7-pin wiring harness: too short?? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 02-01-2011, 11:35 AM Thread Starter
Jeep2.0's Avatar
Question 7-pin wiring harness: too short??
Gang:
For me, the wiring part is the easy part. But believe it or not, my 7-pin harness doens't reach the battery!!
Sure, I looked on the forum & searched. Found several write-ups. All OK so far.
Yeah, I followed the comic-book instructions. As best as I can tell, I routed it correctly.
Sure, once it came up short I went back & pulled everything as taught as I could, while avoiding things like mufflers, exhaust pipes, etc.
But for the life of me I can't figure out why the battery ends (positive & negative) are both ~3" too short.
Has anyone else had this problem?
2011 5.3L GM LC9 Aluminum LS V8 Conversion w/ Custom Dyno Tune
Aluminum Genright Bumpers Front & Rear - Aluminum Nemesis Rockers
PR44/RCV/Reid Front - Superior Rear - ORF Front / Poly Rear Cage - ORF Tire Carrier
RK 3.5" Springs - Fox 2.0 Adjustable Shocks - JKS Arms & Trackbars - Poly Steering
Jeep2.0 is offline
post #2 of 10 Old 02-01-2011, 01:40 PM
Installed mine last summer and it was fine the first time out. You must have routed something the wrong (longer) way. Biggest PITA part I found was where it came up near the battery. Used a fish to pull the wires up. Are you bringing it up right beside the battery or elsewhere?
petro is offline
post #3 of 10 Old 02-01-2011, 02:46 PM Thread Starter
Jeep2.0's Avatar
I fished it up right by the battery. Before that, it was over the transfer case, kinda along the e-brake cables, past the evap cannister, past the muffler along the passenger side frame rail, across the rear x-member to the plug, then to the driver's side tail lamp housing/plug. Is that right?
Jeep2.0 is offline
post #4 of 10 Old 02-01-2011, 02:48 PM
BadAssJK's Avatar
Is there a different part Number for the 2 door or unlimited?
BadAssJK is offline
post #5 of 10 Old 02-01-2011, 03:10 PM Thread Starter
Jeep2.0's Avatar
Doesn't look like it - there's a cartoon showing coiling up the wire to reduce length for the 2-door. I'm only "this much" too short!
Jeep2.0 is offline
post #6 of 10 Old 02-01-2011, 03:33 PM
I don't remember going as far as the passenger side frame rail. If I remember correctly, from the rear plug, it comes about half way across behind the rear bumper then overtop of the muffler (on top of the heat shield), then as you pretty much said, past the evap cannister and pretty much follows the e-brake cables.
petro is offline
post #7 of 10 Old 02-01-2011, 03:37 PM
owtdorz's Avatar
Just did mine on Sunday.
Re-trace your steps.
The directions are a little different in the package versus the ones online.
I went from t/lamp across the bumper beam over to the rt side rail.
Frome there I followed the frame to just at the firewall slope (where it beginns to go up) then to the battery box.
BTW the 2 and 4dr are the same part#.
'09 4dr Rubi Detonator Yellow
3.5 Mid arm Rock Krawler
Finally 5.13s
owtdorz is offline
post #8 of 10 Old 02-01-2011, 03:54 PM Thread Starter
Jeep2.0's Avatar
Instructions online????
Yeah, I definitely followed a different path than the right side rail. (How'd you get it past the fuel tank??). I swear I followed the path in the kit. But online instructions???
Jeep2.0 is offline
post #9 of 10 Old 02-01-2011, 04:10 PM
owtdorz's Avatar
I can print them and fax them. PM me with a fax#.
I ran the wires along the top of the rail from the outside of it and they are pushed over the top of the rail toward the other harness that already runs along the rail.
Finally 5.13s
owtdorz is offline
post #10 of 10 Old 02-01-2011, 05:02 PM Thread Starter
Jeep2.0's Avatar
PM Sent.
So you stayed along the passenger side frame rail from the muffler to the engine compartment?
Jeep2.0 is offline
