Spod + ARB wiring harness - What can I remove? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 02-24-2011, 03:58 PM Thread Starter
Voodoo11's Avatar
Hooked up the ARB compressor harness to the Spod today.
What if any wires can I now eliminate from the ARB? Can i get rid of everything except what is connected to the ARB/Spod harness? Does the Spod provide power to accessories or do I still need to wire power to the battery?
Voodoo11 is offline
post #2 of 6 Old 02-24-2011, 06:29 PM
Mule'Con's Avatar
That is the beauty of the sPOD-just hook up the pos & neg wires from the compressor directly to the pos/neg under the sPOD cover.
2008 Red Rock Rubicon Unltd 6spd dual top
Mule'Con is offline
post #3 of 6 Old 02-24-2011, 07:01 PM
robctry69's Avatar
Send a message via AIM to robctry69
if i recall corect i wired my arb to the battery then hooked the wire that would go to the on off switch to the spod if you need better instruction on it i would contact john and he will walk you thru it he is a great guy to deal with
robctry69 is offline
post #4 of 6 Old 02-27-2011, 02:22 PM Thread Starter
Voodoo11's Avatar
Guys. I plan on running the power to the battery but want to shorten up the connection to the ARB harness on the Spod.
I ripped out the entire ARB wiring loom today. It seems like I need to cut/splice some of the ARB wires in order to shorten it up for the Spod. Is this consistent with everyone else's experience? If not, it looks like I still need to keep the entire loom as is, looping it from the compressor, to the battery, back to the compressor side to the ARB/Spod harness. This still keeps all the relays intact/etc, which is what i thought was the purpose of the Spod.
Can i cut any of this and shorten it up?
Voodoo11 is offline
post #5 of 6 Old 03-03-2011, 03:01 AM
Just make a drawing of the orignal harness so you can put it back exactly how the manufacture intended. It realy doesn't matter what equipment that you use for the controls ( SPod, ARB, Ect ). Just as long as the control circuitry stays the same. Then you can rip the system out and rewire it back to what ever control device you choose. Switches and wiring are all the same ( as long as they have the same rating). But I would stick with the ARB relays.
"The Green Monster"
2007 2 Door X Jeep Green with Freedom Top
16" Painted Aluminum Mopar Wheels
Grab Bar Mod on front bumper
130w KC Daylighter Driving Beams on grab bar
130w KC Daylighter Long Range Beams
on
Smittybuilt Windshield Brackets
Rock Light Mod
Reverse Light Mod
Mood Light Mod
JK-Ford is offline
post #6 of 6 Old 03-03-2011, 08:57 PM Thread Starter
Voodoo11's Avatar
Hooked it all up today.
IPF 900xs
ARB Compressor
IPF 968s
Rigid 6" LEDs.
Now need to do rear roof rack lights and maybe rock lights
Voodoo11 is offline
