i need help. jeep wont start - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 03-09-2011, 04:18 PM Thread Starter
Mikey's Rubi's Avatar
I put the key in the ignition and all of the electrical stuff turns on but when I put in the clutch and turn the key nothing happens. My keys (both the spare and the normal one) do not work. Neither do the remote door unlock. Is it my key?
Sent Via Zip Line Messenger
Mikey's Rubi is offline
post #2 of 9 Old 03-09-2011, 05:08 PM
tkob1060's Avatar
check this out https://www.jkowners.com/forum/showthread.php?t=4276
you should be able to reset the module by disconnecting the battery for 10+ min then reconnecting.
tkob1060 is offline
post #3 of 9 Old 03-09-2011, 06:06 PM Thread Starter
Bitchin. Thank you. Ill let you know what happens.
post #4 of 9 Old 03-09-2011, 07:37 PM
I was just looking for info on this.
Happened to me when I was leaving work last night. Put the key in and nothing. Doors are never locked, so I didn't notice the remote entry not working right away. Had it towed to dealer, picked it up this evening after having a new module installed and the keys programmed.
Orrin is offline
post #5 of 9 Old 03-09-2011, 09:18 PM Thread Starter
Fixed it. Disconnected the positive terminal on the battery. Then pulled the M13 fuse. Let t sit for about 10 minutes and all is well in the world. For today.
post #6 of 9 Old 03-09-2011, 10:03 PM
tkob1060's Avatar
thats good news. in future you should disconnect the negative terminal
tkob1060 is offline
post #7 of 9 Old 03-09-2011, 11:33 PM Thread Starter
Roger.
post #8 of 9 Old 03-10-2011, 12:21 AM
2010jk's Avatar
Thats good to know.
2010jk is offline
post #9 of 9 Old 03-10-2011, 06:57 AM
But... is there a work around if the fuse / battery disconnect does not fix this??
I was lucky and it happened when I was leaving work. What if I'm on vacation, or the middle of nowhere? The Jeep just up and decides it won't recognize the key. That is a big deal if I'm far from home.
Orrin is offline
