FOUND!! 3 wire LED's for grill marker/blinker - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 10-01-2012, 05:36 PM Thread Starter
usmcdoc14's Avatar
Dont know how long they will last I am trying to find the original maker or if more.
http://www.ebay.com/itm/2-amber-yell...item337c6268d9
after repeated failure trying to convert a 2 wire (marker) 2.5" led to run on the JK 3 wire with capacitors, diodes, resistors, blood, urine.....I gave up. Your luck may vary Then I found these on ebay and they work perfectly.
grind off the factory amber bezel and a 2.5" grommet and light push and lock perfectly in place.
The only specialty wiring done is running a 10ohm 10w wire wound resistor ($3 at radioshack) connected from the blinker wire (red on the LED) to the ground wire (WHITE !! on the LED) and then I covered it all in headshrink to keep the water out. it should not hurt the ceramic being heatshrunk I figure.
taaadaaaaa
3 wire led marker - YouTube
usmcdoc14 is offline
post #2 of 13 Old 10-01-2012, 06:02 PM
Any particular reason why you were hell bent for glory with the LEDs? Or just so you can be cool and have LEDs everywhere?
post #3 of 13 Old 10-01-2012, 06:09 PM Thread Starter
usmcdoc14's Avatar
they were the only non-LED left on the outside of the JK
They were trying to revolt
post #4 of 13 Old 10-01-2012, 06:20 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
You're so trendy...
JKCTAZ is offline
post #5 of 13 Old 10-01-2012, 09:21 PM
BumpInTheRoad's Avatar
Not sure why you want your head shrunken but whatever floats your boat.
However, you might want to upgrade that resistor to a 25W rating. At 12.6V a 10 Ohm resistor is going to dissipate almost 16 Watts. I understand its a 50% duty cycle and normally intermittent use, so you might get away with it. At 13.6V (nominal system voltage while running) it will be 18.5 Watts.
I would also remove the heatshrink from the resistor because if it does overheat you don't want anything that might support fire, such as the plastic tubing.
I'm a JKO Reject
BumpInTheRoad is offline
post #6 of 13 Old 10-02-2012, 05:49 AM Thread Starter
usmcdoc14's Avatar
good point on the wattage, I am also running 25w on the rear LED's.
I found its a trade off with the heat shrink, either I protect it and the plastic may melt (fire is VERY slim due to fusing and resistor location) or I leave it exposed and in a year it falls apart due to rust.
I need to pick up a set of the blingy finned aluminum ones
post #7 of 13 Old 10-02-2012, 06:11 AM
I've had the same issue with the resistor regrading in a pretty short period without being covered as well. It'd be pretty hard to catch that on fire, but a heat sinked one is the way to fly.
post #8 of 13 Old 10-02-2012, 10:21 AM
Victim Of Pain's Avatar
Pun?
Victim Of Pain is offline
post #9 of 13 Old 10-02-2012, 10:02 PM
You could always paint the exposed leads.
[mobile post]
I'm a JKO Reject
post #10 of 13 Old 10-02-2012, 10:03 PM
Banshee's Avatar
Originally Posted by Victim Of Pain View Post
Pun?
Watt are you talking about? In the charge to all LED lighting, resistance is useless!
Originally Posted by Clone7
When you die, you see your life going by in a flash.
Steve Jobs didn't - Apple doesn't support Flash.
This message has been reviewed & approved by the NSA, Google and Microsoft.
Banshee is offline
post #11 of 13 Old 10-03-2012, 07:04 AM
I have just been using the Recon LED markers. They are overpriced crap, but do the job.
whosurbuddiee is offline
post #12 of 13 Old 10-03-2012, 08:26 AM Thread Starter
usmcdoc14's Avatar
found out dude is the maker of these and do not make them any more
shit. was a MUCH cheaper option than the Recon ones.
post #13 of 13 Old 10-05-2012, 07:40 AM
Wiggles's Avatar
I'm 99.99% certain that one of my drop-decks has three-wire, amber, LEDs on it. Next time I'm here when it is, I'll take a look. If it does, I'll get the name and part numbers. I know I have red three-wire LEDs in some places, and I believe the lenses are replaceable. I'll see what I can figure out.
Wiggles is offline
