Hella headlight replacements - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 10-03-2012, 07:58 PM Thread Starter
I just installed my Hella headlights replacements with harness today and they are fantastic. The install was straight forward and took about an hour (I'm meticulous about routing my wires). Hit the road with them this evening and I can actually see in front of me. Couldn't help but smile as this is one mod my wife can't bitch about No more seeing my Jeep's shadow from the car lights behind me. And the high beams light up the road as far as I could hope. I don't have anything to compare these to but my stockers and the stockers of my FJ Cruiser which I thought were fantastic.
Highly recommend!
just eric is offline
post #2 of 5 Old 10-03-2012, 09:19 PM
Had these and loved them. Only reason why I replaced them was due to cracking the lens. Be sure to turn off your DRLs so that when you wheel and hit some water you're not cracking the hot glass.
2012 Silver JKU Rubicon
5 speed auto, 4.10s
Riptide is offline
post #3 of 5 Old 10-03-2012, 09:22 PM
Banshee's Avatar
Damn! Your stock lights must REALLY suck!
Hella H4s are the standard fitting down here & we think that they suck and put better ones in.
Of course, the stock ones we get might not be the same spec you installed.
Originally Posted by Clone7
When you die, you see your life going by in a flash.
Steve Jobs didn't - Apple doesn't support Flash.
This message has been reviewed & approved by the NSA, Google and Microsoft.
Banshee is offline
post #4 of 5 Old 10-03-2012, 10:24 PM
Most of us use a harness to give them full power and only use the stock harness to trigger the relays. What are you putting in?
The only ones I'm aware of that are better are Cibies and perhaps the JW Speakers or a custom HID projector setup...
5 speed auto, 4.10s
Riptide is offline
post #5 of 5 Old 10-04-2012, 05:59 PM
Banshee's Avatar
I put in these reflectors. But this is the RHD version and we have the same style as the Euro type (except that most of them are LHD).
I run them with a pair of +80 H4 globes from the standard wiring. Much better than stock. I know some down here use relays & power from the battery, but I have not bothered with that at this point.
Banshee is offline
