BACKUP LIGHT HELP - JKowners.com : Jeep Wrangler JK Forum
post #1 of 20 Old 09-23-2012, 07:31 PM Thread Starter
BACKUP LIGHT HELP
Im planning on getting a set of rigid dually flush mount led lights to put on my rear bumper so I can actually see when I back up at night. What would be the best option to get for this specific application?
1) Diffused
2) Flood
3) Spot
burton861 is offline
post #2 of 20 Old 09-23-2012, 07:39 PM
JKashat's Avatar
1) Diffused
2) Flood
3) Spot
For backup, I'd say diffused. That's what I did. I have two dually d2's.
2012 JKUR Bright White - Ordered 2-1-2012, Built 3-7-2012, Arrived 3-9-2012, Picked Up 3-10-12
JKashat is offline
post #3 of 20 Old 09-23-2012, 07:48 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
I have floods on mine mounted above the spare and they do very well!
JKCTAZ is offline
post #4 of 20 Old 09-23-2012, 07:52 PM
coilrod's Avatar
I have a single dually flood tilted with a bias toward the driver side. I will eventually add another, but it works well enough now that I aimed it to the drivers' side.
coilrod is offline
post #5 of 20 Old 09-23-2012, 07:58 PM
They also make a mount for right above the brake lights. One of the Jersey Crew guys is running them and they look pretty sharp. Plus, it puts the light on either side and elevates it a little more than it would be on the bumper.
Just a thought
Dancin Dan is offline
post #6 of 20 Old 09-23-2012, 08:14 PM
TimbillyOSU's Avatar
Just a thought
Who makes that mount Dan? Any pics or a link?
RK 2.5" Flex - Body Armor Front Bumper - Superwinch 8500 lb - Rigid Industries Dually Flood Lights and Diffused Reverse Light - G2 Gear & Axle Diff Covers - Dynomax Exhaust - Drake Off-Road Billet Knobs - Oliver's Driveshafts
Coming to JKO to get educated on politics is like a marathoner watching the Special Olympics to get technique pointers.
TimbillyOSU is offline
post #7 of 20 Old 09-23-2012, 08:27 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Here ya go. Manny sells them.
http://www.xtorm4wd.com/store/produc...mduallymount2/
JKCTAZ is offline
post #8 of 20 Old 09-23-2012, 08:41 PM
toymaster's Avatar
If the lights are going to be fixed mounted then, you want a flood pattern. You want to light up as much area as possible around the jeep. (spot lights are only good if you can point them exactly where you need them)
JK 2dr rubi
toymaster is offline
post #9 of 20 Old 09-23-2012, 09:02 PM
BumpInTheRoad's Avatar
Everytime I see that photo I hear music from Close Encounters in my head.
I'm a JKO Reject
BumpInTheRoad is offline
post #10 of 20 Old 09-23-2012, 09:04 PM
Originally Posted by toymaster View Post
If the lights are going to be fixed mounted then, you want a flood pattern. You want to light up as much area as possible around the jeep. (spot lights are only good if you can point them exactly into the face of aholes behind you with their brights on)
FIFY.
I'm a JKO Reject
post #11 of 20 Old 09-23-2012, 09:07 PM
toymaster's Avatar
Originally Posted by BumpInTheRoad View Post
FIFY.
Well in that case, spots would be better....
JK 2dr rubi
post #12 of 20 Old 09-23-2012, 09:12 PM
bnb2010's Avatar
I put two vision solstice lights in my wild boar top.
Bryan
bnb2010 is offline
post #13 of 20 Old 09-24-2012, 05:19 AM
Why is it on the Passenger side?
post #14 of 20 Old 09-24-2012, 05:21 AM
I would run the floods for the flush mount option that you want.
post #15 of 20 Old 09-24-2012, 11:00 AM
Vin
Vin's Avatar
they only make the mount for the passenger side. I've been waiting for the driver's side mount for a while now.
Vin is offline
post #16 of 20 Old 10-18-2012, 10:58 PM
Hot Duck's Avatar
I have a pair of the Dually lights with the flood pattern in my rear bumper and I have no regrets at all. They work really well and provide plenty of light.
Hot Duck is offline
post #17 of 20 Old 10-19-2012, 06:20 PM
07unlimitedx's Avatar
I got one of the mounts from Manny with a D2 Diffused on it...
07unlimitedx is offline
post #18 of 20 Old 10-19-2012, 07:29 PM
JKJ
JKJ's Avatar
BDF makes a mount that goes on the tail light assembly.
http://www.northridge4x4.com/shop/bl...ainless-single
Here's one from Olympic.
http://www.quadratec.com/products/12110_041X_PG.htm
Floods definitely.
JKJ is offline
post #19 of 20 Old 10-19-2012, 07:36 PM
Nukeman's Avatar
http://www.maxxima.com/
Check out theirs. I have a set of their MWL-07's (under work lights). AMAZING....
2008 RUBY UNLIMITED
T&T CUSTOMS
Nukeman is offline
post #20 of 20 Old 10-19-2012, 09:15 PM
Ludski's Avatar
got diffused.
comparing diffused with flood. and i say diffused is WAY better. scatters the light perfectly instead of shooting in a designated spot. I slid them in farther now btw, just had them out wide so easier to take soft top off.
*The More You Play With It, The Bigger It Gets*
Ludski is offline
