Will this schematic work for mood lighting? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 03-11-2011, 06:15 PM Thread Starter
Here's what I'm trying to do. I want to have the LED's in my footwells come on when I open the doors (when the dome/courtesy lights come one). I also want to be able to have JUST the footwell lights come on while the key is in the on position and for the footwell lights to be dimmable using a seperate dimmer (not the dimmer for the dash lights). I do not want the dome/courtesy lights on at this time (doors closed). Will this schematic work??
Menard666 is offline
post #2 of 13 Old 03-11-2011, 07:14 PM
bodyguy's Avatar
yup
bodyguy is offline
post #3 of 13 Old 03-11-2011, 07:20 PM Thread Starter
Thanks!
post #4 of 13 Old 03-11-2011, 07:43 PM
Stopher's Avatar
You electrical guys amaze me.
08 "X", RC BB, 33" Duratracs, Coast 1310 front, Hellfires, Woods evap relo.
Stopher is offline
post #5 of 13 Old 03-11-2011, 09:32 PM Thread Starter
I'm not an electrical guy at all..hahah. Just to update though, that schematic did not work for me. I have the dimmer switch from Oznium, and with the first diagram the courtesy light circuit would not activate the footwell LED's. With the key on it worked fine, but as soon as it lost the +12V, the LED's would go out. I fixed it by running another wire from the courtesy circuit to the input side of the dimmer and adding another diode.
Results of this new schematic are as follows:
With the key off, footwell LED's function with the courtesy light circuit (on when doors are unlocked, on when doors are opened.
With the key on, courtesy lights go out but footwell LED's remain lit.
Dimmer has full control of the footwell LED's.
When the courtesy lights turn on, the footwell LED's remain dimmed to where you set them.
The only glitch I am seeing is that the "auto dim" feature on the courtesy circuit makes the footwell LED's flicker as it dims out. Not a concern to me, but thought I would mention it.
New working schematic:
post #6 of 13 Old 03-11-2011, 09:44 PM
bodyguy's Avatar
I wonder if it has something to do with the ground going through the dimmer.
bodyguy is offline
post #7 of 13 Old 03-11-2011, 10:03 PM Thread Starter
If I ground the output side of the dimmer to the chassis all of the LED's get full power, it acts as if the dimmer isn't there. I'm not sure exactly how the dimmer works.
This is the dimmer I have:
h t t p://www.oznium.com/rotary-led-dimmer
post #8 of 13 Old 03-12-2011, 10:17 PM
bodyguy's Avatar
that makes sense
might be a bit much but you could use the dome light power wire to trigger a relay that would add a ground when only the dome circuit is on.
bodyguy is offline
post #9 of 13 Old 03-12-2011, 10:53 PM
enigmaverse's Avatar
http://www.oznium.com/rotary-led-dimmer
no need to break your links up here... your allowed to link to products and businesses.
Joe -
enigmaverse is offline
post #10 of 13 Old 03-13-2011, 06:47 AM
Discombobulated's Avatar
do Diode's work with dimmers? I thought they needed constant voltage to work.
Discombobulated is offline
post #11 of 13 Old 03-13-2011, 07:20 AM Thread Starter
that makes sense
I was actually thinking of this afterwards. I may add one in the future, going to run it as is for now and make sure everything is going to work and not burn up.
Wasn't sure, thanks.
I'm not sure, have to read up on it, but as of right now I can tell you that the diodes are working for now. They are 1n4001, and there are three in my circuit.
post #12 of 13 Old 03-13-2011, 09:43 AM
Broncojohn's Avatar
It's a pulsed circuit. LED's don't really dim, but you can get them to turn on and off fast enough to look dim.
Broncojohn is offline
post #13 of 13 Old 03-13-2011, 09:51 AM Thread Starter
You are right. I can notice no flicker. I assume a standard AC dimmer would not work with LED's. This one is specific for LED's, so it must increase the pulse width modulation. Either way, the effect it gives is the dimming of the LED's and that all I care about.
