cb's which one - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 02-22-2011, 09:50 PM Thread Starter
van7559's Avatar
cb's which one
I am just looking to be able to talk to the people in my group/area. I don't need all the bells and whistles, just want it to be functional. I think I am gonna go with the teraflex antenna mount, but I don't know shit about cb's, antenna, or how to wire them for that matter. Can I just plug the damn thing into the cig lighter, attach an antenna and go or what. Please help
van7559 is offline
post #2 of 17 Old 02-22-2011, 10:11 PM
go buy a radio shack brand small sized unit for 60 bucks. trust me when i say all of buddies use these and the expensive ones break...only has volume and squelch and it always works with great range...2 cents
DBrosJeep is offline
post #3 of 17 Old 02-22-2011, 10:14 PM Thread Starter
van7559's Avatar
does it just plug into the cig lighter, or do I have to hard wire it? What abou an antenna? What all is needed to wire these things?
van7559 is offline
post #4 of 17 Old 02-22-2011, 10:14 PM
oh yeah after several installs i can tell you its simple to wire it up just red-12v source/ black ground to metal somewhere very simple. but the antanne can be tricky you need a solid mounting point that is a good ground if you buy a cb bracket made for jk's you should be good to go because they are made for areas that have good grounds. also for quick solution you can get a magnetic but highley not advised on a jeep bc they fall off normal trucks in the woods and we have plastic roofs... so get a mount, a firestick antanne, and radioshack small simple cb unit. 100 bucks or less and will do you justice.
Frank
post #5 of 17 Old 02-22-2011, 10:16 PM
oh yeah it does come with 12v outlet adapter if you wish not to wire. at least they used to not sure but you can buy one for like 5 bucks if not
post #6 of 17 Old 02-22-2011, 10:17 PM
I bought a Midland 75 for $79. Works awesome with a 4' firestick and can disconnected to used as portable CB.
Sent from my SPH-D700 using Tapatalk
VKJK is offline
post #7 of 17 Old 02-22-2011, 10:18 PM
thats sounds good what he said...also firesticks=great call up knowwheretojeep.com im sure eric stocks them. goodluck on the cb install
post #8 of 17 Old 02-22-2011, 10:21 PM Thread Starter
van7559's Avatar
this must be the one your talking about?
http://www.radioshack.com/product/in...ductId=2102653
van7559 is offline
post #9 of 17 Old 02-22-2011, 10:26 PM
its black and has green led.....also i like bc they are small 1/4 of size of a normal cb. if your interested in a loudspeaker outside the vehicle to tell people your going to run their cars over if they dont move/ jk then youll need a larger cb for the watts as the small ones are ony 4 watts..as a cb your golden they work well...any more ? feel free
post #10 of 17 Old 02-22-2011, 10:32 PM Thread Starter
van7559's Avatar
obviously you have to run a coax wire from the cb to the antenna. Where are you hiding this. do I need to stay away from anything besides stupid sharp bends>?
van7559 is offline
post #11 of 17 Old 02-22-2011, 10:39 PM
mount it up front like under the glove box is good spot.... run the WIRE CABLE out on of your rear drain plugs wire tie the section that is under the body up away from anything and run to rear antennae. you can keep excess coiled up doesnt seem to affect anything. ive installed a lot of these. im sure some other wheelers on here got wiring ideas also my specialty is stereos really...
post #12 of 17 Old 02-22-2011, 11:35 PM
WeGo4x4's Avatar
For the same price as the mount you can buy this radio..
http://www.radioshack.com/product/in...ductId=3799949
I run a cheap radio shack cb as well and have no issues. I bought it about 10 years ago and its still going strong. Only advice I would give is make sure it has a plug for an external speaker. You may think you don't need one, but if you ever take the doors off and drive on the freeway you'll know what I'm talking about. I mounted a speaker in the roll bar padding above the drivers seat. Works great doors off and all. You can either make your own mount or drill into the stock carrier and run a angled coax connector like the pic below.
It's very important to tune your setup with a swr meter. There are a ton of cb threads but most importantly is to get the swr low. Usually a bad ground caused bad swr readings. Also, the other switches on the more expensive radios are very nice to have. You can adjust how far you can send and receive and such, but if you don't care about that then the cheapos are great. Sometimes on the trail you'll pick up other people and you can adjust your radio to tune them out depending on range.
WeGo4x4 is offline
post #13 of 17 Old 02-27-2011, 06:00 PM
Jimmy2x's Avatar
If you are looking for a good, quick, CB education, check out www.rightchannelradios.com. They are great to work with also.
"A government that is big enough to give you everything you want, is strong enough to take everything that you have." - Thomas Jefferson
Jimmy2x is offline
post #14 of 17 Old 02-27-2011, 07:36 PM
I have always used Wilson 4' flexible antenna. They bend and don't break, which is really important out on the trail. Stiff fiberglass antennas work great on the street, but out on the trail they can break or damage your mounting point.
4x4x4 is offline
post #15 of 17 Old 02-27-2011, 07:51 PM
cruzcode's Avatar
x 2. Right Channel Radios are great. Great advice, technical knowledge, pricing, and support.
FWIW, for a budget radio that doesn't take up a lot of space, and works fairly well, I'm very happy with my Cobra 75. It is more than a Radio Shack CB, but I've never had a problem with it, and it installs very cleanly.
RC
A lot of chit coming...
W9DRC
cruzcode is offline
post #16 of 17 Old 02-27-2011, 09:22 PM
I've got the cobra XX75 (don't know the letters). Have had it 3 years, works great. Added bonus was it's easy to install.
JKOutdoors is offline
post #17 of 17 Old 02-27-2011, 09:41 PM
Hittnthebz's Avatar
I have the Uniden 510XL on this mount. I use a 4' Firestik on a Teraflex mount.
Hittnthebz is offline
