ECU/ TCM issues - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 03-26-2011, 02:15 PM Thread Starter
ECU/ TCM issues
I bought a totalled jeep and have been rebuliding it. I'm almost done but I can't start it and getting funky display. The ECU came in a lip lock bag with writing saying it's for the 07'/3.8L/Auto. The issue is the dash display reads that all my gears are lite that I'm in every gear so the nutural switch I believe won't let you start it with the key. I can jump start it at the starter but I can get nothing more then a spit or sputter after I put a little starting fuild spray. I'm not 100% sure this is the ECU/TCM that came out of the jeep or another one. The mileage is close to what they said it had.
HELP please
catmandojeeper is offline
post #2 of 7 Old 03-26-2011, 02:46 PM
SONIC's Avatar
Well is yours 07/auto?
You cannot start a JK without the correct transponder key, which may be part of your issue. Your ECM has to be flashed to your key or vice versa to start at all, starting fluid and a jump will never do it, the CANBUS system is too complex.
If you are reading in all gears at once, have you checked the connection fromt he ECM to transmission? It sounds like that may be an issue as well.
-Doc Holiday
SONIC is offline
post #3 of 7 Old 03-26-2011, 03:01 PM Thread Starter
Yes it's an 07'/auto. I should of said that this is a "X" model. My key is not chipped if that's what you mean. It doesn't look anything like my other 07" Sahra that is chipped. I wonder if that might be some of my problem if the ECM is set up for the chipped key.
I will reconnect the connection at the ECM and at the connection at the tranny. Thanks.
post #4 of 7 Old 03-28-2011, 08:44 AM
SONIC's Avatar
That wll definitely make a difference.
The JK will not start without a chipped key.
-Doc Holiday
SONIC is offline
post #5 of 7 Old 03-28-2011, 06:31 PM Thread Starter
Yep! Just talked to a company that reflashes the ECU and my VIN # calls for a chipped key and I email a picture of my key..... It's chipped. Boy how these keys have changed from what I'm used to. Guess I'll be reflashing my ECU. Thanks. Still have issues with the tranny reading correct. Might be all in the ECM/TCM??
post #6 of 7 Old 01-08-2012, 12:17 AM
I can help you out if you still need to get it running.
2007 JK Unlimited 6 speed supercharged
2011 JK Unlimited Auto Supercharged. looking to purchase. pm me
thundercat90096 is offline
post #7 of 7 Old 03-21-2017, 02:34 PM
apjk's Avatar
Were you ever able to figure it out? I'm having the same problems
apjk is offline
