Sirius Radio Help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 04-04-2011, 12:32 PM Thread Starter
08SaharaM6's Avatar
Sirius Radio Help
I took my stock radio out and replaced it with an OEM radio equipped with Sirius.
My stock radio had one port for the AM/FM Antenna and a port for the Power Cord.
The OEM has an extra port for the Sirius antenna, which is where I plugged in the aftermarket TRAM Sirius antenna. My question is, Am I missing any other power cords? Should there be anything else to hook up. I have pics below to show what ports I am using, please let me know if anything is missing.
My stock radio
OEM Radio I purchased with Sirius Radio
Thanks, Matt.
2008 Jeep Wrangler Unlimited X
Jersey Kustoms Front/Rear Bumpers and Sliders
Engo 10000 Winch
Skyjacker 4" Value Flex Lift
16" Ion Alloys
35" Baja MTZ Radials
K&N Drop In
Thrush Custom Cat-back
VHT Markers and Taillights
Jersey Kustoms Tramp Stamp
08SaharaM6 is offline
post #2 of 13 Old 04-04-2011, 12:36 PM
SONNYDL's Avatar
If you have the port that fits the Sirius antenna, one for your factory antenna, and the power, then you should be fine.
The Sirius antenna does not require any extra prower source if that is what you're asking.
SONNYDL is offline
post #3 of 13 Old 04-04-2011, 02:02 PM Thread Starter
08SaharaM6's Avatar
Thats what I have one sirius, one am/fm and one power. Am I missing anything? Since I am not using the stock antenna?
Engo 10000 Winch
16" Ion Alloys
K&N Drop In
post #4 of 13 Old 04-04-2011, 02:33 PM
MaloCS's Avatar
Nope, your description is EXACTLY how my head unit and antennas are hooked up. You should be good to go.
Those that the beast is looking for...
Listen in awe and you will hear him...
BARK AT THE MOON!
MaloCS is offline
post #5 of 13 Old 04-04-2011, 02:56 PM Thread Starter
08SaharaM6's Avatar
Then I'm screwed! It is activated, signal has been sent three times. NO channels, no sound, nothing! Could the aftermarket antenna be the problem?
Engo 10000 Winch
16" Ion Alloys
K&N Drop In
post #6 of 13 Old 04-04-2011, 03:41 PM
SONNYDL's Avatar
First off, why aren't you using your factory antenna? Do you plan on never using AM/FM again? If you want to be able to, you need to hook the factory antenna back up as well.
Can you play CDs in it? If you hooked up the standard radio antenna, are you getting those stations? If not you may have to go to a dealership and have them unlock the radio for you. Depending on where you bought it from, some places have the ability to bypass the security lock, whereas others don't. If they don't you have to pay Jeep like 15-30 bucks unless you have someone there that will cut you slack.
As far as the SAT antenna goes, where did you buy it? Where do you have it sitting?
Also, not to insult your intelligence, but if everything else above checks out, are you sure you are pushing the Sirius button on the device? I know, I know, but I had to ask.
SONNYDL is offline
post #7 of 13 Old 04-04-2011, 04:04 PM
I am using the factory antenna. As you can see in the first pic, my original radio only has a spot for the am/fm radio. In the second pic you can see the second port for the Sirius. I hooked up the factory antenna to the original spot(it will not work in the other port) I hooked up the sirius plug to the only other available port. Then lastly I plugged in the power plug.
Everything else works. The CD player works, the am/fm works fine. I have a subscription to Sirius now and it does not work. Everything with the exception of the Sirius works.
Lol, I am very well aware of how to use the radio! I had one in my Sahara, this one did not come with Sirius and I miss it so I was trying to just replace it with a factory unit so I had no problems but I guess that was wishful thinking!
Jersey Kustoms Front Bumper
Jersey Kustoms Sliders
K&N Drop In Filter
Daystar Dash Panel
Tread Lightly Rubber Mats
Drilled/Slotted Rotors
08UnlimitedX is offline
post #8 of 13 Old 04-04-2011, 04:26 PM
SONNYDL's Avatar
Like I said, no offense was meant, but as I am sure you know... sometimes people trip up on the simple stuff! Now, here is what I personally would do... go to Best Buy, tell the guy what car you have and say you need a SAT antenna for the factory head unit, buy it and take it to the car and try to hook it up to see if you get anything. This is actually how I figured out my first Sirius radio ever was a dud. If it works you know it was your antenna. If it doesn't, it is somethin with the head unit and you can return the antenna to Best Buy with no penalty.
SONNYDL is offline
post #9 of 13 Old 04-04-2011, 06:40 PM Thread Starter
08SaharaM6's Avatar
Ok, after letting a few hours pass and getting a clear head, I went back out to try it again. I double checked everything and it seemed fine, so the only logical explanation is that they didn't send a signal to my radio. I called the back, I finally got someone that I could communicate with and figured out that the original person that I talked to from the morning wasn't doing his job. He sent out a signal and within 5 minutes of trouble shooting I had my radio up and running. I knew I couldn't be that bad at swapping a radio!!!! Thanks for the suggestions.
Engo 10000 Winch
16" Ion Alloys
K&N Drop In
post #10 of 13 Old 04-04-2011, 06:47 PM
BeerMonkeY's Avatar
doesnt suprise me, when i got my first JK i had a aftermarket sirius in my TJ so i dint need that anymore simce the JK had it and was free for a year, so i call sirius and tell them to cancel the one in my TJ since my new jeep had it already, so that was in nov of 06 and it still works to this day, they never turned it off, never got billed again either.
'92 YJ
'13 WK2
BeerMonkeY is offline
post #11 of 13 Old 04-04-2011, 06:49 PM
SONNYDL's Avatar
Congrats. I have actually seen quite a few bad units being sold recently which is why I starting to think about the Head Unit.
The ones that really get me are the mygigs being sold with junk fans... people should be ashamed.
Now go listen to your radio.
SONNYDL is offline
post #12 of 13 Old 04-04-2011, 08:17 PM
cjb321's Avatar
this is why i reactivated mine myself, i went through the same thing in my old silverado which best buy installed, they tried 2 different radios and the same thing happened. finally i just went to the website at thier store and sent the signal myself and it was up before i even got back out to the shop lol. when the jeeps free year ran out i just went to the website after i had the money to renew it and resent the signal and was done in less than 5 min.
glad ya got it working, i went for a while without it and it sucked, i hate regular radio now lol
Chris
'09 Rubicon 2dr, Silver
cjb321 is offline
post #13 of 13 Old 04-04-2011, 08:26 PM
SONNYDL's Avatar
When you are about 3 weeks from your subscription being up, if you call and ask for the cancellation desk and say you can't afford to pay the high price they knock 50% off. Almost no hassle, though I know some people who had to call back a couple times before reaching someone who could/would acknowledge the deal.
SONNYDL is offline
