why do they stay on?
Build thread:
Gotlime? is offline
post #4 of 13 Old 10-04-2012, 01:57 PM
kkuntz01's Avatar
Right, because I was under the impression that after "xx" amount of time the computer shut down power so as not to allow this to happen. At least it's been that way when we've accidentally left a dome light on.
kkuntz01 is offline
post #5 of 13 Old 10-04-2012, 06:52 PM
FireTrail741's Avatar
Has the interior been rained on? Guessing here.
FireTrail741 is offline
post #6 of 13 Old 10-04-2012, 06:54 PM
When the TIPM dies it can do some funny things, perhaps that's part of your problem.
post #7 of 13 Old 10-04-2012, 07:22 PM
kntr's Avatar
I went trough 1-2 Optima Red Tops every year for about 5 years. I finally switched to a Standard and not a problem since.
kntr is offline
post #8 of 13 Old 10-05-2012, 05:57 AM Thread Starter
Gotlime?'s Avatar
The Jeep has a Viper alarm and it has soemthing to do with the alarm. It was installed in GA and I am in NC so this should be fun.
I noticed when I turn the lights off the parking lights stay on. Click the lock button and they go off. Then, last night, the alarm started activating by itslef. I unlock the Jeep with the fob, get in and start it up, the larm light on the dash comes on and a little ways down the road, it starts going through it's audible alarm cycle. That was fun. I pulled over. Shut off the Jeep. "Unlocked" it. Restarted it and started driving again. The alarm light on the dash continued to flash, but no audible alarm.
The alarm has worked fine for over a year and just decided to start acting funky recently. I'll call the place that installed it and see if I can find someone local to take a look at it.
Build thread:
Gotlime? is offline
post #9 of 13 Old 10-08-2012, 10:19 AM Thread Starter
Gotlime?'s Avatar
And the issue has resolved itself...............................
Build thread:
Gotlime? is offline
post #10 of 13 Old 10-08-2012, 11:38 AM
What was the problem?
JK ready for the build but the pockets aint
jchmelo is offline
post #11 of 13 Old 10-08-2012, 02:25 PM
v10kingsnake's Avatar
Where did you buy the red top? A lot of auto part stores have these shelved for a while before someone drops the coin on them. Test battery first as cars do weird things when a battery is going bad. I'd do this long before wasting time hunting an elusive draw.
2009 Sahara Unlimited. 5.7L Hemi truck setup. Rock Krawler 5.5 coil over LA. Maxxis Trepador 40's . ATX Rims, XRC front rear and side armor. RROR Crusher corners, RROR flat flares. Warn XD9000i. Prorock 44 with RCV shafts. 5.13 gears, ARB front and rear lockers.
v10kingsnake is offline
post #12 of 13 Old 10-08-2012, 03:41 PM
virtual_mage's Avatar
Canbus can do crazy stuff , my battery was getting drain, no key in the ignition and I was getting a parasitic draw..... Started to pull my fuse and found it was from the radio.
I had installed my aftermarket radio without a can bus adapter, since I had run my own power speaker wire ect,always found stock wiring to be cheap.... Anyway the oem radio plug was just laying there.... Hooked a can buss interface to it and it stopped they draw.
Sent from my XT910 using Tapatalk 2
Winter is coming.
virtual_mage is offline
post #13 of 13 Old 10-09-2012, 05:44 AM Thread Starter
Gotlime?'s Avatar
I have no idea. It just went away. I got in the Jeep Satruday am and everything worked as designed.
The good news is I don't have to worry about it right now.
The bad news is it will retrun at an inopportune time.
Build thread:
Gotlime? is offline
