will the s-pod work with locker mod - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 01-25-2011, 07:28 AM Thread Starter
I am looking into buying a s-pod and wondered if I can do the locker mod at the same time? Is there a sway bar mod also, what about traction control? If I can do all of this in the s-pod what are all of you doing with the factory switches??
2007 Rubicon Unlimited 6spd. 3" Rubicon Express, 35" BFG KMS's, 5.13 gears, Dick Cepek Wheels, Rock Hard Front bumper with Bull Dog 10K.
cutterman is offline
post #2 of 17 Old 01-25-2011, 07:35 AM
You could probably add any NEW mod to the s-pod. But you probably can not relocate any OEM controls to the s-pod.
"The Green Monster"
2007 2 Door X Jeep Green with Freedom Top
16" Painted Aluminum Mopar Wheels
Grab Bar Mod on front bumper
130w KC Daylighter Driving Beams on grab bar
130w KC Daylighter Long Range Beams
on
Smittybuilt Windshield Brackets
Rock Light Mod
Reverse Light Mod
Mood Light Mod
JK-Ford is offline
post #3 of 17 Old 01-25-2011, 07:37 AM
Dr.Dirty's Avatar
Feedback: 21 reviews
you can use it for the locker mod
Dr.Dirty is offline
post #4 of 17 Old 01-25-2011, 07:37 AM
Yes you can do the locker mod with the spod, kinda overkill since I believe the spod has relays built into it? Switching a relay with a relay is electrical overkill, but conveinent switching.
The factory switches are pretty much useless if you always use another switch. i dont think there is a "sway bar mod"
post #5 of 17 Old 01-25-2011, 08:33 AM Thread Starter
I realize I don't need relays to do the locker mod but I am trying to keep my dash clean. I am going to use the s-pod to run some lights front and rear and also switch my business band two way on and off. and I am sure I will find a few other things also, I just don't want to have toggle switches on the dash to run my lockers and still have the factory switches in the dash and then have wasted switch space up above in the spod. suggestions are welcome.
post #6 of 17 Old 01-25-2011, 08:37 AM
andrelopez99's Avatar
I did that for my front oe locker, converted to currie sway bar and replaced the switch panel with x/ sahara edition.
andrelopez99 is offline
post #7 of 17 Old 01-25-2011, 08:56 AM Thread Starter
do you by chance have a picture of your setup?
post #8 of 17 Old 01-25-2011, 09:00 AM
What part?
post #9 of 17 Old 01-25-2011, 09:50 AM Thread Starter
do you have a pic of your spod switches and also the factory location after you put the x/sahara trim bezel.
post #10 of 17 Old 01-25-2011, 11:32 AM
You do not have to switch a relay with another relay. All you have to do is a little wire manipulation.
"The Green Monster"
on
Rock Light Mod
Reverse Light Mod
Mood Light Mod
JK-Ford is offline
post #11 of 17 Old 01-25-2011, 09:47 PM
I currently don't have my jeep to give you a photo of the trim bezel.
post #12 of 17 Old 01-25-2011, 10:38 PM
cruzcode's Avatar
Yes.
RC
A lot of chit coming...
W9DRC
cruzcode is offline
post #13 of 17 Old 01-26-2011, 05:14 PM Thread Starter
thanks andrelopez99 for the pic
post #14 of 17 Old 01-26-2011, 05:23 PM
No problem, for reference the top one is the sPOD with air gauge and the dash is the 12voltguy.
post #15 of 17 Old 01-26-2011, 06:57 PM Thread Starter
when I talked with John @ spod he strongly suggested put a seperate switch under the hood so the lockers couldn't be engaged at highway speeds or any other unsafe time, do you have yours this way or not. I really wasn't wanting to do it that way.
post #16 of 17 Old 01-26-2011, 07:04 PM
I do not, did you receive my pm.
post #17 of 17 Old 01-28-2011, 09:34 AM Thread Starter
yes I got your PM
