2011 switch locations - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 02-14-2011, 09:26 AM Thread Starter
I have an '11 Rubi that I am looking to add some lights to. I want some switches that look somewhat stock. With the new interior the sway bar and locker switches are on the left of the wheel. Next to the switches is a piece of plastic that says "off road" it almost looks as though this were made to punch out and allow the addition of switches. Any ideas for something that would fit here? Also on the lower center dash is a row of switches with the hazards and traction control that has some open spots. I would go with a daystar switch panel but I'm not sure it would fit behind the shift boot, and I kind of like the net.
Any help would be great
ptrlcop is offline
post #2 of 7 Old 02-14-2011, 09:41 AM
Daystar does not have a switch panel yet for the 2011 - so we mounted some light switches below the steering wheel for a clean, out of the way look.
REBEL OFFROAD is offline
post #3 of 7 Old 02-14-2011, 09:48 AM
maverick's Avatar
^^^ clean, but they almost look out of place... maybe because they are centered under the steering wheel... might be better if off to one side of that panel... I would suggest (to OP) that you take the photos above and photoshop varying the location of the switches to determine your preference.
Personally, I would consider replacing the panel with the net at the front of the console where the OEM switches were located in previous year models.
maverick is offline
post #4 of 7 Old 02-14-2011, 09:57 AM
madtownjk's Avatar
Rugged ridge came out with an A pillar switch panel, holds 4 switches. Below is a link about it.
https://www.jkowners.com/forum/showthread.php?t=45073
madtownjk is offline
post #5 of 7 Old 02-15-2011, 04:16 PM
artayay's Avatar
center console remove?
I've seen pics of the center console removal, but the 2011 looks nothing like that..anyone do it yet..want to install the CHR550 LockPick.
a.k.a. Christian - 2011 Black Jeep Wrangler JKU Rubicon
37" MTRK, RK 3.5 X-Factor (3-Link Rear) and other stuff..
Owner/Manager -
and other Web Properties
artayay is offline
post #6 of 7 Old 02-15-2011, 04:50 PM
d'sjk's Avatar
Get an s-pod! They are about to release a new bracket for the 2011's
d'sjk is offline
post #7 of 7 Old 02-15-2011, 05:38 PM
artayay's Avatar
Figured it out..
Very easy..will take pics or vid when I go back in to finish up the cams..
Owner/Manager -
artayay is offline
