dual battery question???? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 02-18-2011, 05:42 AM Thread Starter
vandegrift's Avatar
If you are going to put together a dual battery set-up with Optima Batteries, can you run a Red Top (which I have) and a Yellow top, if I want to use it for winching?
Or should I go with 2 Yellow Tops?
35" KM2's - Poly Performance Fox Coilover system - TeraFlex Arms - PSC Ram - Rugged Ridge Modular Snorkel - COP 4X4 Nack Attack - Tatton Driveshaft - S-POD - 5.13 and 6 speed.
vandegrift is offline
post #2 of 12 Old 02-18-2011, 06:07 AM
bthomas's Avatar
seeing as how optima batteries are nowhere near as good as what they were 10 years ago, i wouldnt use them.
bthomas is offline
post #3 of 12 Old 02-18-2011, 06:21 AM Thread Starter
vandegrift's Avatar
What would you use?
post #4 of 12 Old 02-18-2011, 06:36 AM
MoridinTX's Avatar
A lot of people are using Odyssey batteries. Same type of tech (AGM) as the Optimas but been getting better ratings.
Sears sells their Platinum battery (rebadged Odyssey) in two flavors. Regular and Marine (Deep cycle). I have the Marine in my Jeep.
http://www.sears.com/shc/s/p_10153_1...0134000P?mv=rr
http://www.sears.com/shc/s/p_10153_1...0034000P?mv=rr
09 BLACK Sahara 4 Door - Auto, G2 4.88s
TF 2.5" Coil Lift w/shocks, TF Frnt Adj Trac, TF FLCA, JKS Discos, JKS Rear Adj Trac, LOD Full Rear GEN2,
A.C.E. Rock Rails, Viper TB: Check the Garage for more.
MoridinTX is offline
post #5 of 12 Old 02-18-2011, 07:05 AM Thread Starter
vandegrift's Avatar
Thanks, I'll check it out
post #6 of 12 Old 02-18-2011, 07:12 AM
Dr.Dirty's Avatar
Feedback: 21 reviews
Im a optima convert as well, but if you have one already id use the red top as your main Jeep Batt and get a yellow top as you backup bat with all your lights and winch tied to the yellow top.
Dr.Dirty is offline
post #7 of 12 Old 02-18-2011, 07:15 AM
Dr.Dirty's Avatar
here is a link to my Dual batt install.
Dirtys Dual batt writeup
Dr.Dirty is offline
post #8 of 12 Old 02-18-2011, 11:36 PM
No, you should always use matched batteries in any multi-battery situation. Different batteries have different charge/discharge characteristics and having mismatched sets will not be optimal for most switching/charging systems.
Zombie Killer - 2010 Unlimited - Dark Charcoal Pearl
Follow my build
or check out my
X-caiver is offline
post #9 of 12 Old 02-22-2011, 10:00 PM
ibjammin's Avatar
If your running 24v yes there could be a problem with mis matched batteries but in a dual battery 12v set up you only charge and use one battery at a time!
ibjammin is offline
post #10 of 12 Old 02-24-2011, 08:09 AM Thread Starter
vandegrift's Avatar
I will probably just go with 2 new ones now that the tax return is showing up this year..
post #11 of 12 Old 02-24-2011, 09:22 AM
SFCCotton's Avatar
I am running the Sears Diehard Platinums. Basically they are rebadged Odessy batteries but with a 4 year replacement warranty. Optima only gives you a 1 year replacement warranty.
SFCCotton's_Most_Awesome_Dual_Battery_Install_Thre ad!
SFCCotton is offline
post #12 of 12 Old 02-24-2011, 02:27 PM
You better check yo'self before you wreck yo'self
Many battery isolators are actually combining the batteries the vast majority of the time. The isolator will kick in when the primary battery drops below a threshold voltage to ensure you can always crank, but other than that you are usually hooked in parallel so they both charge at the same time.
(parallel doesn't change the voltage, going in series would give you a 24v system which most people have no reason to mess with)
Follow my build
or check out my
X-caiver is offline
