CB antenna ground? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 03-20-2011, 07:36 PM Thread Starter
CB antenna ground?
I'm working on mounting my first CB in my JK and I had a question. I think I'm at the point where I have read every CB thread out there, but can't seem to find the answer. I have a Connex 3400HP, Firestix antenna, and I'm using the truck stop mirror mount on the license plate. There is currently no ground for the mount which is on plastic or for the antenna. So do I need to ground the antenna, the mount, both or neither?
Current JK
2013 JK Sport S
6spd
Past JK
2007 JK Unlimited Sahara
4.10's stock
6spd
Custom muffler relocated
33x12.50/15 BFG AT TKO's
Procomp 15" steelies
pookie is offline
post #2 of 8 Old 03-22-2011, 12:31 PM
oO_Rogue_Oo's Avatar
Ground the mount for best results.
2008 Rubicon 2 Dr 6 speed
Stone White
oO_Rogue_Oo is offline
post #3 of 8 Old 03-22-2011, 03:46 PM
desert dog's Avatar
No, there is no antenna ground wire. Many mistakingly believe that the little wires at the base of some antennas (like the Wilsons) are a ground, but they are not.
Just make sure that the metal mount is firmly attached to the metal on the Jeep and that your washer stack is in the correct sequence. Also make sure that the antenna wire is not coiled and that your radio has a clean ground and power source.
desert dog is offline
post #4 of 8 Old 03-22-2011, 03:58 PM
zjr
zjr's Avatar
It all depends on the antenna you got. Does it SPECIFICALLY say "No ground plane"?
If not, then you need to ground the mount.
zjr is offline
post #5 of 8 Old 03-22-2011, 04:38 PM
desert dog's Avatar
The Firestick does not need to be grounded.
post #6 of 8 Old 03-29-2011, 10:17 AM
Res6cue's Avatar
You might want to consider changing your mount. I just installed a Ultramount from Cool Tech LLC.
http://www.cooltechllc.com/jeep/jk_ultramount.shtml
It is designed to mount a FireStick to the rear license plate mount of the JK. The instructions are great. The ground for the bracket is done through the mounting bolt. They even recommend "roughing up" the finish under where the fender washer & nut go for the mount.
'13 JKU Rubicon - 3" Teraflex Lift w/ 8 Flexarms, LoD Rock Sliders, Poison Spyder Evap Skid, Nitto Trail Grappler 35x12.5x17
'12 JK Artic - 2" RE Lift, Poison Spyder Knockers, Surprise Straps Grab Handles
Res6cue is offline
post #7 of 8 Old 05-09-2011, 10:40 PM
jrider's Avatar
There are antennas made to run without a ground but they must be run with a special cable that grounds back through the CB. You cannot say a "Firestick" does not need a ground because they make them both ways. I have a Firestick and it grounds through the mount as most antennas do.
Definately check the mount as the placement of the nylon insulator is VERY important
jrider is offline
post #8 of 8 Old 05-09-2011, 11:03 PM
desert dog's Avatar
Firestik on JK does not need a ground. Mount needs to be grounded.
