Clock Spring - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 03-12-2011, 09:32 PM Thread Starter
Question Clock Spring
I installed cruise on my sons 08 jk. The cruise works fine and there are no codes. However, the horn doesn't work. Could this still be the clock spring if the cruise is working? I was extra careful not to touch the clock spring when the steering wheel was off. Thanks for the help.
volcycle is offline
post #2 of 9 Old 03-13-2011, 03:40 PM
I donno if the 08 is the same as the 07 but the clock spring was under a cover so it should be fine. If i remember right doesn't it have a plastic part that goes sort of around the wheel so it makes contact for something? Was this installed if its fine. I'd start checking fuses and the horn. I know this cause when I did the cruise control when taking off the steering wheel it popped open the cover on the clock spring and boing!!! Spring everywhere so mine had to be totally replaced good luck
mattymat04 is offline
post #3 of 9 Old 03-13-2011, 04:22 PM Thread Starter
I checked the fuses they are fine. I did notice when I unhooked the battery to check the connections under the airbag again that the horn sounded when I hooked the battery back up but would not work when I pushed the steering wheel. I unhooked again and the horn did not sound.
volcycle is offline
post #4 of 9 Old 04-10-2011, 09:38 PM
chileanjk's Avatar
Just today I fixed my horn, it was the spring clock, two lines were shorted, after a full rain with the soft top and a few drops get in the steering wheel, I disassembled the spring clock and on one of the conectors has a dry black drop, cleaned very well and now is back from the dead, assembled every thing and my horn is back, no more Finger!
2007 Wrangler Diesel CRD, 35" Cooper discoverer, AEV 3.5" premium
chileanjk is offline
post #5 of 9 Old 04-14-2011, 11:12 AM
Muvovr's Avatar
What I have learned
Since replacing the clock spring a week or so ago, I no longer turn my steering wheel without starting the JK.
I don't think the clock spring was designed to take the force of turning the wider tires a lot of US install. My issue did not start until I started straightening the wheel with the engine off.
Just my two
When I was growing up, if we wanted a Jacuzzi, we had to fart in the tub.
Muvovr is offline
post #6 of 9 Old 04-14-2011, 12:46 PM
Panamon Creel's Avatar
The clock spring doesn't transmit any steering forces to your wheels, it's just an assembly with a spiral wound flat ribbon cable inside and shouldn't make a difference for it if you turn your wheel with engine off or on.
Panamon Creel is offline
post #7 of 9 Old 04-14-2011, 01:09 PM
Muvovr's Avatar
So what your saying is....
It's just a shitty design then !!!!
Hello bitches! Ladies I hope you don't mind me calling you bitches cuz I don't know you all by name.
Muvovr is offline
post #8 of 9 Old 05-10-2011, 02:28 PM Thread Starter
bump to see if anyone else can help. When I installed the cruise I didn't even bother the clock spring except to unplug and plug.
volcycle is offline
post #9 of 9 Old 05-10-2011, 03:56 PM
Muvovr's Avatar
Does the Cruise Control
I've replaced the clock spring u should be ok there.
Does the Mopar Part require a computer flash to work correctly ???
Factory Fog Lights sure do !!!!
Muvovr is offline
