08' JK Stereo upgrade - JKowners.com : Jeep Wrangler JK Forum
post #1 of 1 Old 03-15-2011, 07:10 AM Thread Starter
I have an 08' Sahara JK/ non infinity and I've been thinking about doing an audio upgrade, I'm going to swap the stock head unit and everything else for that matter, multiple concerns- one-is the CAN bus/ lack of ignition switch, can I just take my 12VDC positive ignition off the cig lighter/power port, I just can't see dropping 100.00 on the PAC unit for an ignition source only, if thats the safest option then I'll pony up-any input would be helpful, second-dash tweeters-I'm going to go with new components up front, who has used the factory tweeter pods and dropped in new tweeters, if so what brand and pics if possible?? Also 6 1/2inch mids appear to be what works in the factory dash pods, is a kit needed or are they basically a drop in/file fit with no gaps?? Third-rear overhead speakers-has anyone used 5 1/4 w/ the install kit and the OEM grill, if so- pics??? I know 6 1/2's will fit, I've read about the 77 kick 10 as a nice fitting/sounding option I'd just like to keep the OEM grills and as I'm going w/ a sub there only going to be for rear fill. Thank you in advance for your input.-T
toddabbott is offline
