Pull front axle, after reinstallatio locker was engaged and wont disengage - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 09-16-2012, 02:33 PM Thread Starter
jkennedy's Avatar
2007 JKU Rubicon
60,000 miles
I pulled my front axle to truss it and upon reinstalling it the lockers are engaged and won't disengage.
Ive tried-
Jacking up to turn wheels manually
Pulled diff cover to check wiring
Continuity test on locker
Checked Fuses
Checked Front and Rear relay's
Now
Rear won't disengage either
both switchs have a slow blink
jacked the rear, put in drive tried to disengage both manually.
Tried reseting everything using AEV pro cal
I dont know what else to try. Any help would be greatly appreciated.
jkennedy is offline
post #2 of 2 Old 09-17-2012, 02:55 PM
jacktuttle's Avatar
Mine go stuck once
Originally Posted by jkennedy View Post
2007 JKU Rubicon
60,000 miles
Ive tried-
Checked Fuses
Now
My rear locker got stuck on once up in Big Bear in the snow. I was able to jack up the rear to take the stress off and just remove the fill plug, then using a flat blade screw drvier manually release the locker by sliding it sideways. I think it was to the right. I took it into the dealer and they could not reproduce the problem. My light was not blinking slow, so you may have a different problem. You might try disconnection the battery for a few minutes and try releaseing with no power to the system.
jacktuttle is offline
