Looking for switched and illumination wire under steering column - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 04-09-2011, 03:30 PM Thread Starter
b4tn's Avatar
Or better yet under the drivers side, side dash cover. I have my ARB compressor mounted, wired up, and switch mounted but I need a switched source under the steering column and illumination (hot when headlights are on) Before I start sticking pins in wires and testing with the volt meter I was hoping someone had a quick answer
2010 Surf Blue Unlimited
b4tn is offline
post #2 of 7 Old 04-09-2011, 03:51 PM
Heat'n and a beat'n...
STUPIDFACE's Avatar
I think its an orange and gray wire. Check it becuase im not 100% sure.
corey d
2008 JEEP...
STUPIDFACE is offline
post #3 of 7 Old 03-08-2012, 11:24 PM
Any confirmation on this, I am looking for the same?
Thanks,
Brent
Brent13 is offline
post #4 of 7 Old 03-09-2012, 01:51 AM
should be an orange wire with a gray stripe hooked up to the power windows switches or the AC controls.
2012 Silver Rubi. AEV 2.5" lift, JCR Dagger front bumper, Superwinch EPI 9, JCR engine skid, ACE side steps, RR 7" HID lights, Wired HDH switch panel
formerly- 2001 Yellow XJ, 7" longarm, lockers, bumper, winch, armor, lights, etc
whatevah is offline
post #5 of 7 Old 03-09-2012, 05:27 AM
Whilton777's Avatar
Yep, orange with gray stripe. That's what I hooked my led's up to so that they come on when my lights are on.
Whilton777 is offline
post #6 of 7 Old 03-09-2012, 08:19 AM
So behind the power window controls? How in hell to you get a wire up to that point, without tearing the dash apart?
Brent
Brent13 is offline
post #7 of 7 Old 03-09-2012, 08:25 AM
unsub's Avatar
Brent
There's a couple write ups on radio swaps that show you to get back there. You take the center piece off the top of the dash, then there's a couple bolts that hold the face on. It's not hard to do.
Crew
unsub is offline
