Wire Wrap - KC Slimlight harness - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 03-07-2011, 10:54 PM Thread Starter
COL_V's Avatar
Simple question for which I have not found the answer via search.
What is the size of split plastic wire wrap used for KC light wire harness. I just installed my KC Slimlights on winshield mounts, and have wires zipped in place, but want to dress and protect right.
I'm stuck here in Germany, so having to order on-line for wire wrap. Can anyone with experience in the size and lengths required for wrap let me know what I should order. Thinking 3/4 inch and perhaps 8-10 ft required, but that's a swag. Different size required for wires to switch and wires to lights?
Thanks!
You are never too old to learn something stupid
COL_V is offline
post #2 of 3 Old 03-08-2011, 07:45 AM
Thanks!
I think that 3/4 will be a little large. If you were to losely base this on a conduit fill chart. You could install + 15 - #12 conductors in a 3/4 pipe. Even the 1/2" will accept + 9 - #12 conductors. So I would recomend the 3/8 loom. And I used about 20'. Ya I had some left over. But it came in 10' packs.
"The Green Monster"
2007 2 Door X Jeep Green with Freedom Top
16" Painted Aluminum Mopar Wheels
Grab Bar Mod on front bumper
130w KC Daylighter Driving Beams on grab bar
130w KC Daylighter Long Range Beams
on
Smittybuilt Windshield Brackets
Rock Light Mod
Reverse Light Mod
Mood Light Mod
JK-Ford is offline
post #3 of 3 Old 03-08-2011, 07:58 AM Thread Starter
COL_V's Avatar
Thanks. Was over estimating on the size, so appreciate your recommendation. I'll get 20 feet, as there are always other uses down the road.
COL_V is offline
