My stock radio "sound" skips???? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 03-16-2011, 11:14 PM Thread Starter
fourplyn's Avatar
Ok, I've got the mopar indash 6 disc stock stereo.. I just bought another one and installed it...and its still does the same thing..
Here's what it does. When it warms up, the sound skips. Its not the head unit. I'm guessing its the stock amp? Maybe...is there such a thing in these or is it built into the head unit? The power doesn't cut out. When playing a CD or DVD it does the same thing... Its like I have an aftermarket amp and the cables have a slight tear in them or something...
I haven't torn into it any farther...Anyone know what this could be.
Past jeep:
- 40" Pro Comp X-Terrain
fourplyn is offline
post #2 of 14 Old 03-17-2011, 12:06 AM
Cbass122's Avatar
No idea what it is but mine is doing the same thing. I thought it was just the radio but it happens when I have my mp3 player hooked up as well.
Looking for the answer as well.
Cbass122 is offline
post #3 of 14 Old 03-17-2011, 06:30 PM
jeepersheart's Avatar
Funny I saw this mine started doin it the other day I thought it was a radio sation problem but it has done it on a few different stations now. Really weird it sounds just like a skipping CD
2008 Detonator 2Dr. 6 Sp.
Jersey
Crew
jeepersheart is offline
post #4 of 14 Old 03-17-2011, 08:33 PM
Y'all bein watched by da gubmint...
Dancin Dan is offline
post #5 of 14 Old 03-18-2011, 09:56 AM Thread Starter
fourplyn's Avatar
I can tell ya, its not the radio...So I'm guessing a wire is slightly loose or rubbing something.
Past jeep:
fourplyn is offline
post #6 of 14 Old 04-21-2011, 07:23 PM
Cbass122's Avatar
Did you ever find the source? I am still dealing with this and was thinking about buying a new radio, etc to get rid of it...
Cbass122 is offline
post #7 of 14 Old 04-22-2011, 08:50 AM Thread Starter
fourplyn's Avatar
Never found the issue. But now its gone. Seams I've had issues when it was cold. I know its not the radio. I'll bet a stereo shop might be able to track the issue down. Might even be where the harness clips into the back of the deck.
Past jeep:
fourplyn is offline
post #8 of 14 Old 04-22-2011, 10:54 AM
Yea same here once the bitter cold weather moved out the issue seems to have rolled out with it.
Jersey
Crew
post #9 of 14 Old 04-29-2011, 11:25 PM
Cbass122's Avatar
I live in the desert so apparently that is not my issue (cold weather).
I have not done any modification to the sound system so I am not sure why this started???
Cbass122 is offline
post #10 of 14 Old 06-11-2013, 08:53 AM
jerryn's Avatar
Do you have Uconnect ? If so do you have a device plugged into the usb reader ?
I've got a large 64gb flash in there right now and when the flash is read to create a browsing directory sometimes that would cause the music to skip. I might connect an old wd usb drive instead. i don't know how well a hd is going to do when I am on the trails. I might need to work in some way to dampen the shock to the Hard drive.
jerryn is offline
post #11 of 14 Old 07-23-2013, 04:59 PM
Catfish's Avatar
well I was gonna start a new thred, searched and found this and since the last poster tired to bring it from the dead I will too. It happened to me once after a partucularily intersesting trail run. That time I wiggled any wires I could find that might be loose and bingo fixed (CB, winch. lights, power and gorunds, doors ect). Then a year later it started happening again. This time I want to do more than jiggle wires. My CB power was "profesionally installed" with the power wire held into the fuse box with a fuse. It is wearing where it comes out under the lid I will replace and report. other ideas? someone smarter than me said it sounded like an alternator issue
Catfish is offline
post #12 of 14 Old 07-23-2013, 10:35 PM Thread Starter
fourplyn's Avatar
I've sense sold me jeep. but I never had the issue again. Not sure what it could have been honestly.
Past jeep:
fourplyn is offline
post #13 of 14 Old 07-24-2013, 12:33 PM
Any chance it's gotten wet. Mine gets the occasional drop from the top leaking but I don't use my CD player often. Hopefully I don't have the same issue if I go to use mine!
bombout800 is offline
post #14 of 14 Old 07-24-2013, 05:28 PM Thread Starter
fourplyn's Avatar
That's funny you said the hardtop leaking. As soon as I got my ORH soft top. Inever had the problem. Lol maybe that was it. Damn JK gremlins
Past jeep:
fourplyn is offline
