Run new cable or add extension - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 03-28-2012, 03:56 PM Thread Starter
taxman's Avatar
I bought a new Uniden Pro520XL and am relocating my existing CB installation from underneath my dash to above my rear-view mirror. The problem is that the coax isn't sufficiently long to go up the passenger A-pillar and across the top of the windshield. I have (maybe) a foot of slack below the dash where I currently connect my Midland 75-822.
I currently have 18' of uninterrupted Firestik-brand coax with their Firering end on one end and the mini coax connector on the other. I don't think I have much slack along the way to make up for the missing length.
Should I remove the old 18' cable and run a new 25' uninterrupted coax cable or just add a 9' section with a screw-type coax coupler?
Any substantial loss in signal strength or voice quality?
Thanks.
2018 JL Rubicon Unlimited, 6-speed, White
1985 CJ-7, 4-speed, 258 I-6, 3" Springs, 33" BFG AT, Gunmental Gray
taxman is offline
post #2 of 8 Old 03-28-2012, 06:16 PM
Slow and Low
Co4Lo's Avatar
Good question. Personally I would rather have an uninterrupted cable. But I don't really have a good explanation of why. I guess I would consider additional couplers as restrictions to a smooth signal??
Edit: That reminds me... I have a CB question too but I'll start a new thread.
Co4Lo is offline
post #3 of 8 Old 03-28-2012, 06:42 PM
Heavy D's Avatar
I can't speak definitively about signal loss but would imagine there might be some loss at a connector if you spliced cables together.
I would opt for a new cable and have it uninterrupted.
Ron
Heavy D is offline
post #4 of 8 Old 03-28-2012, 07:18 PM
TCdawg's Avatar
Great question Taxman, I've got the same dilemma. Supposedly 18' will get you from mid rear door to above the rear view mirror but I don't think mine will do it.
I'm about to ditch my Cobra 75 for a unit installed above the rear view mirror myself.
TC
TCdawg is offline
post #5 of 8 Old 03-28-2012, 08:16 PM
babiehughie's Avatar
Are you using an over-head mount? If so, why not run the 18' up the rear roll bar to the sound bar to the over-head mount? Just thinking....
Originally Posted by STUPIDFACE View Post
I have 2 legs, but 3 knees....right knee.....left knee.....wee knee....
Jack of all Trades, Master of Some
babiehughie is offline
post #6 of 8 Old 03-28-2012, 08:22 PM
zjr
zjr's Avatar
The connector will lose some signal, any electrical connectors I have seen always do, but doubt it'd be too bad to not use. As long as you check the SWR properly and don't have a bad #...
I personally think it would be fine, but make sure you protect it from dirt and water.
zjr is offline
post #7 of 8 Old 03-28-2012, 08:37 PM Thread Starter
taxman's Avatar
Thanks for the responses. I think I'm going to buy a 9' extension with coupler and test the SWR. If it works, I'll go with it and report back. Otherwise, I'll ditch the 18' and get a 25'. I don't think my 18' will make it. I'm going out the center plug of my rear door to the Or-Fab carrier with very little slack. I got to the glove box with about a foot of slack.
taxman is offline
post #8 of 8 Old 03-28-2012, 10:05 PM
Radioman's Avatar
In commerical work we would never, ever, add to a cable that was too short; we always replace it with a longer cable. You stand to lose 1.5 to 2 dBs of signal (about a third).
My father was a staunch conservative and voted straight line Republican until the day he died, now he votes Democrat.
Radioman is offline
