ORO Lites - JKowners.com : Jeep Wrangler JK Forum
post #1 of 26 Old 01-30-2011, 03:39 PM Thread Starter
Cbass122's Avatar
ORO Lites
I am planning on running the ORO Lite LED tail lights and the also the LED third brake light/license plate lite relocation.
What do I need to purchase to make all this work outside of just the lights?
I have heard you need some additional resistors and the write ups I have seen showed some relay installed. That looks like it is for the TJ, does JK require this also? Just want to make sure I get what I need when I go to install these two items.
Cbass122 is offline
post #2 of 26 Old 01-30-2011, 03:56 PM
Heat'n and a beat'n...
STUPIDFACE's Avatar
I hope you dont have to do a bunch of bullshit to get the lite dots to work. I plan on getting the RR corners shortly with the lite dots and hate twisting wires.
corey d
2008 JEEP...
STUPIDFACE is offline
post #3 of 26 Old 01-30-2011, 04:22 PM
oz97tj's Avatar
Don't buy the Litedots. They are overpriced and the LEDs don't last for whatever reason.
Spend about 30 bucks on some standard LEDs.
Support the sport. GLFWDA.org
oz97tj is offline
post #4 of 26 Old 01-30-2011, 04:26 PM
e-jeep's Avatar
Feedback: 12 reviews
I got the GenRight plate/3rd brake light with a wiring harness ...from what I understand all I have to do is match the brake light wire and the plate light wire to the corresponding wires on the harness, then both grounds/negs to the harness. It's my project this weekend.
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad
e-jeep is offline
post #5 of 26 Old 01-30-2011, 04:33 PM
STUPIDFACE's Avatar
Would they work with river raider corners? I dont even care if i get leds, id be satisfied with regular lights, as long as they work with the corners.
corey d
2008 JEEP...
post #6 of 26 Old 01-30-2011, 04:36 PM
Mr.RonGilbert's Avatar
I understand that there are some new OROs out there... hopefully they improved the design... I have a set of the old ones that I just wired up. I really like the look, hopefully they will hold up. Worst case I will switch over to the truck style. I just like the look of the blacked out light. The LEDs are nice and bright.
You will need a resistor hooked up from the blinker wire to the ground wire - the best one I found is from Poison Spyder:
http://shop.poisonspyder.com/LED-Res.../41-04-650.htm
The resistor gets hot so make sure you keep it away from anything that will melt. I drilled a couple of holes and pop riveted it to a panel inside the tail light well.
Simply cut off the stock plug and wire the OROs to that.
Mr.RonGilbert is offline
post #7 of 26 Old 01-30-2011, 04:47 PM
oz97tj's Avatar
Don't know. Never ran those corners. PSC runs normal LEDs in their corners, but they don't have the cut out like the RRs do. Do you have the corners already? Maybe you could order them without that mount that they come with, or even just a normal hole cut into them?
oz97tj is offline
post #8 of 26 Old 01-30-2011, 05:29 PM
STUPIDFACE's Avatar
I dont have the corners yet.
corey d
2008 JEEP...
post #9 of 26 Old 01-30-2011, 06:16 PM
terrahawk's Avatar
Corey, you can run the truck lights too, just not the grommet style.
terrahawk is offline
post #10 of 26 Old 01-30-2011, 06:19 PM
Jody - you still fast blinking or have you added a resistor?
post #11 of 26 Old 01-30-2011, 07:08 PM Thread Starter
Cbass122's Avatar
Well I already ordered the Lite Dots and the RR corners so there is no going back now.
Just want to make sure that I get the parts needed to make it all work.
So the PSC resistor pack is all thats needed for the LED Tail lights.
And for the LED third brake light/licence plate light just splice into the wires, no worries.
Cbass122 is offline
post #12 of 26 Old 01-30-2011, 07:10 PM Thread Starter
Cbass122's Avatar
Sweet can you let me know how it goes. I plan on doing this part next weekend. I am moving the license plate to get ready for the RR corners.
Cbass122 is offline
post #13 of 26 Old 01-30-2011, 07:16 PM
terrahawk's Avatar
I added a resistor, but it still fast blinks. I must have it wired in bad, but haven't had time to jack with it.
post #14 of 26 Old 01-30-2011, 07:34 PM
You are correct. I tested it myself earlier. The one thing that did not make any sense was that the instructions on the PSC website stated to connect the resistor to the running light and ground wire... I tried that and still had the fast flash. I moved it to the blinker light (which makes sense) and it worked just fine. Like I said, it did get hot - obviously the longer it is on the hotter it will get. I imagine the worst would be sitting at a stop light waiting to turn... all and all it isn't that big of a deal, just be mindful of it when positioning it.
post #15 of 26 Old 01-30-2011, 09:42 PM Thread Starter
Cbass122's Avatar
Can you tell me what the colors of these wires are or is it just completely obvious? I have not actually pulled the lights off to take a look yet.
I don't use my blinkers most of the time anyway so I doubt they will get that hot very often
Cbass122 is offline
post #16 of 26 Old 01-31-2011, 05:44 PM
White with a yellow stripe = Brake/Turn which is the RED wire on the OROs
White with a purple stripe = Running which is the BROWN wire on the OROs
White with a green stripe = Back up lights which is the BLUE wire on the OROs
The last one is the ground wire, black on the Jeep and a white wire with a little screw clamp on the OROs.
What corners are you going with?
post #17 of 26 Old 01-31-2011, 08:45 PM Thread Starter
Cbass122's Avatar
I ordered the RROR JK Crusher Corners.
So I should just hook the resistor across the oro red and white wires then right?
Any explanation why the resitor only goes on the blinker? I would think you would need one for the running lights + one for the turn signal?
edit: for typo
Cbass122 is offline
post #18 of 26 Old 02-01-2011, 06:35 AM
You are correct about where to place the wires, it is how mine is set up and no fast blink....
I understand that the LEDs need very little power to work, the resistors share the load which slows down the blink.... Hopefully someone who understands wires and shit can explain better... I am just about clueless when it gets more complicated than hot/ground.
And on the RROR corners - use the template and get to cutting. You need the large hole (9"x12") for them to fit correctly. There is a subtle change in the stock body that you can feel and see if you look for it. There will be about a 1/8" gap if installed correctly. That will be filled with silicone to finish it off.
post #19 of 26 Old 02-02-2011, 04:50 PM
e-jeep's Avatar
Took me about 2 hours...
Finished my GenRight plate/3rd brake light today:
My Build Thread ~
Adrenaline Offroad
e-jeep is offline
post #20 of 26 Old 02-02-2011, 08:07 PM Thread Starter
Cbass122's Avatar
Sweet! Looks good. How is the light for the license plate? Looks like it could be a little brighter in the pic?
So did you have any issues or learn anything you want to pass along before I tackle this?
Cbass122 is offline
post #21 of 26 Old 02-03-2011, 02:41 PM
e-jeep's Avatar
Actually, I think it's brighter than the OEM. Nothing to it.
Disconnect the battery negative. Remove both rear lights to gain access to the housings.
Mount the light on the plate bracket and run the wiring down to the opening at the bottom of the passenger side light housing, through the housing, and through the firewall boot.
I had already disconnected my 3rd brake light and rerouted it from an earlier wiring job. I had already pulled the wires back through the cargo door and run then along the inside of the long plastic piece on the inside of the door.
Disconnect your plate light and run it through the firewall boot and under the cargo floor carpet.
Connect all the appropriate wires near the limiting starp for the cargo door.
Add any protection and secure everything with zip ties ...many, many zip ties.
Reconnect the battery and test.
My Build Thread ~
Adrenaline Offroad
e-jeep is offline
post #22 of 26 Old 02-03-2011, 03:15 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
I'm going to give the short version of this because I lost some details in the translation but I just had a very interesting conversation with our friends at ORO.
The way that the JK is wired doesn't allow it to read whether or not a bulb is there, it reads the amp pull from each individual bulb throughout the entire vehicle. So if you change the left front turn signal to an LED bulb that light will blink fast...LOL
There are a couple of ways to fix the fast blink, but none of them work 100% of the time because the computer in the JK is too smart.
You can use the resistor we've been talking about here and deal with the heat buildup that we've all been concerned about.
The other fix is to wire a 3157 bulb back into the wiring between the factory wires and the new LiteDOTs and paint the bulb black. You'll want to secure it in the inner fender to keep it from getting banged around and broken. The paint will keep you from putting on a light show at stop lights.
The light bulb will trick the computer most of the time to believe it is receiving the right load at the tail light bulb which will result in Ritalin for your tail lights. (Works most of the time but they still might get a little crazy)
If you have more questions about this I would highly recommend chatting with Steve @ ORO.
He also mentioned that the LiteDOTs have changed to a higher LED count and new circuit board which they believe will end the issues with durability.
Marcus
RiverCityOffroad is offline
post #23 of 26 Old 02-03-2011, 03:42 PM Thread Starter
Cbass122's Avatar
Faulk, nothing is ever easy is it
I guess I will wait to get them installed and then if need be figure out what to do afterwards.
I already have the lights and resistors on the way so hopefully it all just works out of the gate.
Cbass122 is offline
post #24 of 26 Old 02-03-2011, 05:01 PM
Mine don't fast blink with the resistors wired in..... Not sure what changed with them on there bit it works for now. If they start fast blinking I can live with it vs chasing down a fix.
On edit...... now the passengers side fast blinks.... some times...
The drivers side is fine. Kinda goofy.
post #25 of 26 Old 05-29-2011, 01:33 PM
RubiZealot's Avatar
I just finished installing my RR crusher corners and lite dots. I messed around with the resistor to stop the fast blink, but gave up ( it was 1am) when they didn't seem to fix the fast blink.
I may try again before I silicone seal the corners, but I have two questions.
1. Is there a legal rate of blink (in NJ if you know) thereby requiring these resistors?
2. If the answer to #1 is no, and I don't care about fast blink, will I kill my front directional bulbs faster if i just leave the rear LEDs as is?
Mike 2010 Rubicon 2DR | RK 3.5 X FACTOR MID ARM | ΜΟΛΩΝ ΛΑΒΕ
RubiZealot is offline
