high beams "timed out" ?? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 02-28-2011, 05:02 AM Thread Starter
JimmyJK's Avatar
So, we all know that the driving lights turn off when you switch to high beams.
Ok, so one morning, it's rainy-sleety-windy and coming down in waves, just one after another. For some odd reason, I thought I had a better sight picture by holding the momentary high-beam feature on, whilst the driving lights stayed lit.
This lasted for ~20 seconds and kicked back down to low-beam. It didn't matter if I pulled back on the left lever to flip the lights again. No Joy. If I set the high beams on, they'd commit, but I definately had a loss of momentary high beams.
After about a minute, it went back to normal.
Is this an over-heating issue? Is there some built-in safety feature? I did a search on this site for similar writes but came up dry. Anyone else experience this?
08 Detonator Yellow JKU sold 04MAR2013
-Patriot, Vet, Christian, Son, Brother, Father, Husband, Friend, blue collar Irish guy-
JimmyJK is offline
post #2 of 12 Old 02-28-2011, 05:18 AM
sixty5vdub's Avatar
I have had the exact same thing happen to mine. I was on a realy dark stretch of road, tried using the momentary high beams while the low beams stayed on. Worked out the same way yours did.
It is probably just a safety thing built into the system. Either to prevent overheating, or to prevent us from driving around with low and high beams on .............
Anthony
AMP
sixty5vdub is offline
post #3 of 12 Old 02-28-2011, 05:50 AM
It's to keep from melting itself. That makes both light elements go through one bitty ground wire/connector on the light. Thats why it's temporary
post #4 of 12 Old 02-28-2011, 10:51 AM
Sounds like the Can-bus doing it's job....With both high and low bean burning the Can-bus reads too much voltage draw and turns it off.
07 2 Dr White Rubi, 6spd
Linexed tub
EVO Rear Bumper Fascia
Poison Spyder Boby Mounted Tire Carrier
Matercraft grab handles
M.O.R.E. 1" BL
Shrockworks midwidth w/ winch hoop / Linexed
Warn 9.5TI / Spidertrax fairlead / Viking trail line
Marathon Seat covers
PC 8179's 15x10
Toyo MT 37x14.50x15
Shrockworks sliders
EVO C2 Gussets
3.5" Rock Krawler X Factor
Coil Overs Front/rear
12" rear stretch
River Raider stretch corners
Smittybilt XRC front enders
07JKRUBI is offline
post #5 of 12 Old 02-28-2011, 12:13 PM
This:
<---- Solves the problem.
I can run my lowbeams & fogs and still illuminate the road way ahead like it was daytime
Dancin Dan is offline
post #6 of 12 Old 02-28-2011, 01:05 PM
Amperage
post #7 of 12 Old 02-28-2011, 07:45 PM
fishgutz's Avatar
Amperage
"Current."
Amperage is the measure of current draw.
fishgutz is offline
post #8 of 12 Old 02-28-2011, 07:53 PM
Originally Posted by fishgutz View Post
"Current."
Tomato to Tomato when it comes to that...depends on the context.
post #9 of 12 Old 02-28-2011, 08:06 PM
venom's Avatar
actually its neither
it must just use a timer instead of actually sensing current draw because all my canbus connected wiring does is activate relays and it still times out
Originally Posted by My Wife
venom is offline
post #10 of 12 Old 02-28-2011, 08:09 PM
I bet that time limit was programmed based off testing and current capabilities of that design. Rather than a random number being punched in
post #11 of 12 Old 02-28-2011, 11:13 PM
ibjammin's Avatar
LOL I found this out a few weeks ago when a prick in a lowered honda wipped right in front of me and slamed on his brakes I hit the horn he flipped me off and then I hit the high beams and held it lighting up the inside of his car after about 20 seconds they kicked off I wondered why now I know!
ibjammin is offline
post #12 of 12 Old 03-01-2011, 04:36 AM Thread Starter
JimmyJK's Avatar
sweet!
Voltage, Amperage, Current, Lowriders.... Got it. Glad I'm not the only one that this happens to.
Hey Dirty, you've written that your LED headlight install has been problematic due to your computer/wiring issues, right? Does this apply when YOU use your low-draw upgrades??
Thanks to all 4 the feedback
JimmyJK is offline
