jk grounding - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 03-07-2011, 08:56 PM Thread Starter
van7559's Avatar
jk grounding
does the jk have a positive ground, or a negative ground? The reason I am asking is the cb that I ordered tells you this
negative ground-connect red wire from cb to positive pole, and black to negative pole or to a neutral such as a chassis ground
positive ground- connect black wire from cb to negative pole , and red wire to a neutral such as a chassis ground.
I actually plan on running it via a little 12 volt adapter that plugs into the accessory port(12v) I am gonna pick up from radioshack, so I am not even sure if it matters, it has a + and a - screw to attach the wire leads to. I just need to know what to hook to what/ If I don't make any sense, it is because I am an electrical dumbass, and this question proves it!
I r confused Help TIA
07' Unlimited X
PSC Bumpers F/R
8k Warn winch
2.5" RK Max Travel
35" MTR's
5:13 yukons
Sleeved/Gusseted front
Dynomax pre-axle exhaust
van7559 is offline
post #2 of 8 Old 03-07-2011, 09:01 PM
bodyguy's Avatar
negative ground
bodyguy is offline
post #3 of 8 Old 03-07-2011, 09:13 PM Thread Starter
van7559's Avatar
thanks for the reply I appriciate the quick help
07' Unlimited X
PSC Bumpers F/R
8k Warn winch
2.5" RK Max Travel
35" MTR's
5:13 yukons
van7559 is offline
post #4 of 8 Old 03-07-2011, 09:16 PM
sPOD-guy's Avatar
Feedback: 12 reviews
Polarity....
Yes the Jeep is set-up chassis as ground, not the positive.
If you plan on using a 12VDC power adapter plug for your CB, make sure that you connect the positive wire to the center pole on the power plug! The outer prongs are the negative. Keep a fuse inline! Most power plugs have an internal fuse.
PM me and I will send you a power plug. Shoot me a picture of the wires and the back of the CB and let me know what brand and model it is.
Good luck.
-John the sPOD guy
switches jeeps panels jk-forum carling contura led switch windshield
sPOD-guy is offline
post #5 of 8 Old 03-07-2011, 09:36 PM Thread Starter
van7559's Avatar
pm sent how much are your power plugs?
07' Unlimited X
PSC Bumpers F/R
8k Warn winch
2.5" RK Max Travel
35" MTR's
5:13 yukons
van7559 is offline
post #6 of 8 Old 03-07-2011, 09:43 PM
sPOD-guy's Avatar
Free. Just email me your address and I will put some connectors and the plug in the mail.
-John the sPOD guy
sPOD-guy is offline
post #7 of 8 Old 03-08-2011, 09:00 AM
spillidge's Avatar
Kick ass man.
spillidge is offline
post #8 of 8 Old 03-08-2011, 09:31 AM
Thumbs up NICE!
That's what I'm talking about!
Nothing like a guy helping out just to make sure someone wires it up right!
Dancin Dan is offline
