Single DIN Install - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 09-25-2012, 06:38 AM Thread Starter
j-rod17's Avatar
Single DIN Install
Anyone used something like this to install a single DIN head unit?
anywhere to find other than Crutchfield? I havent had luck any of my usual places.
http://www.crutchfield.com/p_1209965...er-reviews-tab
wondering what your thoughts are and if you have pics of your setup?
at first glance the little pocket area looks to be a great place for some in cab winch controls.
j-rod17 is offline
post #2 of 14 Old 09-25-2012, 06:56 AM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
I can take a picture of my install and post it later.
JKCTAZ is offline
post #3 of 14 Old 09-25-2012, 08:04 AM
usmcdoc14's Avatar
why run a single DIN unless you got a killer deal/already have one?
usmcdoc14 is offline
post #4 of 14 Old 09-25-2012, 08:13 AM
SONIC's Avatar
Get it from crutchfield. They will give you step by step
Instructions to put it in (not that it's hard) but its nice.
-Doc Holiday
SONIC is offline
post #5 of 14 Old 09-25-2012, 08:20 AM Thread Starter
j-rod17's Avatar
my main reason is A) the little space below could be useful for control switches and B) cheaper units
j-rod17 is offline
post #6 of 14 Old 09-25-2012, 08:23 AM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
I scored a Clarion FZ501 on clearance for 70.00 at Fry's electronics. That was my reason. The bezel I ordered doesn't have the pocket so it looks clean.
JKCTAZ is offline
post #7 of 14 Old 09-25-2012, 08:43 AM
JKO Dickhead
Asmmns's Avatar
I got one installed in mine.... And I may have another new one...yours if u want it. Cheaper than crutchfield...
Can get a pic if need be.
__________________
CURE SMA !
Asmmns is offline
post #8 of 14 Old 09-25-2012, 08:44 AM
JKO Dickhead
Asmmns's Avatar
The lower space is somewhat useless...you could run some very small switches and make a front plate but the area is very thin... And anything else you put there just slides out when wheeling anyway ..
__________________
CURE SMA !
Asmmns is offline
post #9 of 14 Old 09-25-2012, 08:55 AM Thread Starter
j-rod17's Avatar
sure lmk.
can you tell me what the distance is of the opening? I would make a solid plate for it and then run one toggle and two momentary push buttons (12 volt guy stuff)
j-rod17 is offline
post #10 of 14 Old 09-25-2012, 09:22 PM
Rottenbelly's Avatar
I have that in my rig. Been in over a year with no problems.
Running a nice SQ pioneer unit.
Sonicelectronixs.com should have them.
I'm not able to get to my jeep where I can measure the opening, but I can just slide my hand into it to get things out of it.
You smell that?
Rottenbelly is offline
post #11 of 14 Old 09-26-2012, 07:38 AM
HeloJeff's Avatar
I have the same one with the pocket. Got it from Sonicelectronix when I ordered the rest of my stuff. It works good for stashing a wallet but for switches you would probably nee to turn them sideways. Ill go measure it for you.
HeloJeff is offline
post #12 of 14 Old 09-26-2012, 07:42 AM
HeloJeff's Avatar
4 5/8" deep 7" across 1" tall
HeloJeff is offline
post #13 of 14 Old 09-26-2012, 07:53 AM
TimbillyOSU's Avatar
I won a Pioneer unit in a raffle. I traded it to another guy for a $50 gift card to 4WD Hardware and it towards a Rigid Diffused for a Backup Light and some LCA skids. I think I made the right call
But, I can definitely see where that little cubby could be useful. My brother-in-law has a 2012 and I'm jealous of his storage spaces compared to my 2010...
RK 2.5" Flex - Body Armor Front Bumper - Superwinch 8500 lb - Rigid Industries Dually Flood Lights and Diffused Reverse Light - G2 Gear & Axle Diff Covers - Dynomax Exhaust - Drake Off-Road Billet Knobs - Oliver's Driveshafts
Coming to JKO to get educated on politics is like a marathoner watching the Special Olympics to get technique pointers.
TimbillyOSU is offline
post #14 of 14 Old 09-26-2012, 09:58 AM Thread Starter
j-rod17's Avatar
thanks! I will check my switches before buying this.
j-rod17 is offline
