sPOD and Rigid... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 09-14-2012, 08:51 PM Thread Starter
sPOD and Rigid...
I have the sPOD 6 switch panel installed in my jeep, and I am in the process of installing multiple Rigid lights. My question is the Rigid lights come with a fancy wiring harness that includes a relay, fuse and switch. Can I just wire the rigid straight to the sPOD and cut the rest of the items off of the Rigid harness or are they necessary for the lights to work correctly??
2008 Unlimited Rubicon Black
RK 3.5 Max Travel:Fox Shocks:Fox Front Steering Stabilizer:Ace Front Stubby w/ Stinger:Ace Tubular Fenders:Ace Rear Bumper w/ Tire Carrier:Level 8 ZX Wheels:37-12.5-17 MTR-Kevlar:Engo 9K Winch:Currie Anti-Rock:Synthetic Winch Rope:6 panel sPOD:Rigid Lights:AEV Procal
1badjk is offline
post #2 of 11 Old 09-14-2012, 08:54 PM
EMG006's Avatar
Just wire direct to the sPod. Don't need all the other stuff.
River City Offroad
Metal Cloak
EMG006 is offline
post #3 of 11 Old 09-14-2012, 08:58 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Ditch all of the Rigid supplied stuff. The Spod is fused and relayed already up to 30 amps per channel I believe. I have been keeping the switches and relays from Rigid as spare parts. The Deutsche plug and about 12" of wire is all you need along with wire to extend to the Spod.
JKCTAZ is offline
post #4 of 11 Old 09-14-2012, 11:46 PM
BANZAIKEV's Avatar
Not to hijack but if I have two or more dually lights how can I wire them to the s-pod so I can control them from one switch?
MAY THE LORD BLESS YOU.... YOUR JEEP.... AND THE TRAILS YOU RIDE ON....
BANZAIKEV is offline
post #5 of 11 Old 09-15-2012, 07:16 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Parallel wiring. Positive to positive to positive, negative to negative to negative, etc.
You just run a single pair of wires from the sPod to the first light hook it up with another set of wires running to the next light. Match polarity at each connection and done
If you need a diagram, PM me and I can whip up a quick diagram.
JKCTAZ is offline
post #6 of 11 Old 09-18-2012, 11:05 PM
BANZAIKEV's Avatar
Thanks Chris
post #7 of 11 Old 09-19-2012, 06:35 PM
EAD Offroad's Avatar
Rigid is an awesome supplier for us. If you need their products without the relay and switch send me a PM and I can save you a couple of $. You will want the wiring harness however.
Alec Wallis, Owner |
| 303-918-6167
| 888-521-0170
EAD Offroad is offline
post #8 of 11 Old 09-19-2012, 06:40 PM
jeeperjkj's Avatar
Alec, what could you possibly want the Rigid harness for if you're running and sPod?
jeeperjkj is offline
post #9 of 11 Old 09-19-2012, 06:44 PM
Nothing, I was wrong, and forgot the harness also included the relay and switch. Thought it was just the wires and plug.
You may want this http://www.eadoffroad.com/rigid/rigi...eter-extension just to tap into.
Sorry.
| 303-918-6167
| 888-521-0170
post #10 of 11 Old 09-19-2012, 06:56 PM
jeeperjkj's Avatar
Right on. That's exactly what you'd want.
post #11 of 11 Old 09-20-2012, 09:37 AM
tvernon's Avatar
That's what I'll do when I buy the D2's.
tvernon is offline
